matthew_miller
Indesign for print set up
Jun 12, 2012 2:16 PM
I am currently working on a project containing a variety of print media, all of which will be exported as a pdf directly from Indesign.  What I dont understand is which colour profile to set for each of my prgrams within creative suite (obviously these all need to be the same).  I aim to send these to a printer within the U.K, how do I select the correct profile? Does it really make a big difference?
  • lilia@
    Jan 31, 2012
    Jun 12, 2012 2:21 PM   in reply to matthew_miller
    Use Adobe Bridge to sync the colour settings. Edit > Color Settings
    Contact the printer and ask them what they require.
  • Rob Day
    Oct 16, 2007
    Jun 12, 2012 6:48 PM   in reply to matthew_miller
    Any time there's a color conversion profiles come into play, so to display CMYK on screen there needs to be a conversion to RGB or to get the correct separation for a given press condition there has to be a conversion from RGB to CMYK.
    The difference can be very significant like the difference between RGB display of Japan Standard and US Sheetfed Coated:
    Japan Standard
    US Sheetfed
    Jun 12, 2012 7:52 PM   in reply to matthew_miller
    For print work in the UK or Europe, I would suggest using "Europe Pre Press 2 (FOGRA 27)" as your profile as you are more likely to find a local printer using this or a similar profile. However, if you are concerned, you could always ask the printer and see what profile they suggest.
    This link might give you some help with print work: http://www.smashingmagazine.com/2009/10/27/10-pre-press-tips-for-perfe ct-print-publishing/
