ek_ger
Admin is unabled to install Flash ActiveX due to missing rights
May 21, 2012 6:33 AM
Hello!
I have been using FlashPlayer ActiveX for a very long time without any problems. Now I tried to upgrade to 11.2.202.253 ActiveX and received the fllowing error message:
"A neccesary file (C:\Windows\system32\Macromed\Flash\FlashUtil32_11_2_202_235_ActiveX. exe:5) could not be written due to missing access rights
." (I translated this from the orinial german error message, so the original english one might look different).
This happens on Windows 7 32bit Home Premium.
I am logged in with admin-rights (in fact I have tried with three diferent admin account).
The Flashplugin for Firefox installe without any problem.
Here is my flashinstalllog:
=O====== M/11.2.202.235 2012-05-21+13-23-59.004 ========
0000 [I] 00000010 "D:\Users\Public\install_flash_player_ax_32bit.exe"
0001 [W] 00001036 Software\Macromedia\FlashPlayer\SafeVersions/11.0 2
0002 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0003 [W] 00001036 Software\Macromedia\FlashPlayer\SafeVersions/11.0 2
0004 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0005 [I] 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
0006 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
0007 [I] 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_2_202_235.ocx
0008 [I] 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_2_202_235_ActiveX.e xe
0009 [E] 00001031 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_2_202_235_ActiveX.e xe:5
0010 [I] 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_2_202_235_ActiveX.d ll
0011 [W] 00001026 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_2_202_235_ActiveX.d ll 5
0012 [I] 00000021 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe
0013 [W] 00001106
0014 [W] 00001106
=X====== M/11.2.202.235 2012-05-21+13-30-03.038 ========
Any ideas / any help?
    May 21, 2012 8:26 PM   in reply to ek_ger
    It seems that the permission problem is not so much the Admin account, but either the C:\Windows\system32\Macromed\Flash folder, or some of the files that should be overwritten in it.
    I suggest that you try the following:
    If you still have permission problems after this, try
    May 22, 2012 6:05 PM   in reply to ek_ger
    I have only looked at the FlashInstall.log file so far.  Are you really sure that the C:\Windows\system32\Macromed\Flash folder was empty at the time of the install?
    I will look at the Procmon log later if I have some time.
    May 24, 2012 11:01 PM   in reply to ek_ger
    From the FlashInstall.log file it appears as if the installer can't write FlashUtil32_11_2_202_235_ActiveX.exe; but I cannot see anything regarding this in the procmon log file.
    I'm a bit lost here...  But, what I would try if that happened to me is the following
    Jun 5, 2012 10:43 AM   in reply to Pat Willener
    I am having exactly the same issue.  using MSI installers instead gives an error.
    Were you able to solve the problem?
    Jun 6, 2012 7:07 PM   in reply to ek_ger
    ek_ger wrote:
    The OCX-file is placed in the installation directory though, but it is not registered as the installation fails.
    Did you actually get a message that indicates "could not be registered"?
    If so -> http://forums.adobe.com/thread/987370
