script pulling over another file
Jun 8, 2012 5:28 AM
anyone have a problem where a script will open another script file? I am thinking ES is storing a function somehow across files in a global variable and is trying to run another file to get it rolling. never had this happen really.
any ideas?
    Jun 8, 2012 9:17 AM   in reply to hilukasz
    Is the other script file one of your includes? Does it have any $.write() or $.writeln() that have not been commented out? Have you set any $.level options?
    Jun 9, 2012 12:34 AM   in reply to hilukasz
    no idea, it just happens randomly?
    Jun 12, 2012 7:03 AM   in reply to hilukasz
    From the Illustrator scripting read me
    "An Illustrator error occurred: 1346458189 ('PARM')" alert (1459349)
      Affects: JavaScript
      Problem:
        This alert may appear when carelessly written scripts are repeatedly
        run in Illustrator from the ExtendScript Toolkit.
        Each script run is executed within the same persistent ExtendScript
        engine within Illustrator. The net effect is that the state of
        the ExtendScript engine is cumulative across all scripts that
        ran previously.
        The following issues with script code can cause this problem:
          - Reading uninitialized variables.
          - Global namespace conflicts, as when two globals from different
            scripts have the same name.
      Workaround:
        Be very careful about variable initialization and namespace conflict
        when repeatedly pushing a batch of Illustrator scripts
        for execution in Illustrator via the ExtendScript Toolkit (ESTK) in a
        single Illustrator session.
        Initialize variables before using them, and consider the scope of
        your variables carefully. For example, isolate your variables by
        wrapping them within systematically named functions. Instead of:
          var myDoc = app.documents.add();
          // Add code to process myDoc
        Wrap myDoc in a function that follows a systematic naming scheme:
          function myFeatureNameProcessDoc() {
              myFeatureNameProcessDoc();
