davidstri
Can I publish a movie to a single VOB file?
May 26, 2012 8:39 PM
Tags: #file #size #remove #change #separate #stutter #bad #limit #vob #gap #noticeable
I have been having trouble getting the best quality out of my large video project that I am trying to publish, but I found that VOB files provide the best quality. The only problem is that it publishes my movie to three VOB files. When I burn the files to a DVD, there is an extremely noticeable stutter or small gap between the three VOB files. They do not play together smoothly on the DVD in the DVD player. Is it possible to make adobe premiere elements 9 remove the VOB size limit when creating a DVD folder and publish the whole movie to one VOB file?
    May 26, 2012 9:44 PM   in reply to davidstri
    The DVD-Video specs. allow for VOB's to be 1GB. If your Timeline exceeds that limit, it will span multiple VOB's.
    What is the problem, if your Timeline spans several VOB containers?
    Good luck,
    Hunt
    May 27, 2012 3:25 AM   in reply to davidstri
    Are you using Share> Disc> DVD to create your DVD or some other method to create your VOB files? If the former you should not notice any stutter between clips on a 4.7GB DVD. If you are, then I wonder if you have burnt a high-speed disk on your PC that your player is struggling to work with.
    Try this:
    • Share> Disc> DVD and select 'Burn to Folder'. Make a note of the  Folder location and name.
    • Download and install the free burning software 'ImgBurn'.
    • Use ImgBurn to to burn the folder you just created (Help> View ImgBurn Guides... for details if you get stuck).
    • In the Device tab select a write speed of x2.
    Let us know if that works for you.
    Cheers,
    Neale
    Insanity is hereditary, you get it from your children
    Jun 2, 2012 3:38 PM   in reply to davidstri
    >adobe cannot publish a whole movie to a single VOB file
    You need to go back and re-read #1 from Bill Hunt... Premiere Elements (and Encore bundled with Premiere Pro) follow the DVD specification for the size of a VOB
    Since VOB files are only used when creating a DVD, the specification limit is what controls what PreEl creates
    Jun 2, 2012 4:08 PM   in reply to davidstri
    All that the ISO has done is basically ZIP the VIDEO_TS folder, with the IFO, BUP and VOB files into a "wrapper," the ISO. It is not much different than using WinZIP, or similar, to archive the material. The VOB's are still in there, just inside the ISO container.
    Now, PrE cannot generate an ISO, like Adobe Encore can. However, one could author the Project and Burn to Folder, which will create the necessary folders and files within the VIDEO_TS folder. Then, if on the PC, they can use the great, little, free ImgBurn, to create an ISO from that folder.
    An ISO is a good container to basically gather up and deliver the full DVD-Video structure, but there are a few caveats:
    • Not all computers can handle (usually called "Mounting") and ISO. Many have to download and install a program, specifically for this purpose. Some DVD software players work perfectly well with an ISO, but many do not. When yours does not, Google for "ISO mounting software."
    • Many DVD/BD players cannot process an ISO. Check with your equipment mfgr's. spec. sheet, to see if yours can.
    Creating an ISO is not really unlike ZIP'ing several folders and files, but is specifc to DVD-Video, and unlike other "archiving programs," will have the .ISO file extension, rather than .zip, .7z, .rar, etc.
    Good luck, and thank you for posting your workflow.
    Hunt
    Jun 7, 2012 7:40 AM   in reply to davidstri
    You are welcome.
    Just for my education, did DeVeDe provide the function to add Subtitles?
    The request for real Subtitles is not THAT common on the PrE forum, as most people only want Lower-Third Titles, that are burned into the Video, and are not selectable from a DVD Subtitle Menu, and possibly in several languages, i.e. real Subtitles. Adobe Encore can do real Subtitles, as well as Closed-Captions, which are similar, though with a few subtle differences, however, it is not available as a stand-alone program, and is only available with Premiere Pro. That means that it is not a solution for most people, using PrE.
    I do not even know if Sony's DVD Architect (often recommended as a full-featured authoring application here) can do real Subtitles.
    Good luck,
    Hunt
    Jun 7, 2012 4:31 PM   in reply to davidstri
    No, not at all. Knowing how other authoring programs work, is very important around here. Though the forum is hosted by Adobe, and is obviously geared toward Adobe programs, we also try to help others to realize the best from their Projects, even if it means that they need to look beyond Adobe. That is why one is likely to see references to ImgBurn, Sony DVD Architect, and others.Going back to the CS 2 days, Adobe Encore was available as a stand-alone app, and if it still was, would be the authoring app. that I would recommend most, though it was not cheap, even by the standards then. As of CS 2 Production Studio, Adobe worked with the intitial direct integration of Premiere Pro and Encore. By CS 3, that integration had progressed, and to the point that Adobe chose to not create too versions - one for stand-alone use, and one for PrPro use, so it is not only available as part of PrPro. Glad to know about DeVeDe. While Subtitles and CC are more in the domain of professional authoring apps., some folk DO need them, and do not plan on buying Sonic's Scenarist, or even the "Pro" version of Sony DVD Architect, and do not plan on buying Premiere Pro, to get Encore.
    Thank you for that information. I know that I will pass it on soon.
    Hunt
