PIXIllate22
CS6 and Custom Point Curve vs. Linear
Jun 12, 2012 10:48 AM
Tags: #custom #point #cs6 #acr #d700 #curve
So when I open a new D700 shot in ACR with CS6 and go to the point curve panel it defaults to Custom. Which appears to have about 10-12 points on it and looks like it is providing a slight lift in the shadows and a slight dip in the highlights. I can select linear and I know how to save this as the new default I'm just curious what the Custom curve is and where it comes from. I'm using the V.4 Neutral profile if that makes any difference.
I've not seen this mentioned anywhere. Anyone understand it?
    Jun 12, 2012 11:55 AM   in reply to PIXIllate22
    It's coming from converting a PV2010 Linear curve into PV2012.
  • Noel Carboni
    Dec 23, 2006
    Jun 12, 2012 12:30 PM   in reply to PIXIllate22
    I saw the same thing.  It's what's stored in your Camera Raw defaults.  Where did they come from?  Chances are you had saved a set of PV2010 Camera Raw Defaults at one time in the past, and which were migrated to become PV2012 Camera Raw Defaults.
    You can reset it to Linear as you like, simply by saving new Camera Raw defaults.
    -Noel
    Jun 12, 2012 1:01 PM   in reply to PIXIllate22
    PV2012 linear is equivalent to PV2010 medium contrast.
    So, if you want a PV2010 linear equivalent in PV2012, you'll have to brew your own. I gave a recipe for how to do this using DNG Profile Editor in another thread, but not sure where that is now. This approach has the advantage that you start without a bunch of points already on your curve in ACR.
    But if you select linear in PV2010 then convert to PV2012 - that's the equivalent, which can be saved as a preset, if you don't mind having all those points...
    Cheers,
    Rob
    Jun 12, 2012 1:19 PM   in reply to PIXIllate22
    I'm not sure you'll find a satifying rationale - it has been discussed extensively and debated passionately in the Lightroom beta forum, among other forums.
    I think people who tend to like contrastier images aren't fretting as much as the lower contrast (starting point) preferrers.
    I usually just crank contrast down, then maybe adjust tone curve to taste, when need be...
    Cheers,
    Rob
    Jun 12, 2012 3:14 PM   in reply to PIXIllate22
    Highly unlikely, me-thinks.
    But again, you can do it yourself using DNG Profile Editor.
    I wish I could find the link, or the data you need, but can't.
    But here is what I did: I used PV2010 linear in Lightroom, clicked PV2012, then saved a preset (does ACR support presets?) checking only tone/point curve, then using a text editor, converted it to the format required in DNG Profile Editor (recipe), and inserted it into a recipe file.
    On the other hand, you can accomplish something close to the linear equivalent point curve using -contrast.
    Found it - replace tone curve in dcpr file (DPE recipe) with this and you've got linear equivalent:
    <dngclr:ToneCurve rdf:parseType="Resource">
        <dngclr:Edit0 rdf:parseType="Resource">
           <dngclr:X>0</dngclr:X>
           <dngclr:Y>0</dngclr:Y>
        </dngclr:Edit0>
        <dngclr:Edit1 rdf:parseType="Resource">
           <dngclr:X>17</dngclr:X>
           <dngclr:Y>26</dngclr:Y>
        </dngclr:Edit1>
        <dngclr:Edit2 rdf:parseType="Resource">
           <dngclr:X>34</dngclr:X>
           <dngclr:Y>44</dngclr:Y>
        </dngclr:Edit2>
        <dngclr:Edit3 rdf:parseType="Resource">
           <dngclr:X>51</dngclr:X>
           <dngclr:Y>60</dngclr:Y>
        </dngclr:Edit3>
        <dngclr:Edit4 rdf:parseType="Resource">
           <dngclr:X>68</dngclr:X>
           <dngclr:Y>74</dngclr:Y>
        </dngclr:Edit4>
        <dngclr:Edit5 rdf:parseType="Resource">
           <dngclr:X>85</dngclr:X>
           <dngclr:Y>89</dngclr:Y>
        </dngclr:Edit5>
        <dngclr:Edit6 rdf:parseType="Resource">
           <dngclr:X>102</dngclr:X>
           <dngclr:Y>105</dngclr:Y>
        </dngclr:Edit6>
        <dngclr:Edit7 rdf:parseType="Resource">
           <dngclr:X>119</dngclr:X>
           <dngclr:Y>120</dngclr:Y>
        </dngclr:Edit7>
        <dngclr:Edit8 rdf:parseType="Resource">
           <dngclr:X>136</dngclr:X>
           <dngclr:Y>135</dngclr:Y>
        </dngclr:Edit8>
        <dngclr:Edit9 rdf:parseType="Resource">
           <dngclr:X>153</dngclr:X>
           <dngclr:Y>151</dngclr:Y>
        </dngclr:Edit9>
        <dngclr:Edit10 rdf:parseType="Resource">
           <dngclr:X>170</dngclr:X>
           <dngclr:Y>167</dngclr:Y>
        </dngclr:Edit10>
        <dngclr:Edit11 rdf:parseType="Resource">
           <dngclr:X>187</dngclr:X>
           <dngclr:Y>183</dngclr:Y>
        </dngclr:Edit11>
        <dngclr:Edit12 rdf:parseType="Resource">
           <dngclr:X>204</dngclr:X>
           <dngclr:Y>200</dngclr:Y>
        </dngclr:Edit12>
        <dngclr:Edit13 rdf:parseType="Resource">
           <dngclr:X>221</dngclr:X>
           <dngclr:Y>218</dngclr:Y>
        </dngclr:Edit13>
        <dngclr:Edit14 rdf:parseType="Resource">
           <dngclr:X>238</dngclr:X>
           <dngclr:Y>236</dngclr:Y>
        </dngclr:Edit14>
        <dngclr:Edit15 rdf:parseType="Resource">
           <dngclr:X>255</dngclr:X>
           <dngclr:Y>255</dngclr:Y>
        </dngclr:Edit15>
    </dngclr:ToneCurve>
    PIXIllate22 wrote:
    So is there any chance Adobe will at least give us back a Flat option, even if it isn't the default?
    No...
  • Noel Carboni
    Dec 23, 2006
    Jun 12, 2012 3:34 PM   in reply to PIXIllate22
    I'm not sure what Jeff is answering, but could you be more specific what you mean by "Flat option"?
    You can, of course, save your own Camera Raw defaults so that they look like this by simply setting the Curve: to Linear.  Then if you want to add a couple of points on it you can just click on the line and drag...
    -Noel
    Jun 12, 2012 3:51 PM   in reply to PIXIllate22
    PIXIllate22 wrote:
    Rob,
    Thanks a lot. You`ve been really helpful.
    You bet .
    PIXIllate22 wrote:
    Rob,
    Any good links?
    The DPE documentation on the web is actually pretty darn good:
    http://labs.adobe.com/wiki/index.php/DNG_Profiles:Editor
    FWIW/My.02: I think Adobe was just trying to streamline and simplify... 0 for the sliders, straight line for the tone curve. But they wanted to maintain the same "contrast enhanced" default starting point. All of which is fine with me, but I do think simply adding a "Legacy Linear" tone curve option would have avoided some grief - oh well.
    R
  • Noel Carboni
    Dec 23, 2006
    Jun 12, 2012 3:45 PM   in reply to PIXIllate22
    So make your own inverted S curve that makes your images look less contrasty, and just the way you want.  I don't see the problem.
    This is all "touchy feely" stuff.  The interface doesn't lend itself well to overthinking.  Think like this:  Fool with controls until you like what you see in the preview pane.
    Do this with a bunch of different images to evaluate your choices for defaults.
    -Noel
  • Noel Carboni
    Dec 23, 2006
    Jun 12, 2012 5:19 PM   in reply to PIXIllate22
    I think you have a misconception...  You cannot see "the linear camera data".  If you sent a debayered conversion with no tone curve nor gamma correction applied to your monitor it would look essentially black, with a few light spots where the highlights are.  I think it's more a psychological issue that you feel what you were seeing before was somehow a more basic starting point than it really was.  Adobe has now defined their default tone curve as a straight line, and we get to adjust it to taste.
    All the controls on the first page of the converter's Basic page seem to do various things to the tone curve as well, stretching it this way and that.
    "Touchy feely" works with this software.  There doesn't seem to be another method forthcoming.
    -Noel
    Jun 12, 2012 8:02 PM   in reply to PIXIllate22
    PIXIllate22 wrote:
    What was once a linear point curve labled linear is now a medium contrast curve labeled and drawn to appear as a linear point curve.
    It is not a psycological issue. The fact is there is now a hidden curve built in to the point curve setting labled linear.
    No..it is more of a psycological issue...the linear tone curve in the previous PV 2010 was NOT a true linear curve. It was still a modified gamma curve even is the adjustment was mild. If you set the PV 2010 tone curve to linear and set brightness and contrast you would come closer to a linear rendering but it STILL had a non-linear gamma adjustment because it was normalized for viewing and adjustments. Some people fell in love with the flat low contrast starting point. Some people also only used point curves and no basic panel adjustments. That is not an optimal approach now with PV 2012 because it bypasses a lot of tone mapping that the new Basic panel can do.
    You can use DNG Profile Editor to modify a DNG profile for you camera and get back to a more linear (not perfectly linear, only more linear) if that's what you want but you can't do it with any command in LR4/ACR7 now without getting negative Exposure and Contrast settings and multiple pointson te curve to adjust the new default curve to be more linear (but still not exactly linear).
    As to why they converted the old medium contrast and set it now as a default linear curve, that was to have no baseline curve set in the ACR/LR default so that curves could be applied to raw, tiff and even 32-bit float images and use the same default starting point. The normalized medium contrast curve still lives in the DNG profile and that's where you have to change the curve from medium to linear in a custom DNG profile. Bottom line, greatest good was the motive...some people don't like the change but they are not gonna change back because the people who don't like it are a very small minority.
  • Noel Carboni
    Dec 23, 2006
    Jun 13, 2012 12:04 PM   in reply to PIXIllate22
    Out of curiosity, what do you feel you lose by just dialing-in an inverse S curve and saving it as your Camera Raw default, so that it starts out with a conversion pleasing to you?
    -Noel
    Jun 14, 2012 5:26 AM   in reply to PIXIllate22
    I still don't see why Adobe didn't just leave the legacy 2010 linear
    curve in there as a selectable option for those who prefer it but there is
    no sense in discussing that any further if it isn't ever going to happen.
    Because, even if I was happy with the default medium contrast curve,
    everytime I wanted to tweak it, I first had to clean it up of existing
    points. That was annoying. Starting with default curve that is a straight
    line seems much more natural.
    Jun 14, 2012 6:18 AM   in reply to PIXIllate22
    Options that I don't use have no effect on my workflow.
    Jun 14, 2012 11:18 AM   in reply to PIXIllate22
    Consider making a feature request ("Idea") on the feedback site, if there isn't one already (and if there is, vote for it / add comment...):
    http://feedback.photoshop.com/photoshop_family/topics/new
