compare list values with with db ms sql 2008
Jun 13, 2012 5:42 AM
Hi there,
I need to compare a list values with a db column.
Example : list ='12,5,6,8'  and I need to know which of these values doesnt exist in db column values. How would I do that?
DbColumnKeys
1
10
100
1000
1001
1002
1003
1004
    Jun 13, 2012 9:23 AM   in reply to emmim44
    something like this should work
    select list_item
    from
    <cfloop list="#yourlist#" index = "listitem">
    select #listitem# list_item
    union
    </cfloop>
    select 0 list_item
    where 1 = 2
    ) temp left join from yourtable on list_item = somefield
    where somefield is null
    Jun 14, 2012 5:27 AM   in reply to emmim44
    If you are going to use a cfquery, what I gave you should work.  If you are writing a stored procedure, the logic stays the same but the syntax for the loop changes.
    Jul 2, 2012 2:40 AM   in reply to emmim44
    This works on MySQL:
    SELECT dbCol
    FROM (select 12 dbCol union select 5 dbCol2 union select 6 dbCol3 union select 8 dbCol4) someTBLAlias
    WHERE dbCol NOT IN (SELECT dbCol FROM dbTBL)
