For the past week or so, I am having problems with anything that requires Flash.
I am running Windows 7 Home, 64 bit.
I have a Toshiba Sattelite l745.
I don't know what started this problem but i have uninsalled and reinstalled Flash many times since it happened to no avail. I have even used the Adobe uninstaller many times. I have done this in Safe Mode as well as normal mode.
I can use Flash on a few games using Chrome, but when I try to use it on any other browser (IE, Firefox, Safari) it either doesn't load at all, or I get an error message.
I am at my wit's end, Please help.
Moving this discussion to the Installing Flash Player forum.
Can you try a clean install, then with IE verify the installation.
I had done the clean install several times, but followed all the instructions for that and the IE enabling page to no avail.
When I go to the Adobe test page, I don't see any box although flash is enabled.
What exactly you see in the following page? http://helpx.adobe.com/flash-player/kb/find-version-flash-player.html
Do you see an animation or is it a blank grey box?
Sunil
I see just a blank space below "can you see the movie below", not even a grey box, just a white field.
What files do you have in
Can you also post the contents of the FlashInstall.log files from both these folders?
C:\Windows\system32\Macromed\Flash
Flash64_11_2_202_235.ocx
FlashInstall
FlashUtil64_11_2_202_235_ActiveX.dll
FlashUtil64_11_2_202_235_Plugin
NPSWF64_11_2_202_235.dll
C:\Windows\syswow64\Macromed\Flash
Flash32_11_2_202_235.ocx
FlashInstall
flashplayer.xpt
FlashPlayerUpdateService
FlashUtil32_11_2_202_235_ActiveX.dll
FlashUtil32_11_2_202_235_Plugin
mms.cfg
NPSWF32_11_2_202_235.dll
=O====== M/11.2.202.235 2012-05-22+23-37-17.129 ========
0000 00000010 "C:\Users\Kiki\AppData\Local\Temp\install_flash_player_ax_64bit.exe" -iv 8 -install -iv 8 -au 0
0001
0002
0003
0004 00000020 C:\windows\SysWOW64\FlashPlayerCPLApp.cpl
0005
0006 00000013 C:\windows\system32\Macromed\Flash\Flash64_11_2_202_235.ocx
0007 00000015 C:\windows\system32\Macromed\Flash\FlashUtil64_11_2_202_235_ActiveX.exe
0008 00000016 C:\windows\system32\Macromed\Flash\FlashUtil64_11_2_202_235_ActiveX.dll
0009 00000019 C:\windows\SysWOW64\FlashPlayerCPLApp.cpl
0010 00000011 1
0011 00000012
=X====== M/11.2.202.235 2012-05-22+23-37-22.929 ========
=O====== M/11.2.202.235 2012-05-23+00-25-27.238 ========
0000 00000010 "C:\Users\Kiki\AppData\Local\Temp\install_flash_player_64bit.exe" -iv 8 -install -iv 8
0001
0002
0003 00000020 C:\windows\SysWOW64\FlashPlayerCPLApp.cpl
0004
0005
0006
0007
0008
0009
0010
0011
0012 00000014 C:\windows\system32\Macromed\Flash\NPSWF64_11_2_202_235.dll
0013 00000015 C:\windows\system32\Macromed\Flash\FlashUtil64_11_2_202_235_Plugin.exe
0014 00000019 C:\windows\SysWOW64\FlashPlayerCPLApp.cpl
0015 00000011 1
0016 00000012
=X====== M/11.2.202.235 2012-05-23+00-25-30.564 ========
=O====== M/11.2.202.235 2012-05-26+21-24-41.037 ========
0001
=X====== M/11.2.202.235 2012-05-26+21-24-41.213 ========
=O====== M/11.2.202.235 2012-05-26+21-24-52.683 ========
0001 00000020 C:\windows\SysWOW64\FlashPlayerCPLApp.cpl
0002 00000013 C:\windows\system32\Macromed\Flash\Flash64_11_2_202_235.ocx
0003 00000015 C:\windows\system32\Macromed\Flash\FlashUtil64_11_2_202_235_ActiveX.exe
0004 00000016 C:\windows\system32\Macromed\Flash\FlashUtil64_11_2_202_235_ActiveX.dll
0005 00000019 C:\windows\SysWOW64\FlashPlayerCPLApp.cpl
0006 00000011 1
0007 00000012
=X====== M/11.2.202.235 2012-05-26+21-25-00.040 ========
=O====== M/11.2.202.235 2012-05-22+23-37-19.534 ========
0000 00000010 "C:\Users\Kiki\AppData\Local\Temp\{A2A7D619-4F2E-4B43-99A0-F0A85D6BA65E}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 0
0001
0002
0003
0005
0006 00000013 C:\windows\SysWOW64\Macromed\Flash\Flash32_11_2_202_235.ocx
0007 00000015 C:\windows\SysWOW64\Macromed\Flash\FlashUtil32_11_2_202_235_ActiveX.exe
0008 00000016 C:\windows\SysWOW64\Macromed\Flash\FlashUtil32_11_2_202_235_ActiveX.dll
0010 00000021 C:\windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
0011 00000012
=X====== M/11.2.202.235 2012-05-22+23-37-21.851 ========
=O====== M/11.2.202.235 2012-05-23+00-25-28.358 ========
0000 00000010 "C:\Users\Kiki\AppData\Local\Temp\{90355E0C-B6DC-4516-B709-D5058CEC60E4}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 4294967295
0001
0002
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013 00000014 C:\windows\SysWOW64\Macromed\Flash\NPSWF32_11_2_202_235.dll
0014 00000015 C:\windows\SysWOW64\Macromed\Flash\FlashUtil32_11_2_202_235_Plugin.exe
0015 00000017 C:\windows\SysWOW64\Macromed\Flash
0016 00000019 C:\windows\SysWOW64\FlashPlayerCPLApp.cpl
0017
0018
0019 00000021 C:\windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
0020
0021
0022
0023 00000012
=X====== M/11.2.202.235 2012-05-23+00-25-30.358 ========
=O====== M/11.2.202.235 2012-05-26+21-24-56.578 ========
0000 00000010 "C:\Users\Kiki\AppData\Local\Temp\{BE9FAE2E-2612-4FE0-A485-D85481FA4AD8}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 4294967295
0002
0003 00000013 C:\windows\SysWOW64\Macromed\Flash\Flash32_11_2_202_235.ocx
0004 00000015 C:\windows\SysWOW64\Macromed\Flash\FlashUtil32_11_2_202_235_ActiveX.exe
0005 00000016 C:\windows\SysWOW64\Macromed\Flash\FlashUtil32_11_2_202_235_ActiveX.dll
0006 00000019 C:\windows\SysWOW64\FlashPlayerCPLApp.cpl
0007
0008
0009 00000021 C:\windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
0010
0011
0012
0013 00000012
=X====== M/11.2.202.235 2012-05-26+21-24-59.902 ========
I have posted the requested information and would appreciate some feedback. I am still having the problem.
Can anyone help me fix this?
When you did a clean install, did you restart Windows after running the uninstaller?
Did you check that the following files were removed during the uninstall:
I am sorry, I misunderstood what was expected.
I just did a clean install, reobooted and now the contents consist of:
FlashInstall
contents:
0001
0002
0003
0005
0010 00000011 1
0011 00000012
0001
0002
0004
0005
0006
0007
0008
0009
0010
0011
0015 00000011 1
0016 00000012
0001
0006 00000011 1
0007 00000012
=O====== M/11.2.202.233 2012-06-05+17-19-32.852 ========
0000 00000010 "C:\Users\Kiki\Downloads\uninstall_flash_player_64bit.exe" -force -force
0001
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013
0014
0015
0016
0017
0018
0019
0020
0021
0022
0023
0024
0025
0026
0027 00000011 1
=X====== M/11.2.202.233 2012-06-05+17-19-47.032 ========
FlashInstall
mms.cfg
FlashInstall contents are:
0001
0002
0003
0005
0011 00000012
0001
0002
0004
0005
0006
0007
0008
0009
0010
0011
0012
0017
0018
0020
0021
0022
0023 00000012
0002
0007
0008
0010
0011
0012
0013 00000012
=O====== M/11.2.202.233 2012-06-05+17-19-40.995 ========
0000 00000010 "C:\Users\Kiki\AppData\Local\Temp\{0A36663F-3626-47D9-BD6F-A5A2C9B836C0}\InstallFlashPlayer.exe" -force -uninstall
0001
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013
0014
0015
0016
0017
0018
0019
0020
0021
0022
0023
0024
0025
0026
0027
0028
0029
0030
0031
=X====== M/11.2.202.233 2012-06-05+17-19-43.148 ========
I am sorry for the confusion.
Could you try the steps listed in this FAQ?
There is no change, it still doesn't work.
I appreciate your continued assistance.
ck626@hotmail.com wrote:
I just did a clean install...
Did you follow the instructions for a clean install in Chris' reply #2?
I don't think so, you posted your "clean install" comment above on June 6, yet the FlashInstall.log file still shows entries from May 22. You cannot possibly have performed a clean install according Chris' instructions.
...or I get an error message.
And what is that error message?
The error message I get when trying to play a specific game is, "Failed to load Slotomania, OOps, loading failed due to system overload. Please try again later.
I always get this no matter which browser I use.
