I draw square. The 1st point and last points are left-top and finally set 5 points.
The direction is clock-wise and made closed path.
To get smooth-curved polygon shape, I used API 'PointsToCurves'.
But, the first and last points are connected by cornered (not smooth) point.
Here's result.
Maybe, I must set that square is closed path, to API, but it seems to be no parameter to set.
So, I want to know how to get smooth corner shape every corner.
I use SDK CS5.
Best regards.
Thanks for giving me surgestions.
It seems for 'PointsToCurves', there's no way to make specify that pass is closed.
And, I tried to set 'corner' parameter (member of 'segments').
Points are 4, so the shape was opened pass.
First, I set false (i.e. smooth) to the first and last points, the result was same as before.
2ndly, I set true (i.e. corner) to the first and last points, the result was same.
Best regards.
