Onefootvisual19
v20 Problem Scrollable Frames
Jun 11, 2012 4:08 AM
Tags: #cs5.5 #overlay #digital_publishing_suite
Hi Everyone!
I have InDesign CS5.5 and I'm having a problem with the new scrollable frames functions.
I tried to recreate a scrollable frame like the one shown here tv.adobe.com/watch/learn-digital-publishing-suite/scrollable-frames-an d-pan-zoom-v19/ at 03:43.
My Problem is:
Hide Scroll Indicators does not work
Use Document Position does not work too.
I have installed the latest producer tools (FolioProducerTools-CS55-1.10.1 and FolioPanel-CS55-12.2.2.1).
I'm running Windows (Is this the problem here? :-P )
I un- and reinstalled the producer tools.
I also tried it on my windows notebook. Same result.
Do I need to install anything else to get it working?
Maybe someone can help me here.
Best,
Wolfgang
Message was edited by: Onefootvisual19 I uninstalled the Folio Producer Tools v 1.10.1 and installed s v 1.8 (where the feature scrollable frame wasn't available yet) than installed v 1.9 (the wanted function as described above didn't work) and then finally reinstalled v.1.10.1. It still doesn't work ...  Am I the only one here who experiences these problems?
Here are also three screenshots to illustrate my problem.
1.) I the red frame is the container of the grouped elements that are scrollable (on the left side is the whole element so you can see it). Hide scroll indicators option is checked and also use document position.
2. When I start the Content Viewer the scrollable frame places the content on the upper left corner ...
3. and scroll indicators are visible
What's the problem here?
Can  anyone help me out?
Best,
Wolfgang
Here is another strange thing:
I looked up http://www.caniupdateadobedps.com/ and they say that you find the dps version number in the info window of the folio builder panel. it should be 20.
but mine says 15? though I installed v20 now for the fifth time.
the extension manager says I have v20 though.
Is this the cause for my dps functions not working the way they should?
I really would appreciate some help here.
    Jun 12, 2012 9:40 AM   in reply to Onefootvisual19
    It works on Windows for me.
    Bob
    Jun 12, 2012 1:35 PM   in reply to Onefootvisual19
    Have you tried this on a device instead of using the Adobe Content Viewer on the desktop?
    Neil
    Jun 13, 2012 8:54 AM   in reply to Onefootvisual19
    Just to confirm, you're on CS5.5?
    Jun 13, 2012 12:57 PM   in reply to Onefootvisual19
    Ok, you're definitely on the wrong version of the tools which is probably the cause. Here's what you should do:
    1) Uninstall all the DPS tools from Add/Remove programs
    2) Go to C:\Program Files (x86)\Adobe\Adobe InDesign CS5.5\Plug-Ins\Graphics and make sure there is no DigitalPublishing plug-in there. If there is, delete it.
    3) Go to %appdata%\Adobe\InDesign\Version 7.5\en_US and make sure there is no PlugInConfig.txt file there. If there is, delete it.
    4) Follow the install instructions at
    http://help.adobe.com/en_US/digitalpubsuite/using/WS67cb9e293e2f1f60-2 1ba9a4512e5e5e0b8d-7ffe.html. You only need to install the v20 tools and panel. There is no need to install any of the prior components.
    Neil
    Jun 13, 2012 2:08 PM   in reply to Onefootvisual19
    Glad you were able to get it fixed, and my apologies for the difficulties!
    Neil
