What has happened to "Help" in Photoshop CS4?
Jun 7, 2012 3:27 AM
When you click on "Help" in Photoshop CS4 it no longer opens a document with explanations of the functions of Photoshop. I'm trying to import a font into Photoshop.
Roger Stowell
Branched to a new discussion.
    Jun 7, 2012 4:05 AM   in reply to rogerstowell
    What happens when you click on the "Help" , please elaborate ?
    What exactly you are looking for?
    Also what's your OS ?
    Jun 7, 2012 7:20 AM   in reply to rogerstowell
    All your issues with the help aside, you don't import fonts. You simply install them to your system font folder.
    Mylenium
    Jun 7, 2012 8:09 AM   in reply to Mylenium
    Hi rogerstowell,
    Not quite sure about what the problem is with your help, but you could download a PDF file of the Help content from
    http://help.adobe.com/archive/en_US/photoshop/cs4/photoshop_cs4_help.p df
    Preran
    Aug 7, 2012 11:33 PM   in reply to Preran
    Preran, the OP's "problem" is the same as mine, and everybody else who has, for several years now, been able to go directly into help pages from Photoshop. Apparently Adobe has turned off the online help. No reason for this, other than to make the software less useable and drive more people to upgrade to a newer version. If I'm wrong, I stand corrected...
    FHPhotog
    Aug 8, 2012 12:14 AM   in reply to BALawson
    In CS6, the online help is the default -- and you can even get rid of the Help Viewer and use your web browser (but that's a preference you'll have to change).
    But it sounds like the help for CS4 got moved somewhere, or removed in favor of newer versions. We'll have to check on that.
  • Noel Carboni
    Dec 23, 2006
    Aug 8, 2012 7:30 AM   in reply to Chris Cox
    Chris, please help me out here...  I don't ever remember seeing a Help Viewer application in Photoshop CS6...  Where's that preference you mentioned?
    -Noel
    Oct 20, 2012 2:53 PM   in reply to rogerstowell
    I am having the same issue with Photoshop/CS5!  Having been away from any Photoshop work since June, I just sat down to review how to edit text.  Boy am I pissed that I can't access the "user manual" help, which I have found to be some of the best software help out there!  The change must have happened in the last few months.
    What is EVEN WORSE is when I do click on any "text" articles found via search, they take me to a nearly BLANK screen!  The only things showing are a useless, tiny search box that doesn't work, and a survey window that pops up and says "How useful did you find this?"  UH, a nearly blank screen is NEVER useful - seriously?
    I'd love a link to CS5 Photoshop user manual so I can go back to getting exactly the information that has helped me in the past.
    BAD, BAD move, Adobe.  You software companies just can't leave well enough alone - you "broke" something that I thought was a very helpful feature.  It wasn't broke - why did you have to mess with it?
    Dec 13, 2012 6:32 PM   in reply to Chris Cox
    Chris, this was seven months ago, and nobody has checked on this yet?
    FHPhotog
