Does Creative Cloud support locally installed Plugins?
Hello Arpit:
I work for Roland DGA Corporation and we use Adobe Plugins to run some of our devices. Specifically, we have an application called CutStudio that has an export module plugin. We also have our own custom Color Libraries (one example Roland Color Library – which I have attached).
We are not sure if these Swatch Libraries and Plugins will work with the Cloud Version of Illustrator.
Thank you,
Scott
Scott Burgess
Field Engineer, NE
Roland DGA Corp.
Tel: 949-727-2100 x1393 TollFree: (800) 542-2307 Fax: (949) 655-5693
cid:image001.jpg@01CD47E8.D0B12EF0<http://www.rolanddga.com/products/printers/re/
They should work fine.
No reason why they wouldn't.
Cloud products are locally installed the same as the perpetually licensed products always have been. They just phone home on a monthly basis to check your subscription is up to date.
Hi Sclatbomb,
As John also stated, ideally it should work just fine as there is no difference between the perpetual product and the creative cloud one. They both work the same way as the application is installed on the machine itself. Cloud just gives an opportunity to install and use the applications from anywhere including the storage space for taking your files with you.
Hope that Clarifies your doubt.
