Resizing text frames and photo containers issue
Jun 13, 2012 8:08 AM
Tags: #frame #resize #cs6 #frames_size #indesign_cs6
I upgraded to InDesign CS6 yesterday and I am having some workflow issues with the way that InDesign is handling resizing text frames and photo containers.
In CS5.5 (and all other versions of InDesign I have used) when I resize a text frame with overset text, as I pull the bottom handle down I can see the text dynamically popping up as the box becomes longer. Also, with photo containers holding an image larger than the frame, as I pull the frame handle I can see the image filling the space as it grows.
In CS6 I do not see the overset text or the additonal photo area until I release the handle. Is there a setting that I can change to make this behave more like all of the other versions of InDesign?
    Jun 13, 2012 8:17 AM   in reply to brandonschuk
    What you see is dependent on how you have Live Screen Drawing set in your Preferences. Try clicking and holding then waiting a moment before starting to drag.
