Hi - all of a sudden, successful code that I've been using daily, is throwing an error that reads:
Attribute validation error. | |
| A duplicate attribute VALUE has been encountered. Attributes with the same name cannot be provided more than once. | |
Now then, I do not understand the above message at all.
In the first instance (on application 1), this is where the code stops:
30 : <cfif next IS 1>
31 : <cfinclude template="admin/admin_tags/_getNames.cfm">
32 : </cfif>
33 :
In the second instance (application 2), this is where it stops:
The error occurred in E:/inetpub/wwwroot/littleviews/blogin.cfm: line 31
29 :
31 : <cfinclude template = "_accessName.cfm">
32 : </cfif>
33 :
I'm also having trouble with <cfinclude. I tried "including" a different filename that resides in the same directory and CF tells me that it can't find the file.
As I use <cfinclude in a lot of places on other pages, I am NOT having a problem with it. But I'm am having a problem with the two applications above.
Karen
Good advice, Adam. I checked my <cfinclude> line by line and did find a problem.
At the moment, my problem is not resolved. I know a number of things that are NOT my problem at the moment (smile) and the only thing I can think of is that somehow I came to use a reserved word. So, now I'm changing the names of all my variables to see if that helps.
I'm inching along with tests ending in <CFabort>
At first, I thought that there was something about CF8 that made extracting information out of queries different, but if that was the case, my whole site would come down.
Should I find that I did trigger a reserved word, I'll post it here.
Karen
o mah gawd in heven . . . between the time my code worked perfectly and when it stopped, I accidentally placed a <cfqueryparam in a <cfcookie tag.
Thanks for pointing me in the right direction! My CF skills are rusty. I use them every 6 months or so and it shows.
That said, session variables (the few I had) no longer work and I've had to replace them with cookie variables. Session variables would not carry over from page to page.
You can avoid that sort of approach by using the Code Analyser or CFCOMPILE. This sort of thing is a compile-time issue, so one doesn't need to run the code in context, simply see if the file compiles or not. Both the C/A and CFCOMPILE will check all your code in one fell swoop.
Adam
I think you should pretty much try to fix whatever the issue is with sessions, rather than fall back to using cookies...
Adam
I used to create dynamic websites for industry, but now I'm just maintaining a few personal and small client sites. In April, a spammer found a hole in my main site (mine along with hundreds of thousands of others), and left it's mark in my database. As I'm personally changing directions, I decided to shut down all my interactive areas, with just a few personal portals for myself. Should I get back into coding full time, I'll definitely look for those tools (she said sobbing, remembering Homesite). In the meantime, www.LetsKickScoot.com . . .
