Cannot enable Mercury Playback Engine GPU Acceleration.
Just bought a Asus GeForce GTX 560 Ti just so that I can use the graphics acceleration on Adobe Premiere Pro CS5.
Followed every step in most tutorials such as this great one http://vimeo.com/13440307 and yet the Mercury Playback Engine GPU Acceleration option is still faded out.
http://www.urbanistgame.com/wp-content/uploads/2012/06/Cuda-supported. gifAdded the last two lines as wasn't sure if it required "Ti" it only came up as "supported" in the cmd after the "Ti" so I'm guess that's what it required.
You can see in bold I've set the Multi-display/mixed-GPU acceleration option to "Compatibility performance mode"
Splash screen confirms Version as 5.0.3 (update to enable Mercury Playback Engine GPU Acceleration).
After all that the "Video Rendering and Playback" option is still faded out.
Any ideas? System Information
List of installed Nvidia programs
Hope someone can help.
Jeff
Hi Faz,
Two things to try.
1. Go back into the cuda_supported_cards.txt file and make sure there is
NOT a space at the end of each line. They need to end on a character and
not a space. If there is a space, the video card entry will not be seen by
Premiere.
2. Re-Install the NVidia drivers and do a clean install. Follow the first
two steps in this article
http://www.studio1productions.com/Articles/Nvidia.htm
Please let me know how you make out.
Dave
I have the same card that you do, and it works here. So something is different with your hardware or system setup. You did a good job with the initial barrage of screenshots, but some more info is needed. A good list of required info is here:
Adobe Forums: FAQ: What information should I provide when asking a question on this forum?
Jeff
PROBLEM SOLVED.
I reinstalled CS5 on the bookdisk and it worked fine. Spent 9 hours trying everything else its really was the only thing left and the last thing I wanted to do.
Results:
Rendering a 32min clip with Gaussian Blur effect
Before CUDA it took 4 hours and hence my move to purchase a CUDA card.
After CUDA 23mins! using Encoder
Question:
I noticed that the GPU is not stressing that much still. Only running at 30% activity???
