Q&A pod highlight colors
Jan 18, 2012 2:44 PM
My Q&A select color is light green with white text - I can not read it
How do I change it?
  • Jorma Jennings
    Jul 5, 2007
    Jan 18, 2012 3:08 PM   in reply to sailplane89
    The highlight color is the same as your Menu Highlight Color. To change it go to Administration > Customization > Customize Meeting and change the Menu Highlight Color.
    Mar 27, 2012 8:05 AM   in reply to sailplane89
    I am having the same issue. I tried to customize the menu highlight color and it didn't appear to change anything. Does it only work on new meeting rooms created or should the customization change all existing meeting rooms also?
    Thanks.
  • Jorma Jennings
    Jul 5, 2007
    Mar 27, 2012 10:55 AM   in reply to adamhe
    Changing the settings in the Admin panel will affect all exsiting and future rooms.
    Mar 27, 2012 10:59 AM   in reply to Jorma Jennings
    Can you think of any reason it might not work? I've change Menu Highlight Color to black and it still shows up as the faint minty green color.
    Jun 12, 2012 7:34 AM   in reply to adamhe
    I have this same problem on one presenter machine. (Win7 64bit / Chrome 19.0.1084.56 / Flash 11.3.300.254)
    The highlight color is always minty green despite a different setting in the customization settings.  I found it only happened when the connect Add-in was installed, so uninstalled the Connect Add-In using the "Add/Remove programs" or "Programs and Features" option in Windows Control Panel.
    Even after a manual re-install of the Connect add-in, after removing internet files, cookies, flash storage, etc, the highlight color reverted to mint green.  Removing the add-in is an acceptable workaround for me as I don't use screen-sharing.
    Looks like a bug to me.
    Jun 26, 2012 10:23 AM   in reply to sailplane89
    Having same problem with the mint-green and it just suddenly appeared with new Connect Add-In.
  • Jorma Jennings
    Jul 5, 2007
    Jun 26, 2012 10:53 AM   in reply to doofie123
    Rather than uninstalling the add in, you can add ?launcher=false (for example http://realeyesconnect.adobeconnect.com/openroom/?launcher=false) to the URL for the room to tell Connect to not look for the add-in. Then when you need to screen share, you don't append your URL with that qwery string. It will save you from unistalling and reinstalling the add-in multiple times.
