how to replace Acr 6.7 by Acr 6.6
Jun 12, 2012 8:53 AM
I've Ps CS5 with Acr 6.7 (update from 6.6 to 6.7 a few days ago).
I want to replace Acr 6.7 by Acr 6.6 back.... because of the lenscorrections-panel.
The controls for finging are missing... I want them back.
The new finging options in Acr 6.7 does not work (or... I can see NO the difference............)
I've tried to install "AdobeCameraRaw-6.6-mul-AdobeUpdate" but that fails with the message: "some updates are not installed".... and "the following updates are not installed" ....and  "Photoshop Camera Raw 6.6 Update"...and "installation has failed"
>>> how to replace acr 6.7 by Acr 6.6 back?
    Jun 12, 2012 2:30 PM   in reply to Fred K.
    Macintosh or Windows?
  • Noel Carboni
    Dec 23, 2006
    Jun 12, 2012 3:17 PM   in reply to Fred K.
    I just did exactly this myself on my Windows system in the process of doing some timing measurements between different versions.
    This is how, in a nutshell, it can be done on a Windows x64 system:
    • Download the .zip file that contains the Camera Raw 6.6 update
    • Find the zip files encapsulated inside that carry the content of the Camera Raw.8bi files.  They're easy to spot because they're large.
    • Unzip each file (one for 32 bit and one for 64 bit) and copy the numbered resource file inside to the appropriate Camera Raw.8bi file.
    Here's what goes where:
    32 bit
    Copy:  payloads\AdobeCameraRaw6.0All-011211024650\Assets2_1.zip  (file within: 1003)
    To:      C:\Program Files (x86)\Common Files\Adobe\Plug-Ins\CS5\File Formats\Camera Raw.8bi
    64 bit
    Copy:  payloads\AdobeCameraRaw6.0All-x64-011211031019\Assets2_1.zip  (file within: 1002)
    To:      C:\Program Files\Common Files\Adobe\Plug-Ins\CS5\File Formats\Camera Raw.8bi
    -Noel
  • Noel Carboni
    Dec 23, 2006
    Jun 13, 2012 9:21 AM   in reply to Fred K.
    Glad you were able to revert to a version of Camera Raw that works better for you.
    Just to be complete, you HAD used the checkbox to invoke the automatic functionality, right?  It was listed under the Profile tab, but I believe it was not actually profile-based.  Generally speaking if the CA isn't too bad it does a pretty good job of lining up the colors.
    Adobe has been particularly balky about admitting that their recent changes to de-fringing are causing the product to backslide.
    At least one other person has noted that they no longer are able to clean up their color-fringing at all because of the removal of the manual controls. See also: http://forums.adobe.com/thread/1002680
    I have personally dropped back to Camera Raw 7.0 from 7.1 because of pooly conceived de-fringing changes that have gone into 7.1, and which cut off older functionality that I relied upon - similar to what you've done.
    Apparently those of us pointing out these reductions in functionality are being summarily dismissed as "resistant to change", which I find irritating.  See the comment by Eric Chan near the end of this thread: http://forums.adobe.com/message/4451203#4451203
    -Noel
