McPheirsonRae111
Can't open/save pictures as PNG anymore! NEED HELP!
Jun 7, 2012 4:59 AM
Tags: #problem #help #plugin #plug-in #photoshop_cs5 #plug_ins
Hello!
Since yesterday I have the problem, that I can't open/save pictures as PNG any more, the option is completely gone.
When I try to open one, it says "not the right kind of document".
I don't know what I've done, I just wanted to install filters and I've put them in the Plug-ins/Filters folder.
But they didn't work so I've put them out again.
I already deleted my preferences and I am desperate, I don't know what to do anymore.
I have Photoshop CS5.
Thanks for the possbile help I could get.
    Jun 7, 2012 5:17 AM   in reply to McPheirsonRae111
    Boilerplate-text macro:
    Before we waste both your time and mine exchanging potentially irrelevant information, would you be so kind to specify whether you are on a Macintosh or a Windows PC?
    If you're on a Mac, I may have a suggestion or two; if on Windows, I can't help you at all.
    Thanks in advance.
    Jun 7, 2012 5:55 AM   in reply to McPheirsonRae111
    Thank you for the courtesy of your reply.
    You may want to check that you have the PNG plug-in installed in the Plug-ins > File Formats folder, though.
  • PECourtejoie
    Jan 11, 2006
    Jun 7, 2012 6:09 AM   in reply to McPheirsonRae111
    Hello!
    Could you post the content of help>system info? (remove the serial number)
    Did you set an additional plug-ins folder in your preferences? Don't point to the root of the previous version's plug-ins folder, or you'll run in file formats plug-ins.
    staion_two it is the multiformat plug-ins, I think, or something similar.
    Jun 7, 2012 6:23 AM   in reply to McPheirsonRae111
    Looks like you are using version 12.0 of PS.  If so that is way out of date.  Should be 12.05 I believe.  So update to that version.
  • PECourtejoie
    Jan 11, 2006
    Jun 7, 2012 7:35 AM   in reply to McPheirsonRae111
    You said "  I tried to install the additional plugins you know see in this list."
    Which ones?
    I don't see PNG listed, as in this list (for Ps extended, but still)http://forums.adobe.com/message/4365009#4365009
    I'd try to reinstall.
    Also, you seem to have an old graphic card driver, that might cause other issues.
    Jun 7, 2012 10:12 AM   in reply to McPheirsonRae111
    It doesn't work because you've deleted some of the Photoshop plugins, including the one that has the PNG format code in it (multiplugin).
    You need to restore the plugins that shipped with Photoshop to get all the filters and supported file formats.
    Jun 7, 2012 5:41 PM   in reply to McPheirsonRae111
    Well, you're missing several plugins that are installed by default.
    You, or someone using your machine, have deleted or disabled those plugins.
  • PECourtejoie
    Jan 11, 2006
    Jun 8, 2012 12:45 AM   in reply to McPheirsonRae111
    Hi, try to do a reinstall.
    Jun 21, 2012 9:25 AM   in reply to McPheirsonRae111
    This may not be what your problem was, but it may help others when they are troubleshooting..
    I was having the same issue after they upgraded my computer to Win7. I was getting ready to send IT an email to see if they could reinstall when I thought what about running as administrator... So when I right clicked on Photoshop in my startup menu and click on Run as Administrator, I now have Save As Web and Device and can now save to other file formats. YAY! And if you want it to always run as administrator - Right click the icon, Properties, Compatibility and click the box next to Run this Program as Administrator.
Bookmarked By (1)
