Module Template Edits don't show up
Jun 9, 2012 9:17 PM
Tags: #menu_templates
I'm creating a dynamic menu in a Bootstrap site eastwindinsurance.com
I'm dropping the module into the Bootstrap Menu structure that looks like this:
<nav class="navbar navbar-fixed-top">
          <div class="navbar-inner">
                    <div class="container"> <a class="btn btn-navbar" data-toggle="collapse" data-target=".nav-collapse"> <span class="icon-bar"></span> <span class="icon-bar"></span> <span class="icon-bar"></span> </a> <a class="brand" href="../index.htm">FIexAssist</a>
                              <div class="nav-collapse">
                                        <ul class="nav">
                                                  <li class="active"><a href="/flexassist.htm">Home</a></li>
                                                  <li><a href="/benefits.htm">Insurance Benefits</a></li>
                                                  <li><a href="/assistance.htm">Life Assistance</a></li>
                                                  <li><a href="/claims.htm">Claims</a></li>
                                                  <li><a href="../premiums.htm">Premiums</a></li>
                                                  <li><a href="../faq.htm">FAQ</a></li>
                                        </ul>
                              </div>
                              <!--/.nav-collapse -->
                    </div>
          </div>
</nav>
And I drop it in like this:
{module_menu,564015}
  </div>
  </div>
</nav>
Because the generated Module Code looks like this:
<div id="cat_1118133_divs">
    <ul id="nav_1118133">
        <li><a href="/one.html">item one</a></li>
        <li><a href="/two.html">item two</a></li>
        <li><a href="/three.html">item three</a></li>
     </ul>
</div>
I've given the div a class of "nav-collapse" and the ul a class of "nav" in the container and group Menu templates respectively.
The problem is that for whatever reason the changes to the template code are not passed. i just get the default template passing.
What's up?
Cam
  • Liam Dilley
    Feb 28, 2012
    Jun 9, 2012 10:50 PM   in reply to Cam Reesor
    Hey Cam, do you mean you are using the menu module layouts? If so you need to use the v2 module tag code, that's just the default module tag you have there.
  • Liam Dilley
    Feb 28, 2012
    Jun 10, 2012 3:50 PM   in reply to Cam Reesor
    Nope. No reason to change that though.
    Takes 30 seconds to find and replace in your css to use .selected instead of .active
