cris1506
valueObjects memory - How can destroy when unload module
Jun 1, 2012 9:20 AM
Tags: #memory #valueobjects
The problem is when the app load and unload the same module, the data from callresponder is add to class R5objects. The ask is how can drop, delete, destroy,clean,..... this objects from memory when i unload the module. I try with System.gc () but i don't see change in memory.
If i load and unload the same module many times the application take a lot of memory, the query to database take 500 rows and 10 fields
    Jun 1, 2012 1:12 PM   in reply to cris1506
    I don’t know what R5objects is, but you should have it support some way of cleaning up.
    Jun 1, 2012 8:49 PM   in reply to cris1506
    Once the valueObjects are no longer referenced, the will not pin the callResponder data in memory,.  Why are valueObjects still being referenced?
    -Alex
    Jun 3, 2012 11:45 PM   in reply to cris1506
    Use the profiler to see what is holding onto the valueObjects.
    Jun 9, 2012 8:28 AM   in reply to cris1506
    I am facing the same problem.
    Did you find a solution?
    Jun 13, 2012 4:03 PM   in reply to gfbaggio9
    You may need to call disconnect() on the RemoteObject and null it out, or its loaded data may stick around longer than desired.
