cs5 Advanced Photo Album Template Live Links
Jun 12, 2012 10:58 AM
Tags: none (add) #as3 #xml #actionscript #flash_cs5I'm using this template as a "quick & dirty" content slider for my website. I got everything to work great, there's no issues with it's functionality or actionscript. I would just like to make each image a "clickable" link. I got 4 images that I want to take users to 4 separate webpages, I've searched and searched for answers but most are over my head. Is there anybody that could help me? Here's the actions:
import fl.data.DataProvider;
import fl.events.ListEvent;
import fl.transitions.*;
import fl.controls.*;
// USER CONFIG SETTINGS =====
var secondsDelay:Number = 7;
var autoStart:Boolean = true;
var transitionOn:Boolean = true; // true, false
var transitionType:String = "Fade"; // Blinds, Fade, Fly, Iris, Photo, PixelDissolve, Rotate, Squeeze, Wipe, Zoom, Random
var hardcodedXML:String="<photos><image title='Your Choice'>image1.jpg</image><image title='Quick Option'>image2.jpg</image><image title='New Product'>image3.jpg</image><image title='Get Started'>image4.jpg</image></photos>";
// END USER CONFIG SETTINGS
// DECLARE VARIABLES AND OBJECTS =====
var imageList:XML = new XML();
var currentImageID:Number = 0;
var imageDP:DataProvider = new DataProvider();
var slideshowTimer:Timer = new Timer((secondsDelay*1000), 0);
// END DECLARATIONS
// CODE FOR HARDCODED XML =====
imageList = XML(hardcodedXML);
fl_parseImageXML(imageList);
// END CODE FOR HARDCODED XML
// EVENTS =====
imageTiles.addEventListener(ListEvent.ITEM_CLICK, fl_tileClickHandler);
function fl_tileClickHandler(evt:ListEvent):void
imageHolder.imageLoader.source = evt.item.source;
currentImageID = evt.item.imgID;
playPauseToggle_mc.addEventListener(MouseEvent.CLICK, fl_togglePlayPause);
function fl_togglePlayPause(evt:MouseEvent):void
if(playPauseToggle_mc.currentLabel == "play")
fl_startSlideShow();
playPauseToggle_mc.gotoAndStop("pause");
else if(playPauseToggle_mc.currentLabel == "pause")
fl_pauseSlideShow();
playPauseToggle_mc.gotoAndStop("play");
next_btn.addEventListener(MouseEvent.CLICK, fl_nextButtonClick);
prev_btn.addEventListener(MouseEvent.CLICK, fl_prevButtonClick);
function fl_nextButtonClick(evt:MouseEvent):void
fl_nextSlide();
function fl_prevButtonClick(evt:MouseEvent):void
fl_prevSlide();
slideshowTimer.addEventListener(TimerEvent.TIMER, fl_slideShowNext);
function fl_slideShowNext(evt:TimerEvent):void
fl_nextSlide();
// END EVENTS
// FUNCTIONS AND LOGIC =====
function fl_parseImageXML(imageXML:XML):void
var imagesNodes:XMLList = imageXML.children();
for(var i in imagesNodes)
var imgURL:String = imagesNodes[i];
var imgTitle:String = imagesNodes[i].attribute("title");
imageDP.addItem({label:imgTitle, source:imgURL, imgID:i});
imageTiles.dataProvider = imageDP;
imageHolder.imageLoader.source = imageDP.getItemAt(currentImageID).source;
title_txt.text = imageDP.getItemAt(currentImageID).label;
function fl_startSlideShow():void
slideshowTimer.start();
function fl_pauseSlideShow():void
slideshowTimer.stop();
function fl_nextSlide():void
currentImageID++;
if(currentImageID >= imageDP.length)
currentImageID = 0;
if(transitionOn == true)
fl_doTransition();
function fl_prevSlide():void
currentImageID--;
if(currentImageID < 0)
currentImageID = imageDP.length-1;
fl_doTransition();
function fl_doTransition():void
if(transitionType == "Blinds")
TransitionManager.start(imageHolder, {type:Blinds, direction:Transition.IN, duration:0.25});
} else if (transitionType == "Fade")
TransitionManager.start(imageHolder, {type:Fade, direction:Transition.IN, duration:0.25});
} else if (transitionType == "Fly")
TransitionManager.start(imageHolder, {type:Fly, direction:Transition.IN, duration:0.25});
} else if (transitionType == "Iris")
TransitionManager.start(imageHolder, {type:Iris, direction:Transition.IN, duration:0.25});
} else if (transitionType == "Photo")
TransitionManager.start(imageHolder, {type:Photo, direction:Transition.IN, duration:0.25});
} else if (transitionType == "PixelDissolve")
TransitionManager.start(imageHolder, {type:PixelDissolve, direction:Transition.IN, duration:0.25});
} else if (transitionType == "Rotate")
TransitionManager.start(imageHolder, {type:Rotate, direction:Transition.IN, duration:0.25});
} else if (transitionType == "Squeeze")
TransitionManager.start(imageHolder, {type:Squeeze, direction:Transition.IN, duration:0.25});
} else if (transitionType == "Wipe")
TransitionManager.start(imageHolder, {type:Wipe, direction:Transition.IN, duration:0.25});
} else if (transitionType == "Zoom")
TransitionManager.start(imageHolder, {type:Zoom, direction:Transition.IN, duration:0.25});
} else if (transitionType == "Random")
var randomNumber:Number = Math.round(Math.random()*9) + 1;
switch (randomNumber) {
case 1:
break;
case 2:
break;
case 3:
break;
case 4:
break;
case 5:
break;
case 6:
break;
case 7:
break;
case 8:
break;
case 9:
break;
case 10:
break;
} else
trace("error - transitionType not recognized");
if(autoStart == true)
