How do I install the DNxHD and Cineform codecs? (Missing from AME 6 )
Jun 8, 2012 10:22 AM
Tags: #media #cs6 #codec #transcode #adobe_media_encoder #cineform #encoder/export #codec_not_installed #premiere_pro_cs6 #dnx_hd_185
I have downloaded the free versions of both of these codecs in the hopes of being able to transcode to each as an intermediate codec for my AVCHD files. The problem is that neither shows up in either my Premiere Pro CS6 or Adobe Media Encoder Import/Export options? What gives? Did I miss something here? How do I get the option to transcode or encode to DnxHD or Cineform on a PC version of CS6?
    Jun 8, 2012 10:33 AM   in reply to saskamodiejones
    Does this help?
    Jun 8, 2012 3:02 PM   in reply to Jeff Bellune
    CS6 doesn't install Quicktime  by default on Windows, you'll need to install it separately for it show up as an export format.
    Jun 11, 2012 8:30 AM   in reply to Larry Sullivan
    Have a similar problem. My pc cant even read the file. Can someone point me to which codec I could use. I have installed Quicktime pro on my PC, but I still cant read the file, and  dont have the option to export to DNxHD. Im on CS6.
    Jun 11, 2012 9:00 AM   in reply to tellmickey
    Welcome to the forum.
    You have to install the Avid codecs separately.  Go here:
    Avid Codecs 2.3.7 Download
    Jeff
    Apr 13, 2013 4:25 PM   in reply to saskamodiejones
    I am having the same problem on Mac OS X 10.7 (Lion). I verified and the codecs are isntalled in the quicktime folder. I also rebooted the computer after installing the codecs. I want to use Adobe Media Encoder to transcode avchd files to Avid DNXHD.  I have transcoded to ProRes sucessfuly but don't see the option for Avid DNXHD.. Is this possible on the Mac or do I have to wait for the next version of Adobe Premiere Pro and Media Encoder?.
    Apr 13, 2013 6:17 PM   in reply to MJFeliciano
    Never mind... I checked again and noticed I have the same Avid codecs I had before on CS5.5... No presets, just the codecs to create a custom preset. I guess I have to wait for the new version they showed at NAB to get a list of Avid presets like we do now with Apple ProRes.
    May 7, 2013 1:12 PM   in reply to MJFeliciano
    I'm having this exact same issue. I've installed 2.3.7 and the new 2.3.8. Selecting "Quicktime", no DNxHD presets show up in Media Encoder.
    May 7, 2013 1:41 PM   in reply to Xoxidine
    Look under the Video Codec setting further down (where you currently have H.264 selected). The codec names start with "AVID".
    May 7, 2013 1:44 PM   in reply to Profitic
    It's not there either.
    May 7, 2013 1:51 PM   in reply to Xoxidine
    After downloading the codec pack, did you run the executable installation program? After running the program, did you restart the computer?
    May 7, 2013 1:56 PM   in reply to Profitic
    Yes and yes.
    I tried to see if maybe the codec showed up in MPET StreamClip, but I don't see it there either.
    May 7, 2013 2:09 PM   in reply to Xoxidine
    Well, I uninstalled the codecs, reinstalled, restarted, and now they show up under Video Codec. :face palm: So... there you go.
    May 15, 2013 1:44 AM   in reply to Larry Sullivan
    Hi
    i have installed the avid dnxhd codec separately (official avid site - AvidCodecsLESetup.exe) . Premiere pro 6 can now import dnxhd-videos - but premiere 6 can not export in quicktime format - regardless the format or codec. There is an error "can not create a target movie" - in german "Fehler beim Erstellen des Films. Es kann keine Ausgabedatei erstellt oder geöffnet werden. "
    If i remove the dnxhd codec i am able to export in quicktime.
    Do you have any suggestions?
    THX, Oliver
    May 15, 2013 7:53 AM   in reply to TennisGate-LTD
    Have you loaded any other codecs on the system? There might be conflict. What OS are you running?
    May 15, 2013 7:57 AM   in reply to Profitic
    Hi,  - no other external codec. I am running the master collection on Windows 7 64bit.
    May 15, 2013 10:27 AM   in reply to TennisGate-LTD
    Try uninstalling DNxHD and QuickTime, then install a down-rev version of QT based on Adobe system specifications:
    CS6/CC - QT 7.6.6 for Windows (I use 7.6.9)
    CS5.5 - QT 7.6.2
    CS5 - QT 7.6.2
    CS4 - QT 7.4.5
    Restart your computer after re-installing QuickTime and DNxHD, and see if it works.
    May 16, 2013 2:38 AM   in reply to Profitic
    Hi
    thank you for this great advice. Works perfect !!!
    May 16, 2013 11:32 AM   in reply to TennisGate-LTD
    Happy to help, and glad it worked out.
