Is it possible to trigger a script when a file is opened.
Jun 6, 2012 9:43 AM
Tags: #script #javascript
I have a simple script that I need to run when a file is opened in illustrator(cs5) on windows 7. I tried adding the script to the "startup scripts" folder but that only executes when a new instance of illustrator is started. If illustrator is already open and I go to "file/open", the script doesn't run. Any suggestions?
Many thanks,
CRS
    Jun 6, 2012 10:09 AM   in reply to raystoney
    Sorry there are NO events classes in AI… You could add it to the feature requests…
    Jun 6, 2012 11:22 AM   in reply to raystoney
    It might be possible from outside the app using AppleScript or VB to watch AI… ( might even be possible with the BridgeTalk class ). I haven't tried this… I wouldn't like that approach…
    Jun 8, 2012 2:18 AM   in reply to Muppet Mark
    It is somehow possible but maybe not using js. For example, there is a script/plugin to check if white objects have overprint turned on - available on http://www.worker72a.com/72a_Pages/CS3_Plug-ins.htm#WOPD . It would be intresting to know how it is made.
    Jun 8, 2012 9:04 AM   in reply to postworek111
    Plug-in's are different story altogether… and better discussed in the sdk forum…
