Text field variable warning.
Jun 12, 2012 10:38 PM
I'm updating a large .fla file from AS2.0 to AS3.0 and getting the following warning:
"WARNING: Text field variable names are not supported in ActionScript 3.0. The variable 'text_value' used for an unnamed text field will not be exported."
Is there a quick way to locate the offending symbol? The Flash Professional "Find" function does not seem to be helpful for this.
Thank you.
    Jun 13, 2012 4:26 AM   in reply to hhhhhhhhhhhhhh5
    One way would be to look at the AS2 file opened as an AS2 file and find a textfield that has that var assigned to it in the properties panel's field for the var property.
    Jun 13, 2012 8:20 AM   in reply to hhhhhhhhhhhhhh5
    I don't see how finding a textfield would be that difiicult/painful.
    Jun 13, 2012 11:56 AM   in reply to hhhhhhhhhhhhhh5
    The error is only going to come from one fla.  You should be able to see any textfields involved.  You oughta try it first... I doubt there will be any need for Advil.
