Hi all,
Any one else had problems with playback after installing Flash Player 11.2 ? I have a bunch of data I can post but I think it's my code ( not sure why 10.3, 11.1 work fine but 11.2 specifically wouldn't change a mxml view... ), so just wondering if anyone else seeing issues.
Alex G.
This is starting to look more and more like an LCCS issue :/
As far as I can tell during normal session start up (non-recording) LCCS gets the "SessionEvent.SYNCHRONIZATION_CHANGE" in ConnectSessionContainer.as a the thus invoking this code:
protected function onSynchronizationChange(p_event:SessionEvent):void
if ( _connectSession.isSynchronized ) {
buildChild();
dispatchEvent(p_event);
But when in playback mode, seems that SessionManagerPlayback.as starts the playback wayyy too early AND SessionEvent.SYNCHRONIZATION_CHANGE is not dispatched so "buildChildren" is never invoked.
| Thu Apr 5 10:26:28 GMT-0400 2012 | LCCS SDK Version : 2.2.0 | Player Version : MAC 11,2,202,228 |
| 10:26:28 GMT-0400 | requestInfo https://connect.acrobat.com/**************/localdevroom51?guk=ZzpwbGF5 YmFjaw==&mode=xml&playback=test_record_51_2&x=0.7791868606582284 | |
| 10:26:29 GMT-0400 | #TicketService# ticket received: 1r1hkahegysgu | |
| 10:26:29 GMT-0400 | Getting FMS at https://na2.collaboration.adobelivecycle.com/fms?ticket=1r1hkahegysgu& playback=test_record_51_2&proto=rtmfp, attempt #1/3 | |
| 10:26:39 GMT-0400 | result: <fms> |
<origin>fms1.acrobat.com</origin>
<proto_ports>rtmfp:1935,rtmps:443</proto_ports>
<retry_attempts>2</retry_attempts>
</fms>
| 10:26:39 GMT-0400 | protocols: [object ProtocolPortPair],[object ProtocolPortPair] |
| 10:26:39 GMT-0400 | [attempt 1 of 2] Connecting to 0/1: rtmfp://fms1.acrobat.com/playback/na2-c0798bf5-4164-4a17-978e-8495b10 25a2d/localdevroom51/test_record_51_2 #startProtosConnect# |
| 10:26:39 GMT-0400 | tempNetStatusHandler 0/2,NetConnection.Connect.Success |
| 10:26:39 GMT-0400 | isTunneling? false |
| 10:26:39 GMT-0400 | is using RTMPS? false |
| 10:26:39 GMT-0400 | #SessionManagerPlayback 10968 fms connected: [Event type="connected" bubbles=false cancelable=false eventPhase=2] |
| 10:26:39 GMT-0400 | #SessionManagerPlayback 10998 receiveLogin: |
| 10:26:39 GMT-0400 | . [object] |
| 10:26:39 GMT-0400 | \\ |
| 10:26:39 GMT-0400 | .descriptor [object]= [object Object] |
| 10:26:39 GMT-0400 | .ticket [string]= vyajtrv4t01r |
| 10:26:39 GMT-0400 | .options [object]= |
| 10:26:39 GMT-0400 | #SessionManagerPlayback 11004 ======= onConnected: play __PacingStream |
| 10:26:40 GMT-0400 | #SessionManagerPlayback 11079 ======= onMetadata: play __StreamOffsets |
| 10:26:40 GMT-0400 | #SessionManagerPlayback 11165 ======= receiveStreamOffset test_record_51_2/FileManager, 46 |
| 10:26:40 GMT-0400 | #SessionManagerPlayback 11166 ======= receiveStreamOffset test_record_51_2/AVManager, 61 |
| 10:26:40 GMT-0400 | #SessionManagerPlayback 11166 ======= receiveStreamOffset test_record_51_2/RoomManager, 85 |
| 10:26:40 GMT-0400 | #SessionManagerPlayback 11167 ======= receiveStreamOffset test_record_51_2/UserManager, 103 |
| 10:26:40 GMT-0400 | #SessionManagerPlayback 11168 ======= receiveStreamOffset test_record_51_2/myCamera, 121 |
| 10:26:40 GMT-0400 | #SessionManagerPlayback 11170 ======= receiveStreamOffset test_record_51_2/simpleNote, 136 |
| 10:26:40 GMT-0400 | #SessionManagerPlayback 11171 ======= receiveStreamOffset test_record_51_2/swb, 157 |
| 10:26:40 GMT-0400 | #SessionManagerPlayback 11171 ======= receiveStreamOffset test_record_51_2/5FE3CF8C-E808-6D97-968D-82E46471BF54, 180 |
here's playback trace from FP 11.1, that works fine for the same recording with the same app:
Also realized not getting the SessionEvent.SYNCHRONIZATION_CHANGE event because I'm not getting proper login in SessionManagerBase/SessionManagerFMS
| Thu Apr 5 12:44:16 GMT-0400 2012 | LCCS SDK Version : 2.2.0 | Player Version : MAC 11,1,102,55 |
| 12:44:16 GMT-0400 | requestInfo https://connect.acrobat.com/***********************/localdevroom51?guk =ZzpwbGF5YmFjaw==&mode=xml&playback=test_record_51_2&x=0.5776853640563 786 | |
| 12:44:17 GMT-0400 | #TicketService# ticket received: 1lt2bq547mlfl | |
| 12:44:17 GMT-0400 | Getting FMS at https://na2.collaboration.adobelivecycle.com/fms?ticket=1lt2bq547mlfl& playback=test_record_51_2&proto=rtmfp, attempt #1/3 | |
| 12:44:18 GMT-0400 | result: <fms> |
<origin>fms4.acrobat.com</origin>
</fms>
| 12:44:18 GMT-0400 | protocols: [object ProtocolPortPair],[object ProtocolPortPair] |
| 12:44:18 GMT-0400 | [attempt 1 of 2] Connecting to 0/1: rtmfp://fms4.acrobat.com/playback/na2-c0798bf5-4164-4a17-978e-8495b10 25a2d/localdevroom51/test_record_51_2 #startProtosConnect# |
| 12:44:18 GMT-0400 | tempNetStatusHandler 0/2,NetConnection.Connect.Success |
| 12:44:18 GMT-0400 | isTunneling? false |
| 12:44:18 GMT-0400 | is using RTMPS? false |
| 12:44:18 GMT-0400 | #SessionManagerPlayback 1936 fms connected: [Event type="connected" bubbles=false cancelable=false eventPhase=2] |
| 12:44:18 GMT-0400 | #SessionManagerPlayback 2018 receiveLogin: |
| 12:44:18 GMT-0400 | . [object] |
| 12:44:18 GMT-0400 | \\ |
| 12:44:18 GMT-0400 | .descriptor [object]= [object Object] |
| 12:44:18 GMT-0400 | .ticket [string]= 2txa1zn4q3x |
| 12:44:18 GMT-0400 | .options [object]= |
| 12:44:18 GMT-0400 | #SessionManagerPlayback 2021 ======= onConnected: play __PacingStream |
| 12:44:18 GMT-0400 | #SessionManagerPlayback 2065 ======= onMetadata: play __StreamOffsets |
| 12:44:18 GMT-0400 | #SessionManagerPlayback 2155 ======= receiveStreamOffset test_record_51_2/FileManager, 46 |
| 12:44:18 GMT-0400 | #SessionManagerPlayback 2155 ======= receiveStreamOffset test_record_51_2/AVManager, 61 |
| 12:44:18 GMT-0400 | #SessionManagerPlayback 2155 ======= receiveStreamOffset test_record_51_2/RoomManager, 85 |
| 12:44:18 GMT-0400 | #SessionManagerPlayback 2156 ======= receiveStreamOffset test_record_51_2/UserManager, 103 |
| 12:44:18 GMT-0400 | #SessionManagerPlayback 2157 ======= receiveStreamOffset test_record_51_2/myCamera, 121 |
| 12:44:18 GMT-0400 | #SessionManagerPlayback 2157 ======= receiveStreamOffset test_record_51_2/simpleNote, 136 |
| 12:44:18 GMT-0400 | #SessionManagerPlayback 2157 ======= receiveStreamOffset test_record_51_2/swb, 157 |
| 12:44:18 GMT-0400 | #SessionManagerPlayback 2157 ======= receiveStreamOffset test_record_51_2/5FE3CF8C-E808-6D97-968D-82E46471BF54, 180 |
| 12:44:18 GMT-0400 | #SessionManagerPlayback 2158 ======= onOffsetStreamPlayStatus |
| 12:44:18 GMT-0400 | .code [string]= NetStream.Play.Complete |
| 12:44:18 GMT-0400 | .duration [number]= 0 |
| 12:44:18 GMT-0400 | .level [string]= status |
| 12:44:18 GMT-0400 | .bytes [number]= 1179 |
| 12:44:19 GMT-0400 | #SessionManagerPlayback 2269 realReceiveLogin: |
| 12:44:19 GMT-0400 | . [object] |
| 12:44:19 GMT-0400 | \\ |
| 12:44:19 GMT-0400 | .descriptor [object]= [object Object] |
| 12:44:38 GMT-0400 | RECEIVED LOGIN AT SESSION |
| 12:44:38 GMT-0400 | .user descriptor from server [object] |
| 12:44:38 GMT-0400 | \\ |
| 12:44:38 GMT-0400 | .affiliation [number]= 10 |
| 12:44:38 GMT-0400 | .userID [number]= 0 |
| 12:44:38 GMT-0400 | #SessionManagerPlayback 21821 ======= subscribeCollection root |
| 12:44:38 GMT-0400 | #SessionManagerPlayback 21821 ======= subscribeCollection __RootCollection - play |
| 12:44:38 GMT-0400 | #SessionManagerPlayback 21869 ======= subscribeCollection UserManager - play |
| 12:44:38 GMT-0400 | #SessionManagerPlayback 21870 ======= subscribeCollection FileManager - play |
| 12:44:38 GMT-0400 | #SessionManagerPlayback 21871 ======= subscribeCollection AVManager - play |
| 12:44:38 GMT-0400 | #SessionManagerPlayback 21872 ======= subscribeCollection RoomManager - play |
| 12:44:38 GMT-0400 | RECEIVENODES FileManager |
| 12:44:38 GMT-0400 | receiveAllSynchData FileManager |
| 12:44:38 GMT-0400 | checkManagerSync:[object FileManager] |
| 12:44:38 GMT-0400 | RECEIVENODES UserManager |
| 12:44:38 GMT-0400 | receiveAllSynchData UserManager |
| 12:44:38 GMT-0400 | RECEIVENODES RoomManager |
| 12:44:38 GMT-0400 | receiveAllSynchData RoomManager |
| 12:44:38 GMT-0400 | checkManagerSync:[object RoomManager] |
| 12:44:38 GMT-0400 | RECEIVENODES AVManager |
| 12:44:38 GMT-0400 | receiveAllSynchData AVManager |
| 12:44:38 GMT-0400 | checkManagerSync:[object StreamManager] |
| 12:44:38 GMT-0400 | checkManagerSync:[object UserManager] |
| 12:44:41 GMT-0400 | #SessionManagerPlayback 24540 ======= subscribeCollection myCamera - play |
| 12:44:42 GMT-0400 | #SessionManagerPlayback 25504 ======= subscribeCollection simpleNote - play |
| 12:44:43 GMT-0400 | #SessionManagerPlayback 26249 ======= subscribeCollection swb - play |
| 12:44:43 GMT-0400 | RECEIVENODES simpleNote |
| 12:44:43 GMT-0400 | receiveAllSynchData simpleNote |
| 12:44:43 GMT-0400 | RECEIVENODES myCamera |
| 12:44:43 GMT-0400 | receiveAllSynchData myCamera |
| 12:44:43 GMT-0400 | #SessionManagerPlayback 26977 seek and play |
| 12:44:43 GMT-0400 | RECEIVENODES swb |
| 12:44:43 GMT-0400 | receiveAllSynchData swb |
| 12:44:51 GMT-0400 | #SessionManagerPlayback 34450 ======= onPlayStatus |
| 12:44:51 GMT-0400 | . [object] |
| 12:44:51 GMT-0400 | \\ |
| 12:44:51 GMT-0400 | .code [string]= NetStream.Play.Complete |
| 12:44:51 GMT-0400 | .duration [number]= 0 |
| 12:44:51 GMT-0400 | .level [string]= status |
| 12:44:51 GMT-0400 | .bytes [number]= 2340 |
| 12:44:51 GMT-0400 | #SessionManagerPlayback 34452 ======= onPlayStatus |
| 12:44:51 GMT-0400 | .bytes [number]= 978 |
| 12:44:51 GMT-0400 | #SessionManagerPlayback 34481 ======= onPlayStatus |
| 12:44:51 GMT-0400 | .bytes [number]= 1153 |
| 12:44:51 GMT-0400 | #SessionManagerPlayback 34488 ======= onPlayStatus |
| 12:44:51 GMT-0400 | .bytes [number]= 5348 |
| 12:44:51 GMT-0400 | #SessionManagerPlayback 34517 ======= onPlayStatus |
| 12:44:51 GMT-0400 | .bytes [number]= 4021 |
| 12:44:54 GMT-0400 | #SessionManagerPlayback 37783 ======= onPlayStatus |
| 12:44:54 GMT-0400 | . [object] |
| 12:44:54 GMT-0400 | \\ |
| 12:44:54 GMT-0400 | .code [string]= NetStream.Play.Complete |
| 12:44:54 GMT-0400 | .duration [number]= 0 |
| 12:44:54 GMT-0400 | .level [string]= status |
| 12:44:54 GMT-0400 | .bytes [number]= 1278 |
| 12:44:55 GMT-0400 | #SessionManagerPlayback 38867 ======= onPlayStatus |
| 12:44:55 GMT-0400 | . [object] |
| 12:44:55 GMT-0400 | \\ |
| 12:44:55 GMT-0400 | .code [string]= NetStream.Play.Complete |
| 12:44:55 GMT-0400 | .duration [number]= 0 |
| 12:44:55 GMT-0400 | .level [string]= status |
| 12:44:55 GMT-0400 | .bytes [number]= 991 |
| 12:44:56 GMT-0400 | #SessionManagerPlayback 39402 ======= onPlayStatus |
| 12:44:56 GMT-0400 | . [object] |
| 12:44:56 GMT-0400 | \\ |
| 12:44:56 GMT-0400 | .code [string]= NetStream.Play.Complete |
| 12:44:56 GMT-0400 | .duration [number]= 2 |
| 12:44:56 GMT-0400 | .level [string]= status |
| 12:44:56 GMT-0400 | .bytes [number]= 10311 |
| 12:44:56 GMT-0400 | #SessionManagerPlayback 39499 ======= onPlayStatus |
| 12:44:56 GMT-0400 | .duration [number]= 0 |
| 12:44:56 GMT-0400 | .bytes [number]= 38672 |
^ that fix worked for me in the 'simple' recording application, did not however work in the bigger production app I'm working on.
I'm having to call connectSession.archiveManager.seek(0) ... sigh what a terrible work around
( EDIT: Again this just starts the playback; which is NOT synchronized. Video + audio + stage are not in sync ).
Can anyone from Adobe speak to this?
Also, could this be related -> http://forums.adobe.com/message/4308995 and https://bugbase.adobe.com/index.cfm?event=bug&id=3157899 ?
Turns out it is after all Flash Player 11.2 bug in NetStream.play() method used in SessionManagerPlayback.as.
During normal operation of NetStream.play a message is dispatched that triggers the following method:
public function onMetaData(info:Object):void
_offsetStream.client["onPlayStatus"] = onOffsetStreamPlayStatus;
which then triggers the "realReceiveLogin()" function
public function onOffsetStreamPlayStatus(info:Object):void {
setTimeout(realReceiveLogin, asynchTimer, {descriptor:{userID:0, affiliation:10}});
This causes a login event to be dispatched and eventually a buildChildren and etc.... this no longer happens in FP 11.2 nor 11.3 (beta)
Also this causes an unrelated bug where trying to skip forward in my playback, I get broken video/audio/everything that's because "NetStream.play()" breaks when you try to "seek" forward in time in the FLV
yay!
I tried some other things using a wowza test application and I noted that the main difference in this new flash player version is that NetStream does not launch the client callbacks before the player starts to play (events NetStream.Play.Start and NetStream.Buffer.Full) anymore, what was not a problem in the older ones. Or, of course, using the NetConnection client callback, instead of NetStream one, because it does not depends on "play". I can't see any options or workarounds that could be applied to client side.
