edkatibah
Problem with GPX file rendering
Jun 11, 2012 8:17 PM
Tags: #map #lr4 #lightroom4 #gpx #track_log #gpx_file
I'm having an issue with Lightroom 4.1 GPX file rendering (Load Track Log).  The GPX files were generated from a Garmin eTrex GPS unit.  The Garmin GPS tracks were downloaded to Garmin Basecamp Version 3.3.1 from which the GPX files were exported. All software is being executed on a MacBook Pro running OS X 10.6.8.
Esri's ArcGIS Explorer Online renders the GPX file correctly:
Here is how the same data is incorrectly rendered in Lightroom 4.1:
I have placed a copy of the GPX file used above at:
http://sdrv.ms/Only2R
Note: this is not an isolated issue - I have 40 additional GPX files which all suffer the same rendering issues in Lightroom 4.1.
Thanks for looking into this issue.
- Ed
Ed Katibah
ed@katibah.net
    Jun 12, 2012 12:03 AM   in reply to edkatibah
    Your GPX file contains extensions to GPX specification describing in what color to display your track and other additional information.
    Try converting it to basic GPX file using GPSBabel (just load your GPX and convert to GPX) and see if this helps.
    Jun 12, 2012 11:48 AM   in reply to edkatibah
    A similar issue. http://forums.adobe.com/message/4459571
    And just like yours, the other tracklog did not have timestamps. I guess that is what's confusing Lightroom. Not sure it's a bug or a design limitation.
    Jun 12, 2012 12:54 PM   in reply to Dorin Nicolaescu-Musteață
    It should be noted that Garmin GPS units will remove the date/time information from a track point that was not created directly by a GPS fix in the unit.
    This means that any track that is uploaded to the Garmin GPS from a PC or is the result of compressing--called saving in some Garmin units--the track will not contain date/time information.
    Jun 12, 2012 12:57 PM   in reply to edkatibah
    You're not helping yourself by double posting, just confusing the hell out of folk who are trying to help.
    As others have already mentioned, your GPX file is messed up with a bunch of info that Lr can't use or understand. Also, the lack of timestamps doesn't help.
    If file is still on your Etrex try copying it across to your hard drive again, but don't use BaseCamp. Instead connect the Etrex to your Mac via USB then set it up as a USB Mass Storage Device (i.e. choose Interface from Etrex Setup menu)
    Jun 12, 2012 1:11 PM   in reply to Ian Lyons
    I suspect that the extraneous information isn't the problem.  His file is a syntatically correct .gpx file and as such should be read without problem by LR.  However, without the benefit of a time stamp there is no valid method of determining the order of the data points.  The order of the points in the file is a normally accepted method, but it is not standardized.  I write my own .gpx files using my own software.  My files contain lots of added information and LR reads them without a problem.
    I don't believe the eTrex communicates via USB mass storage--at least the early ones didn't, they required communication be via the Garmin Interface Specification which was originally applied only to RS232.  Later the spec was 'wrapped' by further information and Garmin used it for USB.  The use of the USB mass storage method arrived with the nuvi series and has prevailed since then.  So it is possible that your suggestion doesn't apply.
    Jun 12, 2012 1:30 PM   in reply to edkatibah
    The post Dorin linked to above was at http://forums.adobe.com/message/4459571#4459571 not the Community Feedback forums. If you'd followed his link you'd see it a different user name, a different GPS device, but same problem, and missing the same info.
