Green square pixalation blocks apearing on output files
Jan 18, 2011 8:57 PM
  Latest reply: JetsyKetsy, Jul 24, 2012 7:54 PM
Replies 1 2 Previous Next
    Feb 1, 2011 10:52 AM   in reply to Kombi_914
    > so  ImporterFastMPEG decodes the files better than   ImporterMPEG, giving you a higher quality output file?
    It's not relevant to compare the two plug-ins.  Don't think about it in either/or terms.  Both are used by the application.  I can't stress enough how removing ImporterFastMPEG is only a workaround for a bug.  Both plug-ins should be left in place if you desire normal operation of the application.
    Feb 10, 2011 8:22 AM   in reply to Kombi_914
    So might this be also related to the issues with h.264 which also uses MainConcept?
    Feb 10, 2011 6:49 PM   in reply to typpeo
    > they are use the MainConcept encoder for the mpeg-2 files
    Correct, there is code from MainConcept that is used by both plug-ins which runs the internal mechanisms of decoding the MPEG data.
    No.  This thread is about a specific issue with a specific aspect of the MPEG-2 files which aren't getting decoded correctly.  The path for decoding H.264 files is completely different.  The same plug-in files might be involved (depending on the given situation), but that doesn't necessarily mean the same code is relevant to the problem.
    Jul 11, 2011 10:14 PM   in reply to Tim Kurkoski
    Wow! I have been having the same problem and im glad that i was able to find this post! thanks your tip about moving the importerfast plugin worked!
    Jun 11, 2012 12:40 PM   in reply to Kombi_914
    I have this problem on some footage when both "Render at Maximum Depth" and "Use Maximum Render Quality" are selected. Selecting just one of them or neither results with no green blocks. Can't figure out why. Using AME 5.5
    Jun 14, 2012 9:25 AM   in reply to ubi_tech
    I just posted almost the same problem when exporting H.264 files from Premiere 5.5 with AME and when I UNCHECKED render at maximum depth the green blocks went away from my shadow areas... Use Maximum Render Quality had no effect in my situation.  Here is the intesting part - When I took off my color correction effects, The video files were fine with both of the boxes checked.
    At least this fixed my sitaution! Thank you for the hard work and ubi_tech's response...
    Jul 24, 2012 7:54 PM   in reply to Tim Kurkoski
    I'm experiencing the same issue - the entire screen just goes to green (and sometimes black) pixelation.  I've tried removing the ImporterFastMPEG file from the plugin folder as you described but it hasn't fixed the problem.
    I'm hoping, seeing as this is 1.5yrs since you originally identified the bug in your post, that your dev team may have more thoughts on the bug?  Do you have any other suggestions re how to deal with this?
    I'm using CS5 on a 64-bit PC.  The footage was supplied by an external production company (so no chance of getting a different version).  I know all footage was XDCAM compressed from FCP7 as .movs
1 2 Previous Next
