adding mc from libray to the stage by using one linkage name
Participant ,
Jun 11, 2012 Jun 11, 2012
hi,
I was just about to ask this question, glad this has been answered. However, in my project I need to add multiple instance of the class from library dynamically, I know how to do it in AS2 way, can anyone elighten me with AS3 way, specifically with this new addchild(movieclip) function?
thanks!
ActionScript
2.6K
Contributor , Jun 15, 2012 Jun 15, 2012
First check whether you gave the instance name for the button as "mc" in your myMovieClip.
Then write your code same
myMovieClip.mc.addEventListener(MouseEvent.MOUSE_DOWN,showans);  // You can write CLICK event also...
In showans, You have to write like this.
function showans(e:MouseEvent):void
     e.currentTarget.parent.atext.visible = true;
Enthusiast ,
Jun 12, 2012 Jun 12, 2012
Can you paste your code here.
Kartik.
Participant ,
import flash.display.MovieClip;
for (var i:int=0; i<12; i++) {
        // accessing the mc from libray here qmc is linkage name
        myMovieClip = new qmc();
        myMovieClip.x=stage.stageWidth/10;
        myMovieClip.y=stage.stageHeight/3;
        addChild(myMovieClip);
i think all 12 mc are loading in same place, i want to display the mc one by one
Enthusiast ,
You can use it in following way :-
        var myMovieClip:qmc = new qmc();// accessing the mc from libray here qmc is linkage name
        myMovieClip.x=stage.stageWidth/10;//assigning x property
        myMovieClip.y=stage.stageHeight/3;//assigning y property
        addChild(myMovieClip);//adding to stage
Participant ,
Sorry am not finding any difference it is showing the same output
Enthusiast ,
What kind of output you want?
As i have seen your code you are doing it correct apart from the line 1 in for loop which i have corrected.
Kartik.
Participant ,
hi i got the solution for my problem. it is worlking fine.
But i got another problem i don't know how to control the each mc.I want to perform different action with those mc.
for (var i:int=1; i<(len+1); i++) {
        if (i==1) {
            var yval:int=stage.stageHeight/3;
        } else {
            yval=yval+myMovieClip.height+5;
        myMovieClip.y=yval+10;
        myMovieClip.qtext.text=i+". "+ques_arr[i-1];
        myMovieClip.atext.autoSize="center"
        myMovieClip.atext.text=ans_arr[i-1];
        myMovieClip.atext.visible=false;
// here is the problem
Enthusiast ,
Jun 13, 2012 Jun 13, 2012
Hello,
Please try the below mentioned code :-
        if (i==1) {
        } else {
                    myMovieClip.name = "mc"+i // adding name to movieclip
          trace(e.currentTarget.name)//here you will get the name of movieclip you have defined above here you can put a condition check. output will be like "mc1" "mc2" ...
          //here you can write your code to handle different movieclip events
Participant ,
Jun 14, 2012 Jun 14, 2012
This program is not working, when i trace e.currentTarget.name am getting the output as mc, can you please give me another solution.I think problem with for loop
Because when i press any of the mc the out put is coming as mc4
Enthusiast ,
Can you please change this line  myMovieClip.mc.addEventListener(MouseEvent.MOUSE_DOWN,showans); to  myMovieClip.addEventListener(MouseEvent.MOUSE_DOWN,showans); and try again.
Participant ,
Sorry it is not working
Contributor ,
Please explain the problem clearly.  I have some doubts, What do you mean by mc? Whether it is myMovieClip or something else. And different action means for each mc you want to create a seperate action right?
Participant ,
mc is instance of name one button it is there inside the myMovieClip.
For the my myMovieClip when i gave the different name like this myMovieClip.name = "mc"+i
am getting the myMovieClip name as mc1 ,mc2,mc3,mc4
I want to perform one action when i press mc1.mc the myMovieClip.atext should be visible true like wise for mc2..
But it is not happening
Contributor ,
Participant ,
Thanks Its working fine
Contributor ,
You are welcome.
Please mark at the answer as Correct Answer.
