Cannot get my install to render the CF Admin pages succesfully, keep getting a 503 - Service temporarily unavailable.
Log files all look clean with the exception of the Tomcat log file which gives a load of the below:
[Mon May 21 21:54:30 2012] [3457:47024938890000] [info] init_jk::mod_jk.c (3299)
: mod_jk/1.2.32 () initialized
[Mon May 21 21:54:30 2012] [3458:47024938890000] [info] init_jk::mod_jk.c (3299)
[Mon May 21 22:02:54 2012] [3461:47024938890000] [error] jk_open_socket::jk_conn
ect.c (448): socket() failed (errno=22)
[Mon May 21 22:02:54 2012] [3461:47024938890000] [info] ajp_connect_to_endpoint:
:jk_ajp_common.c (1027): Failed opening socket to (127.0.0.1:8012) (errno=22)
[Mon May 21 22:02:54 2012] [3461:47024938890000] [error] ajp_send_request::jk_aj
p_common.c (1649): (cfusion) connecting to backend failed. Tomcat is probably no
t started or is listening on the wrong port (errno=22)
[Mon May 21 22:02:54 2012] [3461:47024938890000] [info] ajp_service::jk_ajp_comm
on.c (2629): (cfusion) sending request to tomcat failed (recoverable), because o
f error during request sending (attempt=1)
To confirm some of my settings:
[root@web-dev4 1]# sestatus
SELinux status: disabled
[root@web-dev4 1]# service iptables status
Firewall is stopped.
[root@web-dev4 1]# more /etc/hosts
# Do not remove the following line, or various programs
# that require network functionality will fail.
127.0.0.1 localhost.localdomain localhost web-dev4
::1 localhost6.localdomain6 localhost6
[root@web-dev4 1]# hostname
web-dev4
[root@web-dev4 1]# telnet localhost 8012
Trying 127.0.0.1...
Connected to localhost.localdomain (127.0.0.1).
Escape character is '^]'.
Connection closed by foreign host.
Really have no ideas at this point, installation repeated a few times, looks all clean. Anybody?
I get exact same error on Centos 5.8 .
Tried with few apache version , same issue .
SeLinux & Firewall completely disabled .
Not doing anything fancy , clean install , default server install with apache .
[root@mel-survey-dev conf]# cat mod_jk.conf
# Load mod_jk module
LoadModule jk_module "/opt/coldfusion10/config/wsconfig/1/mod_jk.so"
# Where to find workers.properties
JkWorkersFile "/opt/coldfusion10/config/wsconfig/1/workers.properties"
JkMountFile "/opt/coldfusion10/config/wsconfig/1/uriworkermap.properties"
# Where to put jk logs
JkLogFile "/opt/coldfusion10/config/wsconfig/1/mod_jk.log"
# Where to put jk shared memory
JkShmFile "/opt/coldfusion10/config/wsconfig/1/jk_shm"
# Set the jk log level [debug/error/info]
JkLogLevel info
# Select the timestamp log format
JkLogStampFormat "[%a %b %d %H:%M:%S %Y] "
AddHandler jakarta-servlet .cfm .cfml .cfc .cfr .cfswf
Alias /CFIDE "/opt/coldfusion10/cfusion/wwwroot/CFIDE"
<Directory "/opt/coldfusion10/cfusion/wwwroot/CFIDE">
Options Indexes FollowSymLinks
AllowOverride None
Order allow,deny
Allow from all
</Directory>
<Files ~ ".hbmxml$">
Order allow,deny
Deny from all
</Files>
Unfortunately, CentOS is not a supported platform for ColdFusion 10 - http://wwwimages.adobe.com/www.adobe.com/content/dam/Adobe/en/products /coldfusion/pdfs/cf10/coldfusion10-support-matrix.pdf
Sorry, I am afraid I don't understand this position. Looking at the list I see that Red Hat Enterprise version 5.6 x64 is fully supported. If you install this and fully update it with "yum update" you will actually end up on version 5.8 and cat /etc/redhat-release will give the new version. Centos is 100% binary compatible and entirely built from Red Hat sources (with the proprietary stuff removed), but ignoring this, are you saying that Red Hat 5.8 is not supported either? If not, this leaves users in the unenviable position of either not being able to update or not being supported? I understand the difficulty in supporting different flavours and versions of Linux distros but it would help if this could be clarified?
Regards
Meint
Meint,
I performed a clean install of CentOS 6.2 in the "Software Development" installation type. After installation, I configured SELinux to be permissive rather than enforcing. ColdFusion 10 installed correctly and I was able to complete the configuration of Apache 2.2 without any problems.
I see that you set SELinux to disabled, so that should not have been an issue, although since I was in permissive mode I did get some warnings.
I'm afraid that I dont' have an answer for you, except to say that I can verify that installation of CF10 and configuration of Apache on a clean CentOS server worked. I could provide a package list or other OS config info if requested for your comparison.
-Steve
Screenshots:
http://www.mobypicture.com/user/stevenerat/view/12991831
On Twitter, Andy Allan commented that he experiences a connector problem only on CentOS 5.8, not 6.x. https://twitter.com/fymd/statuses/211150454535630848
Thanks Steve,
Good to hear, I will try again next week on Centos 6.2 next week and hopefully it will work without all the hassle, pretty confident it will be fine.
I still don't understand Adobe's position on support on the various Red Hat versions though, it seems very strange. What constitutes a version anyway? If I installed 5.6 (supported but probably not working anyway) and install every update apart from the redhat-release package my version will say 5.6 but I am really running 5.8. Is this supported? What does Adobe consider the correct way to determine the version? The kernel version, Apache version or something else? Not supporting Centos doesn't make any sense either as they are 100% binary compatible.
Thanks for your efforts though, appreciated.
Meint
Okay, so I reinstalled with 6.2. All going swimmingly, seemed to install okay. Completely standard install, not touched anything else. Log into CF Admin, enable Use J2EE and find myself constantly logged out, especially after adding a DSN.
Following errors logged in application.log:
| Jun 12, 2012 | 9:09 AM | Information | ajp-bio-8012-exec-8 | |
| Session rotated successfully. | ||||
| Jun 12, 2012 | 9:09 AM | Warning | ajp-bio-8012-exec-2 | CFADMIN |
| There was an error while verifying the token. Either the session timed out or un-authenticated access is suspected. | ||||
Also logged in Apache ssl_error_log:
[Tue Jun 12 09:35:29 2012] [error] [client 192.168.20.49] File does not exist: /var/www/html/2f CFIDE, referer: https://web-dev4/CFIDE/administrator/navserver.cfm
[Tue Jun 12 09:42:45 2012] [error] [client 192.168.20.49] File does not exist: /var/www/html/2f CFIDE, referer: https://web-dev4/CFIDE/administrator/navserver.cfm
In the coldfusion-out.log:
Jun 12, 2012 09:58:52 AM Information [ajp-bio-8012-exec-9] - User admin logged in.
Jun 12, 2012 09:58:56 AM Information [ajp-bio-8012-exec-7] - User admin deleted datasource test.
Jun 12, 2012 09:58:57 AM Information [ajp-bio-8012-exec-3] - Session rotated successfully.
Jun 12, 2012 09:58:57 AM Information [ajp-bio-8012-exec-3] - User admin logged in.
Jun 12, 2012 09:59:06 AM Information [ajp-bio-8012-exec-9] - Session rotated successfully.
Jun 12, 2012 09:59:06 AM Information [ajp-bio-8012-exec-9] - User admin logged in.
Jun 12, 2012 09:59:15 AM Information [ajp-bio-8012-exec-10] - An error occurred while fetching element from authcache.
Jun 12, 2012 09:59:32 AM Information [ajp-bio-8012-exec-9] - Session rotated successfully.
Jun 12, 2012 09:59:32 AM Information [ajp-bio-8012-exec-9] - User admin logged in.
Jun 12, 2012 09:59:36 AM Information [ajp-bio-8012-exec-10] - User admin added/edited datasource cfdocexamples.
Kind of losing heart here, if we can't get a vanilla CF10 server on Linux to install properly, maybe we should consider alternatives.
And from the mod_jk.log:
[Tue Jun 12 10:03:04 2012] [2969:139761065326560] [info] ajp_process_callback::jk_ajp_common.c (1954): Writing to client aborted or client network problems
[Tue Jun 12 10:03:04 2012] [2969:139761065326560] [info] ajp_service::jk_ajp_common.c (2629): (cfusion) sending request to tomcat failed (unrecoverable), because of cl
ient write error (attempt=1)
[Tue Jun 12 10:03:04 2012] [2969:139761065326560] [info] jk_handler::mod_jk.c (2718): Aborting connection for worker=cfusion
[Tue Jun 12 10:04:03 2012] [1415:139761065326560] [info] ajp_send_request::jk_ajp_common.c (1638): (cfusion) all endpoints are disconnected, detected by connect check
(1), cping (0), send (0)
[Tue Jun 12 10:23:14 2012] [1416:139761065326560] [info] ajp_process_callback::jk_ajp_common.c (1954): Writing to client aborted or client network problems
[Tue Jun 12 10:23:14 2012] [1416:139761065326560] [info] ajp_service::jk_ajp_common.c (2629): (cfusion) sending request to tomcat failed (unrecoverable), because of cl
[Tue Jun 12 10:23:14 2012] [1416:139761065326560] [info] jk_handler::mod_jk.c (2718): Aborting connection for worker=cfusion
[Tue Jun 12 10:23:14 2012] [2982:139761065326560] [info] ajp_process_callback::jk_ajp_common.c (1954): Writing to client aborted or client network problems
[Tue Jun 12 10:23:14 2012] [2982:139761065326560] [info] ajp_service::jk_ajp_common.c (2629): (cfusion) sending request to tomcat failed (unrecoverable), because of cl
[Tue Jun 12 10:23:14 2012] [2982:139761065326560] [info] jk_handler::mod_jk.c (2718): Aborting connection for worker=cfusion
[Tue Jun 12 10:32:14 2012] [2982:139761065326560] [info] ajp_process_callback::jk_ajp_common.c (1954): Writing to client aborted or client network problems
[Tue Jun 12 10:32:14 2012] [2982:139761065326560] [info] ajp_service::jk_ajp_common.c (2629): (cfusion) sending request to tomcat failed (unrecoverable), because of cl
[Tue Jun 12 10:32:14 2012] [2982:139761065326560] [info] jk_handler::mod_jk.c (2718): Aborting connection for worker=cfusion
Anybody?
Update: turns out that one of my colleagues was using the same box and every time he logged into CF Administrator, I got logged out. When I logged back in, he obviously got kicked out. Is this by design or a bug? Definately not like this in previous versions. Confusing but at least now we are getting somewhere. ![]()
This is by design, as part of various CF10 security enhancements.
For instance, in this article on CF10 Security enhancements (http://www.adobe.com/devnet/coldfusion/articles/security-improvements. html), it notes this with respect to changes about CFLOGIN, which the CF Admin uses under the covers:
Now you can have only one active session open for one user for a given application that uses the cflogin tag.
For example, you can now access the Administrator console one user at a time with a given set of UserIDs and passwords.
It’s also in the CF10 docs, though not worded as obviously applying to this situation. At the bottom of http://help.adobe.com/en_US/ColdFusion/10.0/Developing/WSe61e35da8d318 5183e145c0d1353e31f559-7ff7.html, it says:
You are logged out from one of the ColdFusion administrators, if:
From the same host, you log in to the ColdFusion (10) Administrator and the ColdFusion Administrator of an older version.
HTH.
/charlie
I should have added that while you may think, "but that doesn't explain why another user and I can't use it at once", actually it does. Note that the login is not "per user" but "per account". And by default, there is one account used for logging into the CF Admin, called the Admin user (we normally don't even notice or use that, and only need to enter the password for that account).
So it's saying that "2 users of the same account can't be logged into the CF Admin at one time." I agree it's an annoyance, but I'm sure there's a worthy security problem for which it was the solution. Maybe someone from Adobe will chime in with more thoughts.
Charlie,
Thanks for that, a quality answer as always. I agree it is probably a good thing, just wondering how much work it would have been to give a nice helpful message saying "Your session was logged out as a result of a login with the same username from IP: xxx.xxx.xxx.xxx".
I had read the bit about "From the same host, you log in to the ColdFusion (10) Administrator and the ColdFusion Administrator of an older version" but that really didn't explain it fully, your last post did though. Frustating to find this after spending a fair bit of time troubleshooting thinking we had session management problems, but at least now we know our install is solid and faith has been restored.
Regards
Meint
Thanks for the update (and the kind regards).
And I do agree both that it could offer a better message and that it could be better highlighted (in the docs, in the interface, or perhaps even in the installer or something) so people know of it in advance.
Until then, I did a blog entry on it (motivated by this thread), and it’s now at:
Have you noticed the #ColdFusion 10 admin allows only one login at a time? It's by design
http://www.carehart.org/blog/client/index.cfm/2012/6/13/cf10_admin_all ows_one_logon_at_a_time
/charlie
