Populate a drop-down with over 500 items
Apr 16, 2010 10:11 PM
Just for some background, I am designing a form to be emailed and filled out by the recepient using LiveCycle Designer 8,0.  In this form, I want to create a list of all cities in my state (over 550).  Apparently, there is no way to directly populate the drop-down other than typing each city individually.  However, I have searched the forums and found that there is possibly a script that can be created to accomplish this.  The problem is that I have practically NO  knowledge about writing code.  There is a tool I have in my Programs menu called "Extendscript" but I don't even know if I can use it for this purpose (nor would I know how if it could be used).  By now it is obvious that I am a very "basic" user, but any help on this would be appreciated.
Daryl
    Apr 18, 2010 3:58 AM   in reply to DarylGS
    No need to type all the cities once again.
    If you have the list of cities in a text or excel document, you can simply copy them and past in the drop-down list field.
    Is this what you need?
    Nith
    Apr 18, 2010 4:01 AM   in reply to $Nith$
    Copy paste from Excel/text document will not work with earlier versions of designer.
    Another approach is to modify the xml source.
    Something looks weired? Send me the list of cities. I will prepare a simple pdf from where you can copy the drop-down field to your form.
    Nith
    Apr 18, 2010 5:18 AM   in reply to DarylGS
    neither will work.
    so pls send ur RTF document to my email directly at  nith.mof@gmail.com
    Nith
    Apr 19, 2010 9:03 PM   in reply to DarylGS
    You are welcome!
    If you are using LiveCycle Designer 9, it is pretty simple to copy these values from clipboard to dropdown list items.
    Nith
    Apr 19, 2010 9:42 PM   in reply to DarylGS
    The internal help system available within Designer is enough to learn the basics.
    However the following PDF will help you to understand the complete javascript APIs..
    http://groups.google.com/group/livecycle/web/Acrobat%20JavaScript%20Sc ripting.pdf
    Nith
    Apr 20, 2010 1:22 AM   in reply to $Nith$
    Hi Nith,
    I've just read this forum post and I am having exactly the same problem tring to populate a drop downlist! Would you be able to help at all please? I have a list of over 100 items in excel / notedpad (see below for examples) where users completing a form will only select 1 of these items. I cannot seem to find an easy way to do this despite several attempts at trying. I thought I could copy and paste the list into the xml source (enclosed in text  tags but this does not seem to work and comes up with an error message. I'm new to livecycle as well so this does not help eiether!
    I'm using Livecycle designer ES 8.2 that comes with Acrobat Pro 9. Any help would be greatly appreciated.
    Example Items-
    A    Medicine and Dentistry
    A100    Pre-clinical Medicine
    A200    Pre-clinical Dentistry
    A300    Clinical Medicine
    A400    Clinical Dentistry
    A900    Others in Medicine and Dentistry
    A990    Medicine and Dentistry not elsewhere classified
    B    Subjects allied to Medicine
    B100    "Anatomy, Physiology and Pathology"
    B110    Anatomy
    B120    Physiology
    B130    Pathology
    B131    Cellular Pathology
    B132    Pathobiology
    B140    Neuroscience
    B160    Physiotherapy
    B190    "Anatomy, Physiology and Pathology not elsewhere classified"
    B200    "Pharmacology, Toxicology and Pharmacy"
    Ken
    Apr 20, 2010 7:31 AM   in reply to kenneth83
    Send your data file to nith.mof@gmail.com
    Nith
    Feb 23, 2012 3:33 AM   in reply to $Nith$
    Hi Nith,
    I have designed a pdf form basically a CV format to be filled by the users while applying for job, in that form i have used many form controls namely checkbox, listbox, radio-buttons, drop-downs and so on.. My problem is that whenever i want to add a new location or update drop-down i have to do it at multiple places. For example i have a drop down for Nationality or Country that is repeated through out the form (independent of each other), is there a way to update the dropdown list values in one place and not have to edit each field specifically?
    In other words is it possible to have the form pull "lookup" data from one source? meaning if i update the nationality drop-down at one place then it should reflect the changes at all the other places where am using the nationality drop-down.
    Can anyone help me out in this please.....
    Sourabh
    Jun 7, 2012 11:37 PM   in reply to $Nith$
    Hi Nith
    As you told using LiveCycle Designer 9, it is simple to copy the values from clipboard to dropdown list items. Pls post the steps involved that would help me to proceed.
    Balaji
    Jun 8, 2012 8:10 PM   in reply to balaji gurumurthy
    which steps Balaji? Copy paste in LC Designer 9 or earlier version updates in xml source?
