chris.rossini
Install Adobe Premiere Elements 10 using the setup.exe in the root folder
Jun 12, 2012 12:01 PM
Tags: #deployment #premiere_elements_10
I am trying to make an SCCM install package for PremiereElements_10_LS15_win64. I am following the directions I found here http://helpx.adobe.com/photoshop-elements/kb/silent-install-instructio ns-photoshop-elements-1.html and I am using a Win7 SP1 machine with a new NT profile that does have admin rights. The error I receive is, "Install Adobe Premiere Elements 10 using the setup.exe in the root folder."
Also, when I try to use AAMEE 2.1 I am told that when I use the containing the setup.exe and the .msi that "A valid installer could not be found."
    Jun 12, 2012 1:55 PM   in reply to chris.rossini
    Hi Chris,
    First of all, you will not be able to package PSE 10 using AAMEE. It needs to be packaged only using the xml method, that you tried and got the error.
    So, here is want i want you to try.
    > Take a Win 7 machine with a fresh OS installation.
    > Follow the above article that you have properly i.e. create the application.xml.override.
    > Test the xml package by running the command mentioned under step 2 using the command prompt.
    Check if that works.
