New PC for Adobe CS6
Jun 9, 2012 7:45 PM
Tags: #hardware #creative #cs6 #cloud
OK, I know I have not been around in a long time, but I need some help. I have read a tremendous amount of online material regarding the components I want for a new editing PC to use with the Creative Cloud.
Rather than clog up the forums, I put up a page with the specs I am looking at, set up an email address for suggestions and an email address for integrators to use if they want to quote it. I want to pull the trigger on Friday June 15th.
I would really appreciate it if some of you would take a look and let me know what you think. I am OK with what I listed on the page, but I want you all to poke holes in it if I have made a mistake.
I would also appreciate some quotes. Either for the system as shown, or one that is along the same lines using your own suggestions.
If you think your suggestions warrant everyone seeing them, please feel free to put them here.
And yes, I really do plan on cleaning up my web site and bringing it current.
Steven Gotz
http://www.stevengotz.com/New_PC_for_CS6.htm
Replies 1 2 Previous Next
    Jun 9, 2012 10:49 PM   in reply to Steven L. Gotz
    Hi Steven.
    I am researching a similar build for a friend but leaning more towards photgraphy 70%, video 30%.   Can you leave you link ofr quotes as is, but get suggestons on the forum as there is no way to see how your build developes.
    One issue seems to be with the i7 3930K and finding a stable RAM.
    Jun 10, 2012 3:55 AM   in reply to Steven L. Gotz
    Steven,
    Welcome back. We missed you and all your valuable input.
    Have a look here Comparing G.Skill memory modules.
    From this page I derive that your choice of memory may well work. I mean certified on the X79 Asus boards indicates a certain confidence that it will work, which of course with that price it should. I have not yet heard whether there are more people using this type of memory. I know one person uses the Ripjaws Z 1600 modules without any problem, even though the Newegg site does not mention that they are certified, like the 2133 sticks. I would not choose the 2400 sticks because of the 1.65V. I hope Eric can have a look as well and give us his opinion.
    Instead of the H80, I would consider the H100 if you opt for watercooling. Given your choice of memory sticks, it makes sense to assume you intend to overclock the system, and then the bigger radiator of the H100 can show its advantage over the H80.
    If you intend to edit RED 4K or Epic 5K material somewhere in the future, I would look at a 4 GB GTX 680, not the 2 GB model.
    Out of curiosity, why the choice of an Atto card? Atto is one of the best cards there is, but what differentiates Atto from all other cards is their support for Raid4.
    I have told you about Planning and Building a new NLE System but at this moment the groundwork has been done and I'm in a holding pattern now, testing my patience. I am waiting for new announcements about an Ivy Bridge-E successor of the SB-E, the Areca ARC-2082iX-24 PCIe-3.0 card, and possibly a 384 bit video card of the 68x generation.
    If you have any more questions, you know how to reach me. Good luck with your build.
    Jun 10, 2012 5:46 AM   in reply to Steven L. Gotz
    Steven,
    Power Supply - make sure you specify a brand name or names; 1000w units from different vendors can vary from horrible to excellent
    RAM - agree with Harm's suggestion; in general, for the 3930k's memory controller I think that most users are finding they can run 64GB up to 1333 or 1600 MHz (DDR3 2133 may work, but not when you fully populate to 64GB with RAM that you can purchase at this time)
    RAID card - the ATTO is a high quality RAID card, however your build plan does not utilize it at all. Either add some more drives (5x2TB with current generation drives and a fast controller should actually perform quite well with "all" files on it) and plan for RAID 5, or dump the controller card all together and make sure your motherboard choice has enough SATA connections, and RAID 0 capabilities to connect all of your drives.
    Boot SSD(s) - suggest 120GB or 128GB SSD for you boot drive(s); that should be plenty large enough and will save just about 1/2 the cost of SSDs twice that size
    Jim
    Jun 10, 2012 11:29 AM   in reply to JEShort01
    Hi Steven. I am also in the same position as you. Since I want to be prepared to work with ANY kind of media (from AVCHD to Red / Epic) I opted for the Sandy Bridge EP 2687W system for the extra power to deal with such large files. I just want to be able to deal with whatever life throws at me    I also do lots in AE so am going for 64GB ram and the most powerful GPU which will benefit me both in Premiere Pro (CUDA)  and AE (new Ray Tracing mode) which is the Nvidia Maximus (Quadro 4000 and Tesla 2075).
    Here are the specs for the system I am have Puget Systems build for me. FWIW.
    Jun 10, 2012 8:31 PM   in reply to Steven L. Gotz
    Steven it seems our needs for projects are different.
    Jun 10, 2012 9:32 PM   in reply to Steven L. Gotz
    My needs are different as well so, while keeping an eye on this thread, I will start my own.
    Jun 11, 2012 9:04 PM   in reply to Steven L. Gotz
    Heres a couple of aspirin. I feel your pain.
    Jun 12, 2012 3:02 PM   in reply to Steven L. Gotz
    I did not realize how much confusion explaining the current ram issues was going to create.
    Prebuilt - If a system integrator is recommending ram based on your requirements then you want to go with what the integrator recommends. The integrator is assuming the responsibility of support for the entire configuration as you purchase it. If you are buying a system from them then you are already assuming they have tested the ram as they configure it with the specific ram they use. The integrator may be using a default configuration for the bios which uses the base profile from the ram along with the base speed. If that is 1066 or 1333 then it will likely work with most modules on the X79. If the integrator is loading the extreme profile with speeds of 1600 or greater then you are assuming they have tested and are willing to support that configuration. The support staff is going to be familiar with the hardware they recommend and would best be able to support you with that hardware. So if that integrator recommends 8GB sticks for their system then I recommend you go with their recommendation.
    DIY - The memory compatibility information and likely pitfalls we posted about were mainly for the DIY editors. Since we have a much larger scope of hardware tested, we can give pre-emptive warnings to those who DIY so they know what is working and what is not. We are simply stating this is what works 100% and this is what you are rolling the dice with and why. If you decide to buy ram that does not work at 1600 and you cannot return it then there is a very good chance you can get it to work at 1066 or 1333 depending on what the base profile is set to. The key though is making sure the OS is installed without memory corruption. So if you find issues with the ram at 1600 or higher then you may have to re-install the OS. You can also install the OS at base profile  after memtesting the ram and then enable the XMP profile for the higher speed after when you can test from the OS. However if people are not aware of what to look for then they can spend a ridiculous amount of time just isolating the problem before the fix is even in place. That was the reason for the information for the DIY.
    I hope that helps clarify and ease the confusion.
    Eric
    ADK
    Jun 13, 2012 5:24 AM   in reply to Steven L. Gotz
    Nice to have you back, Steven.
    Most of the old gang is gone, but Ann Bens is still here, as well as John T. Smith.
    I'm glad you've got the time and means to start playing with this stuff again.
    Jeff
    Jun 13, 2012 8:42 AM   in reply to Steven L. Gotz
    >lot of temporary files (and the Registry) on to the SSD
    I don't use SSD (built my CS5 computer about 2.5 years ago) but I do spread the file load over 3 drives
    Including having the Windows swap/page file on non-boot drive AND telling PPro to use non-boot drive for temp files
    Drive C space http://forums.adobe.com/thread/1007934?tstart=0 for PPro temp file location... which I set to my project drive
    I found instructions for moving swap/page file at http://search.microsoft.com/search.aspx?mkt=en-US&setlang=en-US - if you don't already know how
    I use about 60Gig on my boot drive for Win7 + CS5 MC + MS Office + other small programs + the usual My Documents folder
    Jun 13, 2012 8:56 PM   in reply to Steven L. Gotz
    Looks great... with that, you'll be ready to film-edit-produce the next generation of Star Wars "like" movies!
    Jun 14, 2012 6:19 AM   in reply to Steven L. Gotz
    Congrats. Looks like Eric has set you up with a fine machine!
    Jun 14, 2012 9:11 AM   in reply to Steven L. Gotz
    Looks like an excellent system, Steven, and it's good to have you back in the forums.
    Jun 19, 2012 4:34 AM   in reply to Steven L. Gotz
    I would recommend looking into Acronis TrueImage for system and file backups.
    Jun 19, 2012 8:30 AM   in reply to Steven L. Gotz
    The product I use for full drive backup/restore is at http://www.terabyteunlimited.com/image-for-linux.htm
    Image runs off of a bootable CD via Linux (the Zip you download includes a program to make the bootable CD) and it reads EVERYTHING on the drive, even the hidden registration information, so everything is restored when needed... and you may restore the image to a brand new drive in case of a crash, and not have to re-install anything
    Jun 19, 2012 8:46 AM   in reply to Steven L. Gotz
    Steve,
    Thanks and I expect to see some great PPBM scores from this wonderful system!  Wish I could join the x79 club.  Maybe I will have to sell my i7-3770K that I have posted a PPBM5 score with CS6.
    Jun 21, 2012 5:49 AM   in reply to hesseli
    Acronis, attention:
    till (15.6.2012) i updated my NLE i was running;
    ASUS P6T WS (socket 1366), i7960, C:/ SSD Vertrex 3
    i was able to clone 1:1 C-drive operationg System with ACONIS 2010 without any problems. the clone was running perfect.
    After having updated to
    ASUS P9X WS  (socket 2011), i73930k, C:/SSD Vertex 3
    it was not able to clone with ACONIS 2010.
    I updated to ACONIS 2012 and cloning also was not possible.
    the clone problem i still could not solve
    klfi
    Jun 21, 2012 5:59 AM   in reply to klfi
    Thanks for reporting that, Klaus. Makes me wonder if John has better luck with his Linux solution.
    Jun 21, 2012 6:09 AM   in reply to klfi
    Do you have the addon pack for Acronis 2012?
    That might be the reason. Addon pack has ability to install the backup to a new pc.
    BTW I was looking a new motherboard and got interested on Asus P9X79 WS. Is yours that too and are you happy?
    Jun 21, 2012 11:39 AM   in reply to hesseli
    ASUS P6T WS
    Acronis 2010 worked in clone modus perfect.
    ASUS P9X WS
    Acronis 2012 + addon package ist installed on my system and does not work in clone modus. I dont have any idea why.
    Is it ASUS or is it Acronis ??
    Acronis 2012 works fin in normal backup and restore modus, but this is not interesting for me. I want a 1:1 clone of C./drive. This is in my opinion the easiest way to secure C-drive. In emergy case put the old drive (SSD Vertrex 3) out und the clone (cheep HDD 320 GB 7200) inside. Sytem runns again. Then clone HDD 320 back to SSD Vertrex 3.....and you will be happy in minutes
    ASUS P9X WS experience.
    Very good, I would by it again. Everything you need is there.
    I run 64 GB RAM, 2x Nvidia 570, 1x Areca 1680i (12 connections), 1x Blackmagic multibride card..... and there is still one free slot to use in future.
    Installation is easy, ASUS OC tool helps to OC my 3930K for first experiances. At the moment i run 4,3 GH. max themperature +/- 75, Coolmaster watercooling H (?) 100.
    But - only my personal oppinion. I dont like this Marvel- stuff. For me its too difficult to handle via bios and is f__ to handl.
    Follow Harms general recommendation, go ahea to areca+BPM, a little bit expensive to get, but worth the money. Easy to install (even if you are unexperiance like i), easy to setup multiple Raid and Volumes. also multiple pass throu is possible, Easy to expand or change raid.. I run 1x Raid 0 7TB + 1x Raid3 3TB + 2x pass throu. All this since 2,5 years, not one problem.
    I for myself would by it again.
    Feel free to ask.
    Klaus klfi
    Message was edited by: klfi sorry not coolmaster but corsair
    Jun 21, 2012 9:23 PM   in reply to klfi
    I'm not sure but if i understood correctly it should work so that you take a full backup of c:\ drive and boot from acronis bootdvd in case of c:\ drive crash. The restoring with that transfer option. You should contact Acronis about your cloning problem.
    Thanks for the info.
    Jun 22, 2012 5:41 AM   in reply to hesseli
    no you missunderstood. your workflow works, but its not the elegant way-in my opinion
    My wokflow:
    1. open acronis and go to clone (not to backup)
    2. say acronis to clone C:/ to drive X./ (for example)
    3. NLE shuts down and makes 1:1 copy of C./. (means X;/ drive is a 1:1 bootable drive of C:/)
    4. i secure X:/ outside my NLE
    5, when C./ does not work, i put out C./ and put in X:/    (X:/ runns 100% same as C:/)......no restorage with acronis is necessary.
    you have to change in Bios boot from X:/.
    In other words i have 2 C:/ dirves with same status (one is original C:/, one is 100% clone and called X:/)
    in earlier workflows i had problems with workflow you described. i did backup C:/ but later restore did not work properly.
    Klaus klfi
    Jul 4, 2012 7:37 AM   in reply to Steven L. Gotz
    Steven L. Gotz wrote:
    I spoke with Eric today. My PC is in testing. I should have it early next week.
    He just wanted to make sure I wasn't planning on using the second SSD for anything other than a copyt of my boot drive. I know it sounds a little nuts, but I have always wanted a perfectly clean copy of a boot drive I could revert to after beta testing or trying out lots of different software.
    Steven, your progress is great and your configuration is very logical.  I must tell you that I have at least 3 or 4 boot drives that have been used as we transition between versions and for instance, proving that with PPBM there is no performance difference between SSD and hard drive for boot drive usage.
    It has happened so often that I have my boot drives on removable "mobile" mounts.  For instance if we ever have to consider Windows 8 (heaven forbid) that will mean cleaning up one of the older Win 7 boot drives and loading Win 8 on it.  Then with just normal boot-up time I can have it almost instantaneously back to Win 7.  That would then be accomplished faster on the SSD's
    Jul 4, 2012 10:10 AM   in reply to Steven L. Gotz
    Sounds like exciting times Stephen!
    I am also waiting on the delivery of my new edit system...the HP Z820. I went for the dual CPU approach due to the nature of my work flow.
    I was initally considering several vendors to build a system (ADK - Eric is a master and a very nice guy, Puget Systems - Very classy operation) but something happened last week with my current Mac Pro that changed my perspective.
    The other day I had a bad experience with the PSU on my Mac Pro that has really made me sit down and think. It started acting weird in the middle of an edit session, but at that point I didn't know what it was. I had to call Apple for $60 for them to try to interpret my symptoms. The next day , after figuring out the problem, I had to start running around looking for an Apple store to drag the machine to. And they had to have the part in stock. Then I had to wait a few days until they fixed it!
    What this made me realize is I need a situation where repair folks familiar with my machine will come to me in a timely fashion. They need to know the machine and be able to swop out parts. I can't be sending the machine out for repairs. This requirement changed my original plans of getting a custom machine.The HP Z820 is widely used in professional circles and has 24 hour repair service that will come to my house to fix whatever ails it.
    In deadline situations with nervous clients on your back, this kind of service reeally gives me peace of mind.
    I look forward to hearing more about your new system!
    Jul 4, 2012 1:33 PM   in reply to Steven L. Gotz
    Actually its in one of my many dialogs with Eric that I learned that to much memory can be counter productive. So I ONLY populated the system with 64GB, more than enough for my PrP and AE needs, at the moment.
    I go the Sandy Bridge EP 2687 3.1 dual CPUs. After 30 years at facilities Im on my own and need power to cover all the possibilities of media (H.264 to Red).
    I went with the external Caldigit HD Pro2 system at 16TB. It gave me lots of R/W speed and storage.
    I should get the machine in the next week. The one thing I find very cool is the HP Performance Advisor. Not only does it display system info for troubleshooting when necessary. It allows you to customize the bios to the software you are using. This was developed by HP, Adobe, Nvidia and other vendors to allow users to configure the system in the most optimal fashion, depending on what software they were using at the moment.
    I will keep you posted on my experience.
    After thought.. the PPBM is a very interesting way to gauge system performance, but there is a catch.
    It reminds me of a car rally. Bigger engines, super fuel and monster tires. Yes those computers go from 0-60 in a very fast fashion. I see my edit system as a big truck, able to do heavy lifting and reliable for the long haul, with damn good speed on the highway
    As a long time editor in touch with lots of other folks working at facilities and now some on their own, I dont know hardly any editors that overclock their systems.
    I know that is where a lot of the systems on the PPBM that get their great results from , but it doesnt seem to reflect my real world expereince of 7 days a week / 12 hours a day use. It obviously works for many folks to overclock, but every facility engineer I know is not in favor of that procedure. That is another reason I went with what I did.
    I understand there are lots of different niches of editors here, with different work flows. And I say do what ever works for you. But I personally will not overclock a system. Each to their own
    Jul 4, 2012 1:38 PM   in reply to Steven L. Gotz
    Im sure it will be great!
1 2 Previous Next
Actions
