adding mc from libray to the stage by using one linkage name
Jun 11, 2012 11:57 PM
hi,
I was just about to ask this question, glad this has been answered. However, in my project I need to add multiple instance of the class from library dynamically, I know how to do it in AS2 way, can anyone elighten me with AS3 way, specifically with this new addchild(movieclip) function?
thanks!
    Jun 12, 2012 12:14 AM   in reply to lalitha subramanian
    Can you paste your code here.
    Kartik.
    Jun 12, 2012 12:26 AM   in reply to lalitha subramanian
    You can use it in following way :-
    for (var i:int=0; i<12; i++) {
            var myMovieClip:qmc = new qmc();// accessing the mc from libray here qmc is linkage name
            myMovieClip.x=stage.stageWidth/10;//assigning x property
            myMovieClip.y=stage.stageHeight/3;//assigning y property
            addChild(myMovieClip);//adding to stage
    Jun 12, 2012 12:46 AM   in reply to lalitha subramanian
    What kind of output you want?
    As i have seen your code you are doing it correct apart from the line 1 in for loop which i have corrected.
    Kartik.
    Jun 13, 2012 8:14 AM   in reply to lalitha subramanian
    Hello,
    Please try the below mentioned code :-
    for (var i:int=1; i<(len+1); i++) {
             myMovieClip = new qmc();
            if (i==1) {
                var yval:int=stage.stageHeight/3;
            } else {
                yval=yval+myMovieClip.height+5;
            myMovieClip.y=yval+10;
            myMovieClip.qtext.text=i+". "+ques_arr[i-1];
            myMovieClip.atext.autoSize="center"
            myMovieClip.atext.text=ans_arr[i-1];
            myMovieClip.atext.visible=false;
                        myMovieClip.name = "mc"+i // adding name to movieclip
    // here is the problem
            myMovieClip.mc.addEventListener(MouseEvent.MOUSE_DOWN,showans);
    function showans(e:MouseEvent):void
              trace(e.currentTarget.name)//here you will get the name of movieclip you have defined above here you can put a condition check. output will be like "mc1" "mc2" ...
              //here you can write your code to handle different movieclip events
    Jun 14, 2012 8:17 AM   in reply to lalitha subramanian
    Can you please change this line  myMovieClip.mc.addEventListener(MouseEvent.MOUSE_DOWN,showans); to  myMovieClip.addEventListener(MouseEvent.MOUSE_DOWN,showans); and try again.
    Jun 14, 2012 9:16 PM   in reply to lalitha subramanian
    Please explain the problem clearly.  I have some doubts, What do you mean by mc? Whether it is myMovieClip or something else. And different action means for each mc you want to create a seperate action right?
    Jun 15, 2012 2:08 AM   in reply to lalitha subramanian
    First check whether you gave the instance name for the button as "mc" in your myMovieClip.
    Then write your code same
    myMovieClip.mc.addEventListener(MouseEvent.MOUSE_DOWN,showans);  // You can write CLICK event also...
    In showans, You have to write like this.
         e.currentTarget.parent.atext.visible = true;
    Jun 15, 2012 4:45 AM   in reply to lalitha subramanian
    You are welcome.
    Please mark at the answer as Correct Answer.
