I am unable to download anything else. My choices do not include a 64 bit version.
On Mac it is difficult to tell from the directory structure whether you are running a 32-bit or 64-bit version of an application although there is a utility which reveals this information.
However on Windows it is as simple as looking in Program Files.
On 32-bit machines you will ONLY see "Program Files" in the C: directory if you installed your adobe applications to the default location
On 64-bit machines you will see "Program Files" AND "Program Files (x86)". The latter is where all of your 32-bit applications are installed by default unless you choose a custom location which is possible for some but not all computer applications. With Adobe CS applications you CAN choose a specific target location or even a different drive partition to install your applications.
Hi Joe,
Premiere Pro and After Effects CS 6 are only 64 bit applications.
They don't have any non 64 bit version .
On a 64 bit machine, you will only see Premiere Pro CS 6 and after Efects CS 6, they will not say 64 bit because its obviuos that these are only 64 bit apps.
If we talk about PS CS 6 and Illustrator CS 6, these are the two apps which have both 32 bit and 64 bit versions, when installed on 64 bit machine.
Baljeet
Can I ask then about this having both 32 and 64 bit versions, has anyone noticed any conflicts from running either one?
I have a 64 bit machine and first the 32 bit version installed then the 64 after I ran an update from within Photoshop.
Is there any need to worry about running one vs the other? They are both compatible using friles with other programs etc?
Dan
