Hi
I want to have a grey bar at the bottom of my pages. So far I have used a graphic with a grey bar on the bottom as a background image in the page properties section of my template. This works well, except I am now finding that some pages need more space than what the graphic will allow. Do I need to use frames to achieve this? (I have seen that Adobe don't recommend using frames). Or is there a way to get another graphic of a grey bar to float up and down according to page size? Please respond in layman's terms as I am still a rookie at DW.
thanks.
L
Do you mean like a Sticky Footer?
Best to keep the height of your page flexible because you'll have some long pages and some short pages in your site.
The following demo shows how to have different background-colors on various sections of your page with CSS.
You can replace background-colors with CSS gradients or repeating image slices.
http://alt-web.com/TEST/LHS-test.html
Nancy O.
Alt-Web Design & Publishing
Web | Graphics | Print | Media Specialists
Hi John
Yes, it’s a sticky footer I want … this is all new to me, but rather exciting! What I am wanting to do is make the grey bar at the bottom of this page float up and down so I need to be able to adjust the height of the code you sent me as well as being able to place a small menu bar (contact us, etc.) and the email response blurb on top of the sticky. Could you elaborate on how to do this.
Thanks so much.
Lyn
http://whiterockchristiansciencechurch.com/bcsitejune3/index.html
This link shows how to make a sticky footer:
http://alt-web.com/DEMOS/CSS2-Sticky-Footer.shtml
CSS:
#footer {
position:fixed;
bottom:0;
left:0;
background-color: #666666;
HTML:
<div id="footer">
This is a sticky footer. Add your footer content here...
</div>
In addition, you'll need to slice your 4-color background image into 4 separate background images.
http://whiterockchristiansciencechurch.com/bcsitejune3/images/sidebar4 .png
Green = #header,
Charcoal = #topMenu,
White = #content
Gray = #footer.
Nancy O.
Thanks Nancy
I think I am clear now on how to make the sticky footer, but your comment about slicing my background graphic into four graphics is puzzling me … I realize I have to take the grey off the bottom as this will now become part of the footer, but why slice the other into three bits? In Dreamweaver ‘page properties’ section, it only gives me the option of placing one background graphic. How would I be able to place more than one graphic as a background image?
Lyn
Copy & paste this code into a new, blank HTML document.
You can change background-colors to background-images or CSS background-gradients if you prefer.
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<title>Untitled Document</title>
<style type="text/css">
body {
font-family:"Lucida Sans Unicode", "Lucida Grande", sans-serif;
font-size: 16px;
margin:0; padding:0;
background-color: #CCC;
#header {
min-height: 100px;
background-color: #099;
#menu {
min-height: 45px;
background-color: #333;
color: #FFF;
#content {
min-height: 500px;
background-color: #FFF;
#footer {
min-height: 100px;
background-color: #666;
color: #FFF;
/**sticky footer**/
position:fixed;
bottom:0;
left:0;
width: 100%;
.section {
width: 880px; /**adjust width as needed**/
margin:0 auto; /**this is centered**/
padding:0 12px;
/**for demo purposes, you can remove the border**/
border: 1px dotted red;
</style>
</head>
<body>
<div id="header">
your header goes here...
</div>
<div id="menu">
<div class="section">
your navigation goes here...
</div>
</div>
<div id="content">
your page content goes here...
</div>
</div>
<div id="footer">
your footer content goes here...
</div>
</body>
</html>
Nancy O.
No. See the test page -
http://www.gws-sandbox.com/test-div_default.html
It appears that the behavior is the same in IE/FF/Opera/Safari (but not in DW's Design view) - Fixed and Absolute positioning requires you to specify a width for the div. Relative positioning does not. I suppose that makes sense. Thanks - I learned something!
Hi Nancy
Thank you for sending me the code …
I am learning Dreamweaver CS4 from the digital classroom manual and in creating a first page it tells you to create a ‘main’ ap box first and then a ‘container’ which wraps the ‘main’ box as well as all the other elements on the page. I am unable to find a ‘container’ in the code you send me so now I am puzzled. I am trying to insert my masthead at the top, but I don’t see a way to keep them lined up with the rest of the body copy -- if I attach them to the ‘header’ in your code, the masthead slides sideways as you size the screen. I would have thought these elements should be inside the container to keep them in position.
I really appreciate your help. Thanks.
Lyn D.
...it tells you to create a ‘main’ ap box first and then a ‘container’ which wraps the ‘main’ box as well as all the other elements on the page.
Any book that instructs you to use APDivs for primary layouts should be burned, OK? I am not joking. Nobody, not even experienced web developers should use APDivs for primary layouts because they are removed from the normal document flow. To illustrate what happens when people increase text size in their browsers (as many do), APDivs collide making a jumbled mess. See screenshot.
In some layouts, it's good to use an outer #container or #wrapper division but it isn't required in all layouts. Yours doesn't need an outer #container so much as it needs an inner one. I created a class for this called .section. The .section div horizontally centers content on screen.
Get rid of Digital Classroom. Learn HTML & CSS first. This is required knowledge.
HTML & CSS Tutorials - http://w3schools.com/
WEB DESIGN RESOURCES:
http://forums.adobe.com/message/4105662#4105662
For your first site, use one of the pre-built CSS layouts that comes with Dreamweaver.
File > New > Blank > HTML > 2-col, fixed layout.
Nancy O.
Hi Nancy:
Oh dear, your comments about the Digital Classroom which I had thought would be the ‘bible’ to learn Dreamweaver are most discouraging! I will check out the w3schools. Thanks for your patience … I would still like to know, though, if you’re available for private, paid consultations per my email to your company.
Thanks.
Lyn
