SG12345
HTML Object Not Loading (PS CS5, 5.1)
Jun 8, 2012 11:57 AM
Tags: #photoshop #html #object #panel #configurator #configurator_3
I've created a very simple Configurator panel for Photoshop CS5 that is nothing more than two items in a tabbed navigator with an HTML widget in each.
The Panel Preview shows the HTML content loading perfectly fine, but when I open the panel in Photoshop, everything but the HTML content shows up.
The HTML content that I'm trying to load is hosted on a local server, but just to rule that out as a problem, I created a tab with an HTML object pointing to Adobe.com, but still nothing.
Any help in resolving this would be greatly appreciated.
Scott.
    Jun 11, 2012 7:06 PM   in reply to SG12345
    Could you please sent your design panel ".gpc" file and the corresponding ".assets" folder to xguo@adobe.com ?
    Let's try and investigate this problem.
    Xiaoyan
    Jun 14, 2012 6:52 PM   in reply to guoxy
    After checking the gpc file, the root cause if a panel contians "&" in the name, then the content of HTML widget can't be shown in Photoshop CS5.
    As for Photoshop CS6, if the panel name contains "&", then the panel is shown with an incorrect size.
    Please don't use "&" to avoid this problem.
    3x
    Xiaoyan
