XELAD111
public var and External swf
Jun 13, 2012 8:14 AM
Hello!
I have some problem with vars. The situation is the same I wrote here Re: External swf
I have public var (for example ZZZ) in code of MAIN.swf (main class is Main.as), and I want to access it from code of loaded EXTERNAL.swf.
But nothing helps, flash says:
there is no ZZZ in code of Main
there is no ZZZ on stage.root
there is no ZZZ in any parents.
But if a have ZZZ in code of EXTERNAL, and want to access it from MAIN,  (the reverse situation), ZZZ is easily found.
  • kglad
    Jul 21, 2002
    Jun 13, 2012 8:26 AM   in reply to XELAD111
    your variable is defined on the main timeline of MAIN.swf so you just need a path to it.
    that exact path depends on the scope of EXTERNAL's loader.
    (and, of course, you need to make sure that variable is defined before trying to reference it.)
  • kglad
    Jul 21, 2002
    Jun 13, 2012 12:05 PM   in reply to XELAD111
    you're welcome.
