Can I edit the HTML that Muse exports in an HTML editor like Dreamweaver or Coda?
Jun 12, 2012 12:35 PM
If I create a site in Muse, can I export the HTML and pass it along to a web developer to add additional hand-coding?
    Mar 18, 2013 4:19 PM   in reply to Adobe Muse FAQ
    We use a service called Stat Counter where you have to add in HTML code in the <body> under the </div>. Is there a way to do this within muse?
    Mar 18, 2013 11:39 PM   in reply to zeusca47
    Choose Object > Insert HTML. In the window that appears, select the default placeholder text and Press Delete (Mac) or Backspace (Windows) to remove it. Choose Edit > Paste to paste the HTML code  into the HTML Code field. Click OK to close the HTML Code window.
    For detailed Instruction you can follow the article http://www.adobekb.com/building_your_first_website_pt04.html#inserting
    Hope this helps
