Photoshop CS6 hangs when using the brush (Mac OS X Lion)
Jun 7, 2012 2:10 PM
Tags: none (add) #cs6 #mac_hangs #brushes_hangsHi folks,
This is my first posting here so I hope I'm doing it right. I upgraded to Photoshop CS6 a couple of days ago (jumped the Creative Cloud offer for existing customers) and ever since I've experienced several "hangs" when using the brush tool. In general I can work a few minutes with the brush before I notice that it isn't responding anymore, ie. it doesn't paint or erase or whatever it is I'm using it for. When this happens I can't access the gui anymore and all I have for cursor is the shape of the brush. After that the cursor will turn into that black and white spinning ring of dots and my only way to exit Photoshop is to force quit it.
This happens almost every time I use the brush. The OS X Lion installation is brand new, as is the Photoshop installation. No third party plugins installed (haven't had the time yet) and no third party fonts. I use a Wacom Intous 4 with latest drivers.
I've recorded a short video of what happens (13MB): https://dl.dropbox.com/u/2055280/Photoshop%20CS6%20hangs.mov
This is me working on a texture for a 3D model. I have a couple of layers and when the recording starts I am using a mask to blend two layers.
- At around 00:40 the brush stops working so I try to change tool by keyboard shortcut and then by clicking the tool palette.
- At around 01:05 the spinning ring appears and by then I know that I have to force quit.
- At around 01:50 I open up the Activity Monitor (although it can be tricky to read as the Photoshop document refuses to go to the background when the spinning ring appears)
- At around 02:24 the brush starts working again but I still have the spinning ring and I still can't access anything in the menus or palettes.
I *think* it is related to the amount of time I spend on a single brush session but I'm not sure. What I mean is that if I start brushing away and simply pause once in a while or lift the pen off the board to start a new stroke it feels like the behaviour is less likely to appear. If I however use the brush for a longer period of time without lifting it or pausing, the spinning ring will most definitely appear. It's like Photoshop buffers all my brush movements and then somehow chokes. I could get the spinning beach ball in earlier versions as well but once Photoshop so to say had catched up I could continue working. Now it chokes and I have to force quit. This is just a theory from side, I need to test it more.
I'm attaching a copy of the System info below as well.
Any ideas on what might be causing this behaviour is appreciated.
/Anders
Adobe Photoshop Version: 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00) x64
Operating System: Mac OS 10.7.4
System architecture: Intel CPU Family:6, Model:26, Stepping:5 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, HyperThreading
Physical processor count: 8
Logical processor count: 16
Processor speed: 2260 MHz
Built-in memory: 12288 MB
Free memory: 7630 MB
Memory available to Photoshop: 11198 MB
Memory used by Photoshop: 70 %
Image tile size: 1024K
Image cache levels: 4
OpenGL Drawing: Enabled.
OpenGL Drawing Mode: Advanced
OpenGL Allow Normal Mode: True.
OpenGL Allow Advanced Mode: True.
OpenGL Allow Old GPUs: Not Detected.
OpenGL Version: 2.1 ATI-7.18.18
OpenCL Version:
Video Card Vendor: ATI Technologies Inc.
Video Card Renderer: ATI Radeon HD 5770 OpenGL Engine
Display: 2
Display Depth:= 32
Display Bounds:= top: 0, left: 1920, bottom: 1200, right: 3840
Video Renderer ID: 16915202
Video Card Memory: 1256 MB
Video Rect Texture Size: 16384
OpenCL Version: 1.1 (Apr 9 2012 19:41:45)
Display: 1
Main Display
Display Depth:= 32
Display Bounds:= top: 0, left: 0, bottom: 1200, right: 1920
Serial number: 90970847541468733918
Application folder: Macintosh HD:Applications:Adobe Photoshop CS6:
Photoshop scratch has async I/O enabled
Scratch volume(s):
Samsung, 1.18T, 440.2G free
Macintosh HD, 222.8G, 134.9G free
Working Files, 223.3G, 138.9G free
Required Plug-ins folder: Macintosh HD:Applications:Adobe Photoshop CS6:Adobe Photoshop CS6.app:Contents:Required:
Primary Plug-ins folder: Macintosh HD:Applications:Adobe Photoshop CS6:Plug-ins:
Additional Plug-ins folder: not set
Installed components:
adbeape.framework adbeape 3.3.8.19346 66.1025012
AdbeScriptUIFlex.framework AdbeScriptUIFlex 6.2.29.18602 66.490082
adobe_caps.framework adobe_caps 6.0.29.0 1.276181
AdobeACE.framework AdobeACE 2.19.18.19243 66.492997
AdobeAGM.framework AdobeAGM 4.26.17.19243 66.492997
AdobeAXE8SharedExpat.framework AdobeAXE8SharedExpat 3.7.101.18636 66.26830
AdobeAXEDOMCore.framework AdobeAXEDOMCore 3.7.101.18636 66.26830
AdobeBIB.framework AdobeBIB 1.2.02.19243 66.492997
AdobeBIBUtils.framework AdobeBIBUtils 1.1.01 66.492997
AdobeCoolType.framework AdobeCoolType 5.10.31.19243 66.492997
AdobeCrashReporter.framework AdobeCrashReporter 6.0.20120201
AdobeExtendScript.framework AdobeExtendScript 4.2.12.18602 66.490082
AdobeJP2K.framework AdobeJP2K 2.0.0.18562 66.236923
AdobeLinguistic.framework 17206
AdobeMPS.framework AdobeMPS 5.8.0.19463 66.495174
AdobeOwl.framework AdobeOwl 4.0.93 66.496052
AdobePDFL.framework AdobePDFL 10.0.1.18562 66.419471
AdobePDFSettings.framework AdobePDFSettings 1.4
AdobePIP.framework AdobePIP 6.0.0.1654
AdobeScCore.framework AdobeScCore 4.2.12.18602 66.490082
AdobeUpdater.framework AdobeUpdater 6.0.0.1452 "52.338651"
AdobeXMP.framework AdobeXMPCore 66.145661 66.145661
AdobeXMPFiles.framework AdobeXMPFiles 66.145661 66.145661
AdobeXMPScript.framework AdobeXMPScript 66.145661 66.145661
ahclient.framework ahclient 1.7.0.56
aif_core.framework AdobeAIF 3.0.00 62.490293
aif_ocl.framework AdobeAIF 3.0.00 62.490293
aif_ogl.framework AdobeAIF 3.0.00 62.490293
AlignmentLib.framework xcode 1.0.0.1
amtlib.framework amtlib 6.0.0.75
boost_date_time.framework boost_date_time 6.0.0.0
boost_signals.framework boost_signals 6.0.0.0
boost_system.framework boost_system 6.0.0.0
boost_threads.framework boost_threads 6.0.0.0
Cg.framework NVIDIA Cg
CIT.framework CIT 2.0.5.19287 145486
data_flow.framework AdobeAIF 3.0.00 62.490293
dvaaudiodevice.framework dvaaudiodevice 6.0.0.0
dvacore.framework dvacore 6.0.0.0
dvamarshal.framework dvamarshal 6.0.0.0
dvamediatypes.framework dvamediatypes 6.0.0.0
dvaplayer.framework dvaplayer 6.0.0.0
dvatransport.framework dvatransport 6.0.0.0
dvaunittesting.framework dvaunittesting 6.0.0.0
dynamiclink.framework dynamiclink 6.0.0.0
FileInfo.framework FileInfo 66.145433 66.145433
filter_graph.framework AdobeAIF 3.0.00 62.490293
hydra_filters.framework AdobeAIF 3.0.00 62.490293
ICUConverter.framework ICUConverter 3.61 "gtlib_3.0" "." "16615"
ICUData.framework ICUData 3.61 "gtlib_3.0" "." "16615"
image_compiler.framework AdobeAIF 3.0.00 62.490293
image_flow.framework AdobeAIF 3.0.00 62.490293
image_runtime.framework AdobeAIF 3.0.00 62.490293
LogSession.framework LogSession 2.1.2.1652
mediacoreif.framework mediacoreif 6.0.0.0
PlugPlug.framework PlugPlug 3.0.0.383
UpdaterNotifications.framework UpdaterNotifications 6.0.0.24 "6.0.0.24"
wrservices.framework
Required plug-ins:
3D Studio 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
Accented Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Adaptive Wide Angle 13.0, Copyright © 2012 Adobe Systems Incorporated - from the file “Adaptive Wide Angle.plugin”
ADM 3.10x16, Copyright © 1987-2008 Adobe Systems Inc. All rights reserved. - from the file “AdobeADM.bundle”
Angled Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Average 13.0 20120315.r.428 2012/03/15:21:00:00 ©1993-2012 Adobe Systems Incorporated - from the file “Average.plugin”
Bas Relief 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
BMP 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Camera Raw 7.1 (354), Copyright © 2012 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
Chalk & Charcoal 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Chrome 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Cineon 13.0 20120315.r.428 2012/03/15:21:00:00 ©2002-2012 Adobe Systems Incorporated - from the file “Cineon.plugin”
Clouds 13.0 20120315.r.428 2012/03/15:21:00:00 ©1993-2012 Adobe Systems Incorporated - from the file “Clouds.plugin”
Collada DAE 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
Color Halftone 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Colored Pencil 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
CompuServe GIF 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Conté Crayon 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Craquelure 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Crop and Straighten Photos 13.0 20120315.r.428 2012/03/15:21:00:00 ©2003-2012 Adobe Systems Incorporated - from the file “CropPhotosAuto.plugin”
Crop and Straighten Photos Filter 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Crosshatch 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Crystallize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Cutout 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Dark Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
De-Interlace 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Dicom 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “dicom.plugin”
Difference Clouds 13.0 20120315.r.428 2012/03/15:21:00:00 ©1993-2012 Adobe Systems Incorporated - from the file “Clouds.plugin”
Diffuse Glow 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Displace 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Dry Brush 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Eazel Acquire 13.0 20120315.r.428 2012/03/15:21:00:00 ©1997-2012 Adobe Systems Incorporated - from the file “EazelAcquire.plugin”
Embed Watermark NO VERSION - from the file “DigiSign.plugin”
Enable Async I/O 13.0 20120315.r.428 2012/03/15:21:00:00 © 2004-2012 Adobe Systems Incorporated - from the file “Enable Async IO.plugin”
Entropy 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
Extrude 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
FastCore Routines 13.0 20120315.r.428 2012/03/15:21:00:00 ©1990-2012 Adobe Systems Incorporated - from the file “FastCore.plugin”
Fibers 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Film Grain 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Filter Gallery 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Flash 3D 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
Fresco 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Glass 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Glowing Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Google Earth 4 KMZ 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
Graphic Pen 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Halftone Pattern 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
HDRMergeUI 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “HDRMergeUI.plugin”
IFF Format 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Ink Outlines 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
JPEG 2000 13.0 20120315.r.428 2012/03/15:21:00:00 ©2001-2012 Adobe Systems Incorporated - from the file “JPEG2000.plugin”
Kurtosis 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
Lens Blur 13.0, Copyright © 2002-2012 Adobe Systems Incorporated - from the file “Lens Blur.plugin”
Lens Correction 13.0, Copyright © 2002-2012 Adobe Systems Incorporated - from the file “Lens Correct.plugin”
Lens Flare 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Liquify 13.0, Copyright © 2001-2012 Adobe Systems Incorporated - from the file “Liquify.plugin”
Matlab Operation 13.0 20120315.r.428 2012/03/15:21:00:00 ©1993-2012 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
Maximum 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
Mean 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
Measurement Core 13.0 20120315.r.428 2012/03/15:21:00:00 ©1993-2012 Adobe Systems Incorporated - from the file “MeasurementCore.plugin”
Median 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
Mezzotint 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Minimum 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
MMXCore Routines 13.0 20120315.r.428 2012/03/15:21:00:00 ©1990-2012 Adobe Systems Incorporated - from the file “MMXCore.plugin”
Mosaic Tiles 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Multiprocessor Support 13.0 20120315.r.428 2012/03/15:21:00:00 ©1990-2012 Adobe Systems Incorporated - from the file “MultiProcessor Support.plugin”
Neon Glow 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Note Paper 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
NTSC Colors 13.0 20120315.r.428 2012/03/15:21:00:00 ©1993-2012 Adobe Systems Incorporated - from the file “NTSC Colors.plugin”
Ocean Ripple 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Oil Paint 13.0, Copyright © 2011 Adobe Systems Incorporated - from the file “Oil Paint.plugin”
OpenEXR 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Paint Daubs 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Palette Knife 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Patchwork 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Paths to Illustrator 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
PCX 13.0 20120315.r.428 2012/03/15:21:00:00 ©1989-2012 Adobe Systems Incorporated - from the file “PCX.plugin”
Photocopy 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Photoshop 3D Engine 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “Photoshop3DEngine.plugin”
Picture Package Filter 13.0 20120315.r.428 2012/03/15:21:00:00 ©1993-2012 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
Pinch 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Pixar 13.0 20120315.r.428 2012/03/15:21:00:00 ©1989-2012 Adobe Systems Incorporated - from the file “Pixar.plugin”
Plaster 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Plastic Wrap 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
PNG 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Pointillize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Polar Coordinates 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Portable Bit Map 13.0 20120315.r.428 2012/03/15:21:00:00 ©1989-2012 Adobe Systems Incorporated - from the file “PBM.plugin”
Poster Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Radial Blur 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Radiance 13.0 20120315.r.428 2012/03/15:21:00:00 ©2003-2012 Adobe Systems Incorporated - from the file “Radiance.plugin”
Range 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
Read Watermark NO VERSION - from the file “DigiRead.plugin”
Reticulation 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Ripple 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Rough Pastels 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Save for Web 13.0, Copyright © 1999-2012 Adobe Systems Incorporated - from the file “Save for Web.plugin”
ScriptingSupport 13.0, Copyright © 2012 Adobe Systems Incorporated - from the file “ScriptingSupport.plugin”
Shear 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Skewness 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
Smart Blur 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Smudge Stick 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Solarize 13.0 20120315.r.428 2012/03/15:21:00:00 ©1993-2012 Adobe Systems Incorporated - from the file “Solarize.plugin”
Spatter 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Spherize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Sponge 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Sprayed Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Stained Glass 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Stamp 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Standard Deviation 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
Sumi-e 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Summation 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
Targa 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Texturizer 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Tiles 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Torn Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Twirl 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
U3D 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
Underpainting 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Vanishing Point 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “VanishingPoint.plugin”
Variance 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
Water Paper 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Watercolor 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Wave 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Wavefront|OBJ 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
Wind 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Wireless Bitmap 13.0 20120315.r.428 2012/03/15:21:00:00 ©1989-2012 Adobe Systems Incorporated - from the file “WBMP.plugin”
ZigZag 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Optional and third party plug-ins: NONE
Plug-ins that failed to load: NONE
Flash: NONE
Installed TWAIN devices: NONE
