I am writing my final thesis, (more than 100 pages) and indesign crashed this moring while writing. Now the file can't open anyware anymore. I am using CS6 trial version, and even on other mac and pc it will not open anymore.
How can I get my file back? Please help me..
Thanks a lot!
It's usually a bad sign when the file will no longer open even on another computer. Do you get any error messages?
Find, and empty, the InDesign Recovery folder in your user library to keep ID from crashing over and over when it tries to open the bad recovery data. (The recovery folder is in the same folder where the InDesign SavedData file is stored, and the path information for your OS can be found in Replace Your Preferences Note that this folder is gong to be a hidden folder if you run Lion, so you need to display hidden folders in your search).
Once that is done, start InDesign and use FIle > Open... to navigate to the original location where the file is saved. Tick the radio button to "Open as a COPY" and cross your fingers. If you are REALLLLLLY lucky it will open, and if it does, IMMEDIATELY export to .idml, then save the file with a new name as a backup, too. File > Open... and open the .idml file you just made, Save As to yet another name and you should be good to go.
If it doesn't open, do you have any backup copies someplace? If not, you best hope is probably Markzware: Bad InDesign or Quark File Recovery Submission Form
Now some advice on preventing this from happening again (though a crash is outside your control). First, never work directly off a removeable drive, if that's your habit. Copy the file to the hard drive, edit, then copy back to the removeable drive. Do a Save As from time to time to clear out the old, useless and inaccessible change data from previous sessions and reduce the file size. Make backup copies every day. If you do the save as each time you are done working, and add a versioning sequence to the name or something similar you take care of two birds with one stone.
Thank you for your answer. I have tried to clear the temp files and open as copy. It opens but as soon as I move my mouse it crashes again.
I did make a idml file, and saves it under multiple .ai files (different versions) but nothing opens anymore.
The IML says it is missing plug-ins or is open at a different location. And all the other files crash right away. No error message just a crash.
I can show the apple error message if that is any help?
.ai files? I thought we were talking about InDesign here.
Every time the program crashes it leaves behind the recovery data. If that data is damaged you will go into a cycle of continuous crashing every time you retstart InDesign, so you need to keep emptying the recovery folder.
The error message would help a lot, as would posting the crash report on Pastebin.com and putting a link to it here.
And I'm going to send you an upload link for the .idml and .indd files to see if I can open either one here, if you like.
I have the files. The .idml file seems to be damaged in some way -- won't open as .idml and I get an invaled archive message when changing the extension to .zip (John, are you watching this? Want to see it?)
The .indd file seems to be hung, but I'll wait a bit longer before declaring failure as the program is not crashed.
In the meantime, try making another .idml file, if you can get the program to stay open. It may take awhile to finish the export so walk away from the computer for 10 minutes after you've started teh process.
And is there a chance you can post that crash report?
I cant keep the program open at all, the file crashes as soon as I move my cursor. It seems that indesign is making all my files corrupt?
The Apple crash report is here: http://pastebin.com/download.php?i=4MgUsLUL
Well, the crash report isn't very helpful. Just seems to indicate some sort of text problem (no big surprise).
I'm on windows, where keyboard navigation is easy, but I think there is a way to run menus on the Mac, too, without touching the mouse. You might give that a try.
And you file is still hung after 20 minutes, so I think it's not going to open at all, but I had one take about an hour last year. It had dozens of pasted vector objects in it -- you don't have anything like that in your file, do you?
I've converted the older file to CS5 for you. When I was opening the .idml I got this warning:
But the file opened OK. I think this relates to something on pages 52 and 53 which are complex vectors and are NOT linked, and that may well be the source of the problem with the later version. I would advise that when you get the converted file you copy these graphics into Illustrator, save them as .ai files and place those as links replacing what's there.
