Adobe Acrobat Pro X, Mac, and Scanning with HP Deskjet Issue!
Mar 18, 2012 4:34 PM
Tags: #acrobat #adobe #mac #hp #prox #deskjet
I am running Adobe Acrobat X Pro on Lion and when I go to scan from PDF, my HP Deskjet 3052 A scanner isn't showing up in the drop down menu.  I also have Acrobat Pro X for Windows on my machine (VMWare) and it works fine, but it won't work with the Mac version.  I have called Adobe and HP and neither have been able to help me.  I bought this program with this feature in mind, and I am sick of having to toggle back to Windows to scan, as it eats up a lot of my processing power.  I have downloaded the SANE and TWAIN drivers (or so I thought I did) with no luck.  I have also un-installed and re-installed the printer and Adobe multiple times, with no luck!  Please help me!
    Mar 19, 2012 9:33 AM   in reply to CoachCJV
    Check in the system preferences in Printer/Fax If your HP device is Combo Printer Scan you might have to change to Scanner first.
    See this: https://skitch.com/pjonescet/8mj2e/print-and-fax-32-bit
    Switch to scan first and set up as necessary. the quit or hide Printer Fax
    Now see if the scanner show up in Acrobat.
    Mar 19, 2012 2:41 PM   in reply to CoachCJV
    Did you click on the link provided in my answer. The way HP Printer scanners are setup you can use one or the other but not both at the same time.
    Switch to scan in Printer/Fax. Then go back acrobat choose PDF from Scanner.  the scanner should then show up or you can select it.  Then you can use the the scanner. To print you have to go back and switch back to the printer.
    Both don't work at the same time.
    Mar 20, 2012 7:48 AM   in reply to CoachCJV
    Okay your is setup similar to mine.
    Click on the scan Tab.
    Setup as necessary (If necessary)
    Now quit Printer/Fax (leaving it with Scan Tab activated).
    Now go to acrobat and create PDF from Scan : http://www.screencast.com/t/WGSYIjJWOEd3
    Next as shown here: http://screencast.com/t/QqDXVA6qXpXM click on button as shown and slect your scanner.
    You can now make a scan.
    Apr 6, 2012 6:37 AM   in reply to CoachCJV
    Just spoke with Adobe support yesterday (case 183132362). They say they don't support scanning on OS X 10.7. The agent said one has to scan with another program and then use Acrobat X Pro from there. It sure sounds like a bug to me. I'm going to use Image Capture and have it scan to Acrobat. I hope that deals with most of my needs.
    Apr 11, 2012 9:08 PM   in reply to Chip Nowacek
    I also was not able to get Acrobat to drive my HP printer/scanner (I have an HP Photosmart Premium). But I was able to use the HP software to drive Acrobat by using System Preferences. These are the steps I followed:
    1. Open System Preferences and click on Print & Scan.
    2. Select my Printer in the Print & Scan db, and then clicking the Scan button.
    3. Click on the "Open Scanner" button.
    4. In the dialog box for the HP printer (Photosmart Prem C310 series), click Scanner in the top right corner.
    Make sure the Details are showing.
    I set these options in the Scanner Details:
    Kind: Text
    Resolution: 300
    Scan To: Adobe Acrobat Pro.app
    Format: PDF
    Then I clicked Scan. This scanned the document and opened it automatically in Acrobat X.
    Jun 7, 2012 9:25 AM   in reply to Kevin Susco
    Hello Kevin,
    Yes Adobe Acrobate X Pro does not support HP Photosmart Plus scanning.
    I have had the same issue for months, but like you I found that I can scan a document from the Printer/Scan box in System Prefs (not ideal).
    One can also scan a document using HP Scan and then convert it using Adobe OCR recognition, this is another work-around.
    Hopefully Adobe will update their software sometime to accomodated HP users!
    P.S. How do you get it to "Scan To: Adobe Acrobat Pro.app"? My system won't let me click on the Acrobate program to select it (in applications)as it is greyed out.
    Jun 18, 2012 6:56 PM   in reply to Tim-from-coll
    This is ridiculous.  I just "upgraded" to an HP scanner from a Brother and I find myself having a more difficult time with Acrobat.  How is it possible that Adobe does not support HP scanners?  I have tried everything here and none of it seems to work.
    Jun 26, 2012 11:19 AM   in reply to Tim-from-coll
    I spent hours yesterday and all day today to find out that there is not a solution. Couldn't be more frustrated.
    Jul 7, 2012 11:55 AM   in reply to sclegalnurse
    I am having the same problem with my HP 7515.  Adobe X with iMac.  Won't recognize the scanner.
    Oct 9, 2012 11:02 AM   in reply to CoachCJV
    last update I see in this thread is from July, but since I just purchased a new HP Photosmart printer and now I can't create PDF from scanner (nothing shows up in scanner drop down) - I'm guessing this still hasn't been addressed.
    I am baffled as to how such a simple function can be released broken and remain unaddressed for so long.
    Any word from Adobe as to when this very important feature will be fixed?  Thanks
    Oct 9, 2012 11:08 AM   in reply to cmoczarski
    Adobe say it's up to HP to support their own scanners and that it's not an Adobe issue.
    Oct 9, 2012 11:16 AM   in reply to Tim-from-coll
    Wow - what incredible customer support ... loosely translated ... "screw the customer, it's the other guys problem".
    Thanks for the response Tim - I'll quit wasting my time with Adobe now.
    Oct 12, 2012 10:53 AM   in reply to CoachCJV
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c03378792&cc=uk&dl c=en&lc=en&os=219&product=3777182&sw_lang=#N469
    Depending on your printer and the type of driver update, you might need to scan in a different way than you did before you installed Mountain Lion.
    NOTE:Scanning to the computer from the printer control panel is not available when you scan with Preview, Image Capture, or Printer browser methods. You must use HP Scan software to scan from the printer.
    Oct 15, 2012 11:33 AM   in reply to CoachCJV
    It looks like you cannot scan from your HP device.  Apparently the reason is that Adobe only supports the TWAIN-compliant software for scanning, but the HP device is not TWAIN-compliant, it is ICA-Compliant.
    Pretty lame on both companies.  Neither can seem to answer the simple question of why, it took a fair amount of research.
    http://h30434.www3.hp.com/t5/Mac-Printing-and-Scanning/Scan-from-Adobe -Acrobat-Pro-to-Photosmart-7510/td-p/1666517
    Nov 27, 2012 10:11 AM   in reply to CoachCJV
    Unfortunately, Coach, seems like you will need to do the (silly) steps that I do by scanning in with Preview first, then open the particular file with Acrobat. Annoys the crap out of me! One would think it more streamlined to go 'Create' >> 'PDF from Scanner' >> Choose scanner ... from within Acrobat.
    Hmmm ....
    Nov 27, 2012 11:09 AM   in reply to Chip Nowacek
    Baloney. It depends upon the Scanner. I have c310 ePrinter/Scanner.
    The Twain Specification has been out since Apple came out with a Scanner on their own  about 1990.  And If yu will look for S.A.N.E for Macintosh.
    Install the appropriate software. Then look for the proper  Driver in the list. It's slow but it works.
    I used with a UMAX Scanner for ages using the SANE/Twain software back bac as far back as Acrobat 4.
    Jan 18, 2013 2:34 PM   in reply to CoachCJV
    So today, January 18, 2013, OSX 10.8.2 has released the newest HP Drivers, and still this problem persists. I decided to cal HP, and will save you all the long conversation, because it all comes down to this one thing: According to HP, if the printer prints, and it scans using THEIR scan utility, then the hardware works as it was intended and their is no problem. They basically said, and hung up on me when I asked for clarification, that HP designs its products to work with its software and could care less if it doesn't work with another companies software.
    The ball, as they say, is now in Adobe's court as to wheather they will attemp to please their consumers and make this work, or if we as consumers need to buy something other than HP FROM NOW ON.
    I, for one, have been scanning directly into Adobe products since 1993, and am very discouraged that I am now being prevented from doing so.
    Mac OSX 10.8.2
    HP OfficeJet 6500A Plus (which may be available at my next garage sale!)
    Jan 19, 2013 8:24 AM   in reply to nutrdoc
    It's HP not Adobe who are not cooperating on this.
    I've now changed my printer to a Brother printer, as I've given up on HP; they are not interested in Mac users.
    Brother provides the necessary Twain driver for their printer - HP doesn't and won't.
    Adobe Acrobate scanning works fine with Brother software and their inks are cheaper.
    Jan 20, 2013 3:01 PM   in reply to Tim-from-coll
    Today I purchased Acrobat XI and after spending an hour or so trying to configure the HP D110 as a scanner, finally ran onto this thread.  I'll use the HP app to scan and hope that Adobe or HP finds a solution.
    Jan 21, 2013 7:15 AM   in reply to ramnj1
    1. Okay you need to go into Print/Scan.
    2. In System Preferences and switch to scanner
    3. Quit then go to acrobat and set up printer.
Bookmarked By (2)
