Show/Hide with button hot spot
Mar 23, 2012 11:17 PM
I've seen this done with other interactive magazines, but have not been able to figure it out myself. I'd like to be able to touch one "hot spot" and have some content appear, then touch the same "hot spot" to have the content disappear. Is this even possible to do with DPS, or might this magazine have been using other software?
  • Bob Bringhurst
    May 29, 2007
    Mar 24, 2012 7:17 AM   in reply to JoSchro
    Jun 7, 2012 6:05 AM   in reply to Bob Bringhurst
    Hello
    Is it possible to do the following ?
    01: to have targets (green circles) acting as buttons
    02: when you chose ot click on one of these (here green) target, it opens an image or text like this (yellow rectangle) AND makes ALL OTHER TARGETS DISAPPEAR
    note: if you click on the top right green target, it opens ANOTHER destination close to it etc.)
    03 : when you click on the opened destination (here the yellow rectangle), the destination disappears and all other green targets come back (back to 01).
    AND then it can act the same way for all others
    I tried many ways, can't find the trick, if there is one
    Jun 7, 2012 6:12 AM   in reply to jbalmain
    Put everything into an MSO including the buttons. The first screenshot you showed would be state 1 of the MSO. Tap on one of the buttons and it takes you to another state.
    Bob
    Jun 7, 2012 6:38 AM   in reply to Bob Levine
    I don't get it.
    And can't explain why.
    Not sure I cleary explained what I wanted to achieve.
    Jun 7, 2012 6:52 AM   in reply to jbalmain
    Let's back up...do you know how to create an MSO?
    Bob
    Jun 7, 2012 7:14 AM   in reply to Bob Levine
    yes
    main problem seems to be that if i try to insert a button in one state of the MSO (like: go back to "STATE1 where you only see he buttons"), the button does NOT work
    Jun 7, 2012 7:46 AM   in reply to jbalmain
    and i read and search everywhere including here http://forums.adobe.com/message/4340921 but can't make it work ...
    Jul 25, 2012 10:57 AM   in reply to jbalmain
    First: sorry for my bad english. Second: sorry for this stupid question!
    I use Hot Spot Button but i don't understand what it means: hot spot?
    And also: what is the difference between Button and Hot Spot Button?
    Sorry Bob...
    f
  • Bob Bringhurst
    May 29, 2007
    Jul 25, 2012 11:55 AM   in reply to Folobo
    A hot spot is a type of button. In DPS, a hot spot button lets you tap an area to display a pop-up image. The pop-up image usually has a close (X) button.
    Jul 26, 2012 2:28 AM   in reply to Bob Bringhurst
    Many thanks Bob!
