Help needed for Time Calc Java Script
Nov 18, 2008 9:09 PM
I am trying to create a timesheet in PDF and have hit a speed bump. Is there anyone there who could provide me with a script that calculated the difference between 2 times? (Field2 time)-(Feild 1 Time) = Duration.I am desperate and have tried everything.
I proccess the payroll for a company and all of the 500 or so timesheets that I received each fortnight are paper copies and I am pulling my hair out. I need to use Adobe forms (We have Adobe Pro 9 and I am using the XML forms, not live cycle) as the serach engine that we use for emails cannot search on excel documents.
I have no Java script experience and I am getting completely lost in the subject. Any help would be greatly appreciated.
Thanks anyone who can help at all.
-Sohnia
    Nov 19, 2008 11:15 AM   in reply to (Sohnia_White)
    Using Acrobat forms JavaScript, the following script will compute the time difference in hours and minutes within the same day:
    function Time2Num(sTime, cFormat) {
    // convert a date time string to seconds since the epoch date
    var oTime = util.scand(cFormat, sTime); // date time object
    var fTime = oTime.valueOf(); // time string to milliseconds
    return Math.round(fTime / 1000); // return rounded seconds
    function TimeDiff(sEnd, sStart) {
    // compute difference in time within same day as minutes
    var fEnd = 0; // default value if not data
    var fStart = 0; // default value if not data
    var cDateFormat = "m/d/yyyy "; // date format string
    var sNowDate = util.printd(cDateFormat, new Date()); // get today's date as "m/d/yyyy'
    var cDateTimeFormat = cDateFormat + "h:MM tt";
    // compute difference if we have data
    if(sEnd != "" & sStart != "") {
    // get end time in minutes
    var cDateTimeValue = sNowDate + sEnd; // start date time string
    var fEnd = Time2Num(cDateTimeValue, cDateTimeFormat) / 60; // convert to seconds and divide by 60 sec
    // get start time in minutes
    var cDateTimeValue = sNowDate + sStart; // start date time string
    var fStart = Time2Num(cDateTimeValue, cDateTimeFormat) / 60; // convert to seconds and divide by 60 sec
    } // end if we have value
    return fEnd - fStart; // compute and return the difference in minutes
    } // end function
    function Mins2HrsMins(fMinutes) {
    // convert seconds into formatted string of hours:minutes
    var cDisplayFormat = "%01.0f" + ":" + "%02.0f"; // format for returned value
    var fHrs = Math.floor(fminutes / 60); // compute whole hours from the difference
    var fMins = fMinutes % 60; // get minutes less than 1 hour form the difference
    return util.printf(cDisplayFormat, fHrs, fMins); // format and return computed value
    } // end function
    var fDiff = TimeDiff(this.getField("Field2 Time").value, this.getField("Field1 Time").value)
    event.value = Mins2HrsMins(fDiff); // format computed value
    The 3 functions can be placed as a document level functions. One only needs to call the "TimeDiff(sEnd, sStart)" with the end and start time strings to get the difference in minutes between the start and end times. This value can then be further processed to summ other differences. The "Sec2HrsMins()" will format a minutes value to hours and minutes if any additional processing is done.
    Of one can use the following event script to compute the difference and format the result with one line of code:
    event.value = Mins2HrsMins( TimeDiff(this.getField("Field2 Time").value, this.getField("Field1 Time").value) );
    Nov 25, 2008 7:14 AM   in reply to (Sohnia_White)
    If you place the functions as a document level script, "Advance => Document Processing => Document JavaScirpts...", then one does not need to repeat the funciton code for each call of the function by each field.
    You code for each period would be similar to:
    And you would only need to change the field names as required.
    To get the total for a series of fields one could use a custom calculation script similar to:
    var fDiff = TimeDiff(this.getField("Field2 Time").value, this.getField("Field1 Time").value); // get first pair of times
    fDiff += TimeDiff(this.getField("Field4 Time").value, this.getField("Field3 Time").value) // add next pair of times
    fDiff += TimeDiff(this.getField("Field6 Time").value, this.getField("Field5 Time").value) // add next pair of times
    fDiff += TimeDiff(this.getField("Field8 Time").value, this.getField("Field7 Time").value) // add next pair of times
    fDiff += TimeDiff(this.getField("Field1- Time").value, this.getField("Field9 Time").value) // add last pair of times
    Or one could even fill in each day's time while computing the sum.
    Jan 6, 2009 7:13 AM   in reply to (Sohnia_White)
    hi friend here example for time calulation start and end time example..<br />just copy and paste then run it ur browser.<br /><br /><HTML><br /><script language="JavaScript"><br /><!--<br /><br />var h1 = 1;<br />var h2 = 2;<br />var days = 0;<br />var m1 = 1;<br />var m2 = 2;<br />var am1 = 1;<br />var am2 = 2;<br />function findtime(h1,h2,days,m1,m2,am1,am2)<br />{<br />var answer = "why";<br />var mdiff = 1;<br />var hdiff = 2;<br />pdays = parseInt(days);<br />ph1 = parseInt(h1);<br />ph2 = parseInt(h2);<br />pm1 = parseInt(m1);<br />pm2 = parseInt(m2);<br />if(am1 == 2 & ph1 < 12) ph1 = ph1 + 12;<br />if(am2 == 2 & ph2 < 12) ph2 = ph2 + 12;<br />if(am1 == 1 & ph1 == 12) ph1 = 24;<br />if(am2 == 1 & ph2 == 12) ph2 = 24;<br />if(am1 == 2 & am2 == 1 & ph2 < 24) ph2 = ph2 + 24;<br />if(am1 == am2 & ph1 > ph2) ph2 = ph2 + 24;<br />if(pm2 < pm1){<br />pm2 = pm2 + 60;<br />ph2 = ph2 - 1;<br />}<br />mdiff = pm2 - pm1;<br />hdiff = (ph2 - ph1) + (pdays * 24);<br />if(hdiff == 0) answer = mdiff + ' minutes';<br />else if(hdiff == 1) answer = '1 hour and ' + mdiff + ' minutes'<br />else answer = hdiff + ' hours and ' + mdiff + ' minutes'<br />return answer<br />}<br /><br />//--><br /></script><br /></HEAD><br /><br /><font face="Arial,Helvetica,Geneva,Swiss,SunSans-Regular"><br /><BODY BGCOLOR=FFFFFF TEXT=000000 LINK=0000FF VLINK=800080><br /><br /><div align="center"><table width="950" border="0" cellpadding="0" bgcolor="#899194" cellspacing="0"><br /><br />  <br /><tr><td valign="middle" width="33%"><br /><br /><center><br /><form><br /><TD WIDTH=80%><br /><center><br /><TABLE ALIGN=MIDDLE BORDER=5 CELLPADDING=5><br /><TR BGCOLOR=#FFFFFF><br /><!--ROW 1--><br /><TD WIDTH=80%><br /><center><br /><TABLE ALIGN=MIDDLE BORDER=5 CELLPADDING=5><br /><TR BGCOLOR="#B6D4D2"><br /><!--ROW 1--><br /><td colspan=4><br /><center>Time Between Times Calculations - Multiple Days</center><br /><br /></td><br /></tr><br /><TR BGCOLOR="#B6D4D2"><br /><TD align="center" colspan=4><br />Required Data Entry<br /></td><br /></tr><br /><tr><br /><td align="center">Start / End</td><br /><td align="center">Hour</td><br /><td align="center">Minute</td><br /><td align="center">AM / PM</td><br /></tr><br /><br /><td align="center">Start time</td><br /><td align="center"><input type="text" name="hour1" size="5"></td><br /><td align="center"><input type="text" name="minute1" size="5"></td><br /><td align="center"><select name="period1"><br /><option value="1">AM<br /><option value="2">PM<br /></select><br /></td><br /></tr><br /><tr><br /><td colspan="3">    Add Complete Interim Days</td><td align="center"><input type="text" name="adays" size="5" value="0"></td><br /></tr><br /><tr><br /><td align="center">Start / End</td><br /><br /><td align="center">Hour</td><br /><td align="center">Minute</td><br /><td align="center">AM / PM</td><br /></tr><br /><td align="center">End time</td><br /><td align="center"><input type="text" name="hour2" size="5"></td><br /><td align="center"><input type="text" name="minute2" size="5"></td><br /><td align="center"><select name="period2"><br /><option value="1">AM<br /><option value="2">PM<br /></select><br /></td><br /></tr><br /><br /><tr><br /><td align="center" colspan=4 BGCOLOR="#B6D4D2"><br /><input type="button" value="Calculate" <br />onclick="h1=form.hour1.value;<br />h2=form.hour2.value;<br />m1=form.minute1.value;<br />m2=form.minute2.value;<br />days=form.adays.value;<br />am1=form.period1.options[period1.selectedIndex].value;<br />am2=form.period2.options[period2.selectedIndex].value;<br />if(h1 < 0 | h1 > 12) alert('Your start hour is not valid');<br />else if(h2 < 0 | h2 > 12) alert('Your end hour is not valid');<br />else if(m1 < 0 | m1 > 59) alert('Your start minute is not valid');<br />else if(m2 < 0 | m2 > 59) alert('Your end minute is not valid');<br />else form.answer.value=findtime(h1,h2,days,m1,m2,am1,am2);"><br />   <br /><input type="reset" value="Clear Values"><br /><br /></td><br /></tr><br /><TR BGCOLOR="#B6D4D2"><br /><TD align="center" colspan=4><br />Calculated Results<br /></td><br /></tr><br /><br /><tr><br /><td align="center" colspan="4"><br />Time Difference <input type="text" name="answer" size="40"><br /><tr><td>vino7tech@gmail.com</td></tr><br /></td><br /></tr><br /></table><br /></form><br /></td><br /></tr><br /></table><br /><br /></center><br /></td><br /></tr><br /></table><br /></center><br /><br /></TD><br /></TR><br /></TABLE><br /></BODY> <br /></HTML>
    Jan 6, 2009 7:15 AM   in reply to (Sohnia_White)
    <pre><br /><HTML><br /><script language="JavaScript"><br /><!--<br /><br />var h1 = 1;<br />var h2 = 2;<br />var days = 0;<br />var m1 = 1;<br />var m2 = 2;<br />var am1 = 1;<br />var am2 = 2;<br />function findtime(h1,h2,days,m1,m2,am1,am2)<br />{<br />var answer = "why";<br />var mdiff = 1;<br />var hdiff = 2;<br />pdays = parseInt(days);<br />ph1 = parseInt(h1);<br />ph2 = parseInt(h2);<br />pm1 = parseInt(m1);<br />pm2 = parseInt(m2);<br />if(am1 == 2 & ph1 < 12) ph1 = ph1 + 12;<br />if(am2 == 2 & ph2 < 12) ph2 = ph2 + 12;<br />if(am1 == 1 & ph1 == 12) ph1 = 24;<br />if(am2 == 1 & ph2 == 12) ph2 = 24;<br />if(am1 == 2 & am2 == 1 & ph2 < 24) ph2 = ph2 + 24;<br />if(am1 == am2 & ph1 > ph2) ph2 = ph2 + 24;<br />if(pm2 < pm1){<br />pm2 = pm2 + 60;<br />ph2 = ph2 - 1;<br />}<br />mdiff = pm2 - pm1;<br />hdiff = (ph2 - ph1) + (pdays * 24);<br />if(hdiff == 0) answer = mdiff + ' minutes';<br />else if(hdiff == 1) answer = '1 hour and ' + mdiff + ' minutes'<br />else answer = hdiff + ' hours and ' + mdiff + ' minutes'<br />return answer<br />}<br /><br />//--><br /></script><br /></HEAD><br /><br /><font face="Arial,Helvetica,Geneva,Swiss,SunSans-Regular"><br /><BODY BGCOLOR=FFFFFF TEXT=000000 LINK=0000FF VLINK=800080><br /><br /><div align="center"><table width="950" border="0" cellpadding="0" bgcolor="#899194" cellspacing="0"><br /><br />  <br /><tr><td valign="middle" width="33%"><br /><br /><center><br /><form><br /><TD WIDTH=80%><br /><center><br /><TABLE ALIGN=MIDDLE BORDER=5 CELLPADDING=5><br /><TR BGCOLOR=#FFFFFF><br /><!--ROW 1--><br /><TD WIDTH=80%><br /><center><br /><TABLE ALIGN=MIDDLE BORDER=5 CELLPADDING=5><br /><TR BGCOLOR="#B6D4D2"><br /><!--ROW 1--><br /><td colspan=4><br /><center>Time Between Times Calculations - Multiple Days</center><br /><br /></td><br /></tr><br /><TR BGCOLOR="#B6D4D2"><br /><TD align="center" colspan=4><br />Required Data Entry<br /></td><br /></tr><br /><tr><br /><td align="center">Start / End</td><br /><td align="center">Hour</td><br /><td align="center">Minute</td><br /><td align="center">AM / PM</td><br /></tr><br /><br /><td align="center">Start time</td><br /><td align="center"><input type="text" name="hour1" size="5"></td><br /><td align="center"><input type="text" name="minute1" size="5"></td><br /><td align="center"><select name="period1"><br /><option value="1">AM<br /><option value="2">PM<br /></select><br /></td><br /></tr><br /><tr><br /><td colspan="3">    Add Complete Interim Days</td><td align="center"><input type="text" name="adays" size="5" value="0"></td><br /></tr><br /><tr><br /><td align="center">Start / End</td><br /><br /><td align="center">Hour</td><br /><td align="center">Minute</td><br /><td align="center">AM / PM</td><br /></tr><br /><td align="center">End time</td><br /><td align="center"><input type="text" name="hour2" size="5"></td><br /><td align="center"><input type="text" name="minute2" size="5"></td><br /><td align="center"><select name="period2"><br /><option value="1">AM<br /><option value="2">PM<br /></select><br /></td><br /></tr><br /><br /><tr><br /><td align="center" colspan=4 BGCOLOR="#B6D4D2"><br /><input type="button" value="Calculate" <br />onclick="h1=form.hour1.value;<br />h2=form.hour2.value;<br />m1=form.minute1.value;<br />m2=form.minute2.value;<br />days=form.adays.value;<br />am1=form.period1.options[period1.selectedIndex].value;<br />am2=form.period2.options[period2.selectedIndex].value;<br />if(h1 < 0 | h1 > 12) alert('Your start hour is not valid');<br />else if(h2 < 0 | h2 > 12) alert('Your end hour is not valid');<br />else if(m1 < 0 | m1 > 59) alert('Your start minute is not valid');<br />else if(m2 < 0 | m2 > 59) alert('Your end minute is not valid');<br />else form.answer.value=findtime(h1,h2,days,m1,m2,am1,am2);"><br />   <br /><input type="reset" value="Clear Values"><br /><br /></td><br /></tr><br /><TR BGCOLOR="#B6D4D2"><br /><TD align="center" colspan=4><br />Calculated Results<br /></td><br /></tr><br /><br /><tr><br /><td align="center" colspan="4"><br />Time Difference <input type="text" name="answer" size="40"><br /></td><br /></tr><br /></table><br /></form><br /></td><br /></tr><br /></table><br /><br /></center><br /></td><br /></tr><br /></table><br /></center><br /><br /></TD><br /></TR><br /></TABLE><br /></BODY> <br /></HTML><br /></pre>
    Jan 6, 2009 7:16 AM   in reply to (Sohnia_White)
    hi friend i have coding for this if ur interest me vino7tech@gmail.com
    Jun 11, 2012 11:02 AM   in reply to GKaiseril
    Hello GKaiseril,
    I'm having a bit of a problem in doing this Time calculation and was wondering if you could help?
    I've used your 3 functions as 'Document Javascripts' and using a custom calculation script
    " event.value = Mins2HrsMins( TimeDiff(this.getField("Field2 Time").value, this.getField("Field1 Time").value) ); " on the "TotHours" field but for some reason the "TotHours" field appears blank.
    I've also tired using all 3 functions and the event.value as a custom calculation script but still get the same result.
    Could you please let me know what I am doing wrong?
    Thanks for you help in advance!
    Ken!
    Jun 11, 2012 12:43 PM   in reply to gKen
    Ken,
    what is the foramt style of you time string?
    The script is for "h:mm tt" like 9:00 am.
    As to using web page JavaScirpt, you will need to adjsut it for the Acrobat JavaScirpt variation.
    Jun 11, 2012 1:22 PM   in reply to GKaiseril
    Hi GKaiseril,
    Thanks a million for your prompt reply!!
    Both the "Field2 Time" and the "Field1 Time" fields have the time format of "h:MM tt" format.
    I am using your javascript script on the beginning of this page (which you did for Sonhia), but the field displaying the difference between the two times - "TotHours"  - is blank.
    I am using these scripts in a pdf form in Acrobat X (on a Mac) - Could that be an issue?
    Thanks again!
    Jun 11, 2012 1:25 PM   in reply to gKen
    No that should not be a problem.
    Are the field names correct?
    Are the field names spelled correctly?
    Are the field names capitalized correctly?
    Is JavaScript enabled in Acrobat?
    Jun 11, 2012 2:05 PM   in reply to GKaiseril
    Here is the script I am using:
    } // end function
    } // end function
    var fDiff = TimeDiff(this.getField("Field2_Time").value, this.getField("Field1_Time").value)
    All the above code is in the "Calculate>Custom Calculate Script" of the "TotHours" field.
    I have the Javascript Debugger enabled in Acrobat and when I enter the time in "Field2_Time" and hit the tab key I get this in the Debugger:
    fminutes is not defined
    31:Field:CalculateException in line 31 of function Mins2HrsMins, script Field:Calculate
    Exception in line 37 of function top_level, script Field:Calculate
    ReferenceError: fminutes is not defined
    31:Field:Calculate
    I hope this helps.
    Thank you so much!
    Jun 11, 2012 2:14 PM   in reply to gKen
    Hello GKaiseril,
    As I red over the last reply, I figured where the error was and corrected it (fminutes should have been fMinutes on line 31)and it now works.
    Thank very much for helping out with this.
    Ken!
    And do the form field names agree with your form fields in spelling, capitalization, and spaces in the name?
    Have you looked at the JavaScript console for any errors?
