Learning tape on ColdFusion Builder shows an extension to auto-generate CFC components for access to database tables.
I can't find that function in ColdFusion Builder 2. Is it still available? These are the extensions i have installed:
This is what i see when i right click on a database table:
Thanks very much!
Steve
I found a solution!
Go here: http://adobecfcgenerator.riaforge.org/
Download the zip file
Go into CFBuilder
Go to the Extensions tab at the bottom (same row the Servers are in)
Click the + button (hover text should be "Install Extension from Archive File")
browse to the zip file, click open, and tada! You have the CFC Creator.
Hope this helps!
I am having the same problem. Are you using the tutorail from Lynda.com?
Yes, the lynda.com tutorial.
I found a solution!
Go into CFBuilder
Hope this helps!
Tanny... - Thank you so much - worked perfectly!
When I created a server configuration, it added these files to the docroot already but the option wasn't availble. When I tried to follow these instructions I got an "already installed" message.
What worked for me was to click on the second electrical plug - "Import extension from folder" button and browse to the dsired extension.
