Jollestudio
Video becomes smaller after exporting
Jun 5, 2012 6:37 PM
I use the Adobe Premiere Elements 9 that came with my laptop and I'm editing files from my Flip Mino HD camera, and it all works fine except after I've exported the files and play the video the whole picture is much smaller, with huge black borders on the sides. I've tried changing some settings but I just don't know where to look or what to change, I'm very new to this. Is there anything I can do to get rid of this whole black background? It's not just some small borders on the top and on the bottom but large ones on all four sides that really do bother me a lot.
    Jun 5, 2012 6:45 PM   in reply to Jollestudio
    Welcome to the forum.
    Let's start at the beginning. At New Project, exactly which Preset did you choose?
    There is one specifically for Flip cameras, but I am not sure if it was in PrE 9, or was introduced in PrE 10. Someone will either verify, or correct me. This step is very, very important.
    Then, when you go to Share/Export, your settings there will be important too, but will be chosen by the delivery scheme that you require, say DVD-Video, YouTube, etc.
    Good luck,
    Hunt
    Jun 5, 2012 7:15 PM   in reply to Jollestudio
    OK, if you have HD material, in an HD Project, then Exporting/Sharing to 640x 480 WILL yield a tiny Frame Size. From HD, that is about 1/4 of the resolution, of your original footage.
    Exactly how do you plan on delivering the footage? That should be your guide, when choosing the settings for Export/Share.
    Good luck,
    Hunt
    Jun 5, 2012 9:18 PM   in reply to Jollestudio
    For output to YouTube, I would start with the settings in this FAQ Entry.
    Good luck,
    Hunt
    Jun 13, 2012 8:38 AM   in reply to Jollestudio
    Sorry, but I have never had any of my Premiere programs, be unable to find my installation of Apple's QT Player. Now, I am usually a few versions back, as I always want to be sure that I have a "last known good" version, and with QT Player, it's common to have some versions, that just do not play well with Adobe products on a PC. I stayed with 7.3.5 for years, then finally tested and moved to 7.5.5. I kept that installed, until about 7.6.7, which tested OK. I never let iTunes, or any other program, upgrade my QT Player, and have the Update turned OFF, so that only I can make that transition, when I am ready.
    Wish that I had something to offer, and maybe others have encountered what you are, and have a fix.
    Good luck,
    Hunt
    Jun 13, 2012 9:37 AM   in reply to Jollestudio
    You do not mention your OS, but there are sometimes ODD permissions problems with Win7
    To install Quicktime, and even to run PreEl, right click the icon or EXE and select Run as Administrator from the popup option list
    These notes are for other Adobe products, but the IDEA is the same
    As well as the below, right click the Encore icon and select Run as Administrator, which is NOT the same thing as running the computer with the Administrator account, and which fixes several "odd" problems... To create a two layer DVD (or a BluRay?), you MUST have Encore set to use the Run as Administrator option
    Run as Administrator http://forums.adobe.com/thread/969395
    -and Vista http://forums.adobe.com/thread/1021721
    Odd Errors http://forums.adobe.com/thread/670174
    Jun 13, 2012 10:34 AM   in reply to Jollestudio
    If I understand what you want, and what is happening, if you have and HD Project, and have HD material, if you wish to Export/Share, and then use that output file to edit in another Project, you should choose an output format, that will match the new Project. Say you have an AVCHD Project, with AVCHD material, but wish to output from that Project to DV (down-rezzing the HD material to SD), you would choose an SD Export/Share Preset, and let PrE do the down-rezzing for the output file. Then, when you Import that output file into the new SD Project, the Frame Size should match up. Note: with SD Projects/files, one has to consider PAR (Pixel Aspect Ratio). Most HD formats use square pixels (PAR = 1.0), then there is Anamorphic, which will be PAR - 1.333.
    If I did not understand either the problem, or what you wish to do, I apologize.
    Good luck,
    Hunt
