Hi all,
I'm experiencing some wierd display tearing issues in After Effects CS 6.
Anything which moves moderately quickly in the composition window during playback or interaction experiences severe horizontal image tearing.
Video playback is tearing, regardless of resolution size (full, quarter, etc.). The display tears EVEN when I am simply dragging stuff around. I could be holding down space and dragging the canvas around in my composition window, or just dragging a footage element and I'll see a ton of really severe, jagged tearing.
It definitely looks like a monitor refresh rate issue, but I've never experienced anything like it before on this system.
Turning off hardware acceleration for composition, layer and footage has not helped. I have also restarted numerous times after changing this setting.
I am running a MacPro 2.66 GHz Quad-Core, OS X 10.7.3
16 gb ram
Card: ATI Radeon HD 4870 512 MB
My graphics card is admitedly not a supported card, but it has always worked fine in CS 5.5, and I would imagine that it would simply be ignored when I have turned off hardware acceleration, and it is not supported to begin with. I have had NO issues in any other version of AE, or in any other applications including FCP, Photoshop, etc.
I have two monitors on this machine, both standard computer displays and not broadcast, blackmagic, firewire or anything like that. One is an Apple monitor, and the other Samsung. One is connected via mini-display port adaptor.
This issue occurs on either monitor.
Any advice? Thanks so much!
Yeah... I've been having zero luck finding a driver update.
Any Adobe employees around with an idea of what might be going on?
I'm planning to buy a new graphics card anyways, and tests on a friend's system who has a flashed GTX 470 from MacVidCards seem to show that it works perfectly as long as I use the text hack to add it to the list of supported cards. Seeing as it is a supported card under Windows, I feel like I shouldn't be too worried about that...
This was the first thing I noticed on my MacBook Pro laptop. It's a 17" with 8Gb of Ram. I did a small project in AE CS5 nothing fancy but playback was perfect. The exact same project produces the video tearing, not hugely but definately distracting enough to notice. The whole point of RAM preview is to see what you are going to get and if that gives you glitches it's not ideal
I'm experiencing exactly the same issue here. This happens both on the iMac 27" i5 HD4850 at work and on my C2Q 8200 nVidia 550TI at home, in both Win7 and Lion hackintosh. Two completely unrelated computers, which makes this tearing thing very weird indeed. AE5.5 worked just fine in both machines, no tearing at all.
Please help us Adobe.
That is not a good sign. Up until now I had heard that it was only on Macs. This is a big issue. I depend on After Effects on a daily bases for my lively hood and this tearing issue has made it almost un-useable on several projects where there is so much complexity this tearing distracts greatly. I will continue to use CS5 until Adobe finally acknowledges their preview playback problems and addresses them.
This problem has still yet to be addressed! I really want to use AE CS6 but it's much to distracting of an issue.
I made a test project and sent it to several designer friends on two totally different systems and they had the horizontal tearing as well. They hadn't noticed it tell I pointed it out. Soo now I'm thinking it's on everyone's setup and just some people don't notice such things.
I just posted to the other thread abou this, but the problem also happens with a brand new nvidia Quadro 4000 on the same mac.
We cannot be the only ones experiencing this.
Have you tried calling in about it yet?
I'm going to do that soon, but I'm not relishing the idea of hours on the phone going through basic troubleshooting steps which is what I fear will happen.
I wish some of the Adobe employees on this board would chime in. Even just a word or two to tell us if Adobe is aware of the issue would be nice.
Sadly no. It's with any preview of any content within a ram preview in AE CS6. Here are a few sample images of a simple Solid layer moving across the screen. It's just in the preview never in the final render output. But it's all through all of my projects...so distracting I'm just sticking with CS5 for now.
Hey Kevin,
Please see my reply in the other thread -- unfortunately the issue occurs without any kind of media involved at all.
Thats super interesting Kevin. Initially when I started researching this issue it looked like it was a Mac centric problem. But then I found a few mentions with some google searching of it happening on a Windows machine. With the lameness of the current Mac Pro landscape, and me in desperate need of a new workstation, I may be jumping to a PC workstation. Would be awesome if it wasn't an issue there. I'm dying to use AE CS6. But this shows up any of my current commercial broadcast projects and is just too distracting at the moment. The same project in CS5....no problems. Thanks for looking into it.
Just another set of specs to add here. A friend just tested on a mac pro 3,1, Lion, ATI Radeon HD 3870 and got the same issue. It seems very wide-spread.
Kevin - do you know if Adobe is only just becoming aware of this bug? Not trying to rush you - just very curious what's going on. I'm currently sitting on two different expensive grahics cards that were purchased to test this, knowing I need to return one or both depending on how this is resolved, so I'm curious as to what the status is.
I first saw this issue with AVCHD files, but now I see the "tearing" effect with solids and text. If the tearing was limited to AVCHD files, Adobe could blame the issue on the myriad of AVCHD file types, but apparently the problem is not limited to video files. This is a pretty serious bug, and has to be fixed.
I'm having the same problem on my AE CS6. It's on a Windows 7 64-bit. All video is having this problem except 24p footage. When I tell it to re-interprate the 60i interlaced footage (in this case lower-field interlaced to progressive), the footage looked perfect. However, when I changed it back, the footage would not go jagged again. It's like AE couldn't read the footage right until you tell it to interpret it. Then all is good. Don't know if anyone else is experiencing this.
Yes, thanks to you, we are working on a fix. I submitted the bug report last week. Here's to hoping for a quick resolution.
I don't know if this is the same problem that I was having, but I was experiencing tearing issues as well. I found out AE CS6 was not reading my footage correctly. It saw my progressive footage as interlaced, which was causing the tearing. When I went to Menu->Interpret Footage, and set it to progressive frames, the problem went away. Now I had to do that with every piece of footage I imported (progressive or interlaced, which is a pain and something Adobe need to fix), but if you shift-click all your footage, you can interpret footage en masse. It's doesn't fix the problem (AE not seeing the footage correctly), but it's a possible workaround.
BTW Adobe, this is also a problem I'm finding in Premiere Pro as well.
I am having this problem on 3 separate machines since the upgrade to Mountain Lion. We have 3 machines that are 2x2.4 GHz 6-core Intel Xeons, all with ~30gb of memory and dual ATI Radeon HD 5770 1024mb graphics cards, besides one that has an NVIDIA FeForce 8800 GT 512mb as the secondary graphics card.
During an extremely basic linear keyframe with a .jpg and a solid, along with a couple simple backgrounds we ran into this issue on every single machine. We never saw this problem until we upgraded machines and graphics cards.
Has anyone found any fixes for Mac machines running Mountain Lion?
Thanks in advance
