Can't update Adobe Air. Can't unistall old version. I am teh adminsitrator. Win 7 Home Premium 64bit SP1.
Please help.
Joe
Install log
[2012-06-13:14:22:02] Runtime Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-13:14:22:02] Commandline is:
[2012-06-13:14:22:02] Installed runtime (3.2.0.2070) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2012-06-13:14:22:09] Relaunching with elevation
[2012-06-13:14:22:09] Launching subprocess with commandline c:\users\j\appdata\local\temp\aira237.tmp\adobe air installer.exe -ei
[2012-06-13:14:22:11] Runtime Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-13:14:22:11] Commandline is: -stdio \\.\pipe\AIR_2580_0 -ei
[2012-06-13:14:22:11] Installed runtime (3.2.0.2070) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2012-06-13:14:22:11] Starting silent runtime update. Updating runtime from version 3.2.0.2070 to version 3.3.0.3650
[2012-06-13:14:22:11] Installing msi at c:\users\j\appdata\local\temp\aira237.tmp\setup.msi with guid {65CB4C08-C47B-4A7E-A6A4-50C06ADA5FC6}
[2012-06-13:14:22:20] Error occurred during msi install operation; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1603" errorID=0]
[2012-06-13:14:22:20] Rolling back install of c:\users\j\appdata\local\temp\aira237.tmp\setup.msi
[2012-06-13:14:22:20] Rollback complete
[2012-06-13:14:22:20] Exiting due to error: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1603" errorID=0]
[2012-06-13:14:22:20] Runtime Installer end with exit code 7
[2012-06-13:14:22:23] Runtime Installer end with exit code 7
[2012-06-13:14:22:30] Runtime Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-13:14:22:30] Commandline is:
[2012-06-13:14:22:30] Installed runtime (3.2.0.2070) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2012-06-13:14:22:33] Runtime Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-13:14:22:33] Commandline is:
[2012-06-13:14:22:33] Installed runtime (3.2.0.2070) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2012-06-13:14:22:34] Runtime Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-13:14:22:34] Commandline is:
[2012-06-13:14:22:34] Installed runtime (3.2.0.2070) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2012-06-13:14:22:36] Relaunching with elevation
[2012-06-13:14:22:36] Launching subprocess with commandline c:\users\j\appdata\local\temp\aira0e.tmp\adobe air installer.exe -ei
[2012-06-13:14:22:38] Runtime Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-13:14:22:38] Commandline is: -stdio \\.\pipe\AIR_2740_0 -ei
[2012-06-13:14:22:38] Installed runtime (3.2.0.2070) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2012-06-13:14:22:38] Starting silent runtime update. Updating runtime from version 3.2.0.2070 to version 3.3.0.3650
[2012-06-13:14:22:38] Installing msi at c:\users\j\appdata\local\temp\aira0e.tmp\setup.msi with guid {65CB4C08-C47B-4A7E-A6A4-50C06ADA5FC6}
[2012-06-13:14:22:44] Cancelling elevated install
[2012-06-13:14:22:45] Cancel request forwarded to msi install operation
[2012-06-13:14:22:46] Relaunching with elevation
[2012-06-13:14:22:46] Launching subprocess with commandline c:\users\j\appdata\local\temp\air1802.tmp\adobe air installer.exe -ei
[2012-06-13:14:22:46] Error occurred during msi install operation; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1603" errorID=0]
[2012-06-13:14:22:46] Rolling back install of c:\users\j\appdata\local\temp\aira0e.tmp\setup.msi
[2012-06-13:14:22:46] Rollback complete
[2012-06-13:14:22:46] Exiting due to error: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1603" errorID=0]
[2012-06-13:14:22:46] Runtime Installer end with exit code 7
[2012-06-13:14:22:47] Runtime Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-13:14:22:47] Commandline is: -stdio \\.\pipe\AIR_4060_0 -ei
[2012-06-13:14:22:47] Installed runtime (3.2.0.2070) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2012-06-13:14:22:47] Starting silent runtime update. Updating runtime from version 3.2.0.2070 to version 3.3.0.3650
[2012-06-13:14:22:48] Installing msi at c:\users\j\appdata\local\temp\air1802.tmp\setup.msi with guid {65CB4C08-C47B-4A7E-A6A4-50C06ADA5FC6}
[2012-06-13:14:22:51] Error occurred during msi install operation; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1603" errorID=0]
[2012-06-13:14:22:51] Rolling back install of c:\users\j\appdata\local\temp\air1802.tmp\setup.msi
[2012-06-13:14:22:51] Rollback complete
[2012-06-13:14:22:51] Exiting due to error: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1603" errorID=0]
[2012-06-13:14:22:51] Runtime Installer end with exit code 7
[2012-06-13:14:22:53] Runtime Installer end with exit code 7
[2012-06-13:14:23:33] Runtime Installer end with exit code 6
[2012-06-13:14:24:20] Runtime Installer begin with version 3.3.0.3650 on Windows XP x86
[2012-06-13:14:24:20] Commandline is:
[2012-06-13:14:24:20] Installed runtime (3.2.0.2070) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2012-06-13:14:24:24] Runtime Installer begin with version 3.3.0.3650 on Windows XP x86
[2012-06-13:14:24:24] Commandline is:
[2012-06-13:14:24:24] Installed runtime (3.2.0.2070) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2012-06-13:14:24:25] Runtime Installer begin with version 3.3.0.3650 on Windows XP x86
[2012-06-13:14:24:25] Commandline is:
[2012-06-13:14:24:25] Installed runtime (3.2.0.2070) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2012-06-13:14:24:26] Starting runtime update. Updating runtime from version 3.2.0.2070 to version 3.3.0.3650
[2012-06-13:14:24:26] Installing msi at c:\users\j\appdata\local\temp\airb328.tmp\setup.msi with guid {65CB4C08-C47B-4A7E-A6A4-50C06ADA5FC6}
[2012-06-13:14:24:32] Error occurred during msi install operation; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1603" errorID=0]
[2012-06-13:14:24:32] Rolling back install of c:\users\j\appdata\local\temp\airb328.tmp\setup.msi
[2012-06-13:14:24:32] Rollback complete
[2012-06-13:14:24:32] Exiting due to error: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1603" errorID=0]
[2012-06-13:14:24:55] Runtime Installer end with exit code 7
[2012-06-13:14:24:56] Runtime Installer end with exit code 6
[2012-06-13:14:24:58] Runtime Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-13:14:24:58] Commandline is:
[2012-06-13:14:24:58] Installed runtime (3.2.0.2070) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2012-06-13:14:25:00] Runtime Installer end with exit code 6
[2012-06-13:14:25:04] Relaunching with elevation
[2012-06-13:14:25:04] Launching subprocess with commandline c:\users\j\appdata\local\temp\air4f57.tmp\adobe air installer.exe -ei
[2012-06-13:14:25:05] Runtime Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-13:14:25:05] Commandline is: -stdio \\.\pipe\AIR_2988_0 -ei
[2012-06-13:14:25:05] Installed runtime (3.2.0.2070) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2012-06-13:14:25:05] Starting silent runtime update. Updating runtime from version 3.2.0.2070 to version 3.3.0.3650
[2012-06-13:14:25:06] Installing msi at c:\users\j\appdata\local\temp\air4f57.tmp\setup.msi with guid {65CB4C08-C47B-4A7E-A6A4-50C06ADA5FC6}
[2012-06-13:14:25:08] Error occurred during msi install operation; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1603" errorID=0]
[2012-06-13:14:25:08] Rolling back install of c:\users\j\appdata\local\temp\air4f57.tmp\setup.msi
[2012-06-13:14:25:08] Rollback complete
[2012-06-13:14:25:08] Exiting due to error: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1603" errorID=0]
[2012-06-13:14:25:08] Runtime Installer end with exit code 7
[2012-06-13:14:26:23] Runtime Installer end with exit code 7
[2012-06-13:14:49:38] Runtime Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-13:14:49:38] Commandline is:
[2012-06-13:14:49:38] Installed runtime (3.2.0.2070) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2012-06-13:14:49:44] Relaunching with elevation
[2012-06-13:14:49:44] Launching subprocess with commandline c:\users\j\appdata\local\temp\airf6bd.tmp\adobe air installer.exe -ei
[2012-06-13:14:49:46] Runtime Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-13:14:49:46] Commandline is: -stdio \\.\pipe\AIR_3736_0 -ei
[2012-06-13:14:49:46] Installed runtime (3.2.0.2070) located at c:\Program Files (x86)\Common Files\Adobe AIR
[2012-06-13:14:49:46] Starting silent runtime update. Updating runtime from version 3.2.0.2070 to version 3.3.0.3650
[2012-06-13:14:49:46] Installing msi at c:\users\j\appdata\local\temp\airf6bd.tmp\setup.msi with guid {65CB4C08-C47B-4A7E-A6A4-50C06ADA5FC6}
[2012-06-13:14:49:51] Error occurred during msi install operation; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1603" errorID=0]
[2012-06-13:14:49:51] Rolling back install of c:\users\j\appdata\local\temp\airf6bd.tmp\setup.msi
[2012-06-13:14:49:51] Rollback complete
[2012-06-13:14:49:51] Exiting due to error: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1603" errorID=0]
[2012-06-13:14:49:51] Runtime Installer end with exit code 7
[2012-06-13:14:49:54] Runtime Installer end with exit code 7
msi logging
=== Verbose logging started: 6/13/2012 15:06:58 Build type: SHIP UNICODE 5.00.7601.00 Calling process: C:\Windows\System32\msiexec.exe ===
MSI (c) (B0:68) [15:06:58:219]: Font created. Charset: Req=0, Ret=0, Font: Req=MS Shell Dlg, Ret=MS Shell Dlg
MSI (c) (B0:AC) [15:06:58:219]: Resetting cached policy values
MSI (c) (B0:AC) [15:06:58:219]: Machine policy value 'Debug' is 0
MSI (c) (B0:AC) [15:06:58:219]: ******* RunEngine:
******* Product: C:\Users\j\Desktop\MicrosoftFixit50381.msi
******* Action:
******* CommandLine: **********
MSI (c) (B0:AC) [15:06:58:219]: Machine policy value 'DisableUserInstalls' is 0
MSI (c) (B0:AC) [15:06:58:235]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Users\j\Desktop\MicrosoftFixit50381.msi' against software restriction policy
MSI (c) (B0:AC) [15:06:58:235]: SOFTWARE RESTRICTION POLICY: C:\Users\j\Desktop\MicrosoftFixit50381.msi has a digital signature
MSI (c) (B0:AC) [15:06:58:328]: SOFTWARE RESTRICTION POLICY: C:\Users\j\Desktop\MicrosoftFixit50381.msi is permitted to run at the 'unrestricted' authorization level.
MSI (c) (B0:AC) [15:06:58:328]: Cloaking enabled.
MSI (c) (B0:AC) [15:06:58:328]: Attempting to enable all disabled privileges before calling Install on Server
MSI (c) (B0:AC) [15:06:58:328]: End dialog not enabled
MSI (c) (B0:AC) [15:06:58:328]: Original package ==> C:\Users\j\Desktop\MicrosoftFixit50381.msi
MSI (c) (B0:AC) [15:06:58:328]: Package we're running from ==> C:\Users\j\Desktop\MicrosoftFixit50381.msi
MSI (c) (B0:AC) [15:06:58:328]: APPCOMPAT: Compatibility mode property overrides found.
MSI (c) (B0:AC) [15:06:58:328]: APPCOMPAT: looking for appcompat database entry with ProductCode '{55D13F49-FCB8-4892-8266-05D373FCAA61}'.
MSI (c) (B0:AC) [15:06:58:328]: APPCOMPAT: no matching ProductCode found in database.
MSI (c) (B0:AC) [15:06:58:328]: MSCOREE not loaded loading copy from system32
MSI (c) (B0:AC) [15:06:58:344]: Machine policy value 'TransformsSecure' is 0
MSI (c) (B0:AC) [15:06:58:344]: User policy value 'TransformsAtSource' is 0
MSI (c) (B0:AC) [15:06:58:344]: Note: 1: 2262 2: File 3: -2147287038
MSI (c) (B0:AC) [15:06:58:344]: Note: 1: 2262 2: MsiFileHash 3: -2147287038
MSI (c) (B0:AC) [15:06:58:344]: Machine policy value 'DisablePatch' is 0
MSI (c) (B0:AC) [15:06:58:344]: Machine policy value 'AllowLockdownPatch' is 0
MSI (c) (B0:AC) [15:06:58:344]: Machine policy value 'DisableLUAPatching' is 0
MSI (c) (B0:AC) [15:06:58:344]: Machine policy value 'DisableFlyWeightPatching' is 0
MSI (c) (B0:AC) [15:06:58:344]: Enabling baseline caching for this transaction since all active patches are MSI 3.0 style MSPs or at least one MSI 3.0 minor update patch is active
MSI (c) (B0:AC) [15:06:58:344]: APPCOMPAT: looking for appcompat database entry with ProductCode '{55D13F49-FCB8-4892-8266-05D373FCAA61}'.
MSI (c) (B0:AC) [15:06:58:344]: APPCOMPAT: no matching ProductCode found in database.
MSI (c) (B0:AC) [15:06:58:344]: Transforms are not secure.
MSI (c) (B0:AC) [15:06:58:344]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\j\AppData\Local\Temp\MSI3e2c0.LOG'.
MSI (c) (B0:AC) [15:06:58:344]: Command Line: CURRENTDIRECTORY=C:\Users\j\Desktop CLIENTUILEVEL=0 CLIENTPROCESSID=1968
MSI (c) (B0:AC) [15:06:58:344]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{1C7C3009-013E-4A16-9A0F-0000FB80A613}'.
MSI (c) (B0:AC) [15:06:58:344]: Product Code passed to Engine.Initialize: ''
MSI (c) (B0:AC) [15:06:58:344]: Product Code from property table before transforms: '{55D13F49-FCB8-4892-8266-05D373FCAA61}'
MSI (c) (B0:AC) [15:06:58:344]: Product Code from property table after transforms: '{55D13F49-FCB8-4892-8266-05D373FCAA61}'
MSI (c) (B0:AC) [15:06:58:344]: Product not registered: beginning first-time install
MSI (c) (B0:AC) [15:06:58:344]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
MSI (c) (B0:AC) [15:06:58:344]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI (c) (B0:AC) [15:06:58:344]: User policy value 'SearchOrder' is 'nmu'
MSI (c) (B0:AC) [15:06:58:344]: Adding new sources is allowed.
MSI (c) (B0:AC) [15:06:58:344]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
MSI (c) (B0:AC) [15:06:58:344]: Package name extracted from package path: 'MicrosoftFixit50381.msi'
MSI (c) (B0:AC) [15:06:58:344]: Package to be registered: 'MicrosoftFixit50381.msi'
MSI (c) (B0:AC) [15:06:58:344]: Note: 1: 2262 2: Error 3: -2147287038
MSI (c) (B0:AC) [15:06:58:344]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI (c) (B0:AC) [15:06:58:344]: Machine policy value 'DisableMsi' is 0
MSI (c) (B0:AC) [15:06:58:344]: Machine policy value 'AlwaysInstallElevated' is 0
MSI (c) (B0:AC) [15:06:58:344]: User policy value 'AlwaysInstallElevated' is 0
MSI (c) (B0:AC) [15:06:58:344]: Running product '{55D13F49-FCB8-4892-8266-05D373FCAA61}' with user privileges: It's not assigned.
MSI (c) (B0:AC) [15:06:58:344]: PROPERTY CHANGE: Adding CURRENTDIRECTORY property. Its value is 'C:\Users\j\Desktop'.
MSI (c) (B0:AC) [15:06:58:344]: PROPERTY CHANGE: Adding CLIENTUILEVEL property. Its value is '0'.
MSI (c) (B0:AC) [15:06:58:344]: PROPERTY CHANGE: Adding CLIENTPROCESSID property. Its value is '1968'.
MSI (c) (B0:AC) [15:06:58:344]: TRANSFORMS property is now:
MSI (c) (B0:AC) [15:06:58:344]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
MSI (c) (B0:AC) [15:06:58:344]: SHELL32::SHGetFolderPath returned: C:\Users\j\AppData\Roaming
MSI (c) (B0:AC) [15:06:58:344]: SHELL32::SHGetFolderPath returned: C:\Users\j\Favorites
MSI (c) (B0:AC) [15:06:58:344]: SHELL32::SHGetFolderPath returned: C:\Users\j\AppData\Roaming\Microsoft\Windows\Network Shortcuts
MSI (c) (B0:AC) [15:06:58:344]: SHELL32::SHGetFolderPath returned: C:\Users\j\Contacts\Documents\Documents
MSI (c) (B0:AC) [15:06:58:344]: SHELL32::SHGetFolderPath returned: C:\Users\j\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
MSI (c) (B0:AC) [15:06:58:344]: SHELL32::SHGetFolderPath returned: C:\Users\j\AppData\Roaming\Microsoft\Windows\Recent
MSI (c) (B0:AC) [15:06:58:344]: SHELL32::SHGetFolderPath returned: C:\Users\j\AppData\Roaming\Microsoft\Windows\SendTo
MSI (c) (B0:AC) [15:06:58:344]: SHELL32::SHGetFolderPath returned: C:\Users\j\AppData\Roaming\Microsoft\Windows\Templates
MSI (c) (B0:AC) [15:06:58:344]: SHELL32::SHGetFolderPath returned: C:\ProgramData
MSI (c) (B0:AC) [15:06:58:344]: SHELL32::SHGetFolderPath returned: C:\Users\j\AppData\Local
MSI (c) (B0:AC) [15:06:58:344]: SHELL32::SHGetFolderPath returned: C:\Users\j\Pictures
MSI (c) (B0:AC) [15:06:58:344]: SHELL32::SHGetFolderPath returned: C:\Users\j\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI (c) (B0:AC) [15:06:58:344]: SHELL32::SHGetFolderPath returned: C:\Users\j\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
MSI (c) (B0:AC) [15:06:58:344]: SHELL32::SHGetFolderPath returned: C:\Users\j\Desktop
MSI (c) (B0:AC) [15:06:58:344]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI (c) (B0:AC) [15:06:58:344]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
MSI (c) (B0:AC) [15:06:58:344]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
MSI (c) (B0:AC) [15:06:58:344]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts
MSI (c) (B0:AC) [15:06:58:344]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
MSI (c) (B0:AC) [15:06:58:344]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
MSI (c) (B0:AC) [15:06:58:344]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
MSI (c) (B0:AC) [15:06:58:344]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
MSI (c) (B0:AC) [15:06:58:344]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI (c) (B0:AC) [15:06:58:344]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'j'.
MSI (c) (B0:AC) [15:06:58:344]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Users\j\Desktop\MicrosoftFixit50381.msi'.
MSI (c) (B0:AC) [15:06:58:344]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Users\j\Desktop\MicrosoftFixit50381.msi'.
MSI (c) (B0:AC) [15:06:58:344]: Machine policy value 'MsiDisableEmbeddedUI' is 0
MSI (c) (B0:AC) [15:06:58:344]: PROPERTY CHANGE: Adding SourceDir property. Its value is 'C:\Users\j\Desktop\'.
MSI (c) (B0:AC) [15:06:58:344]: PROPERTY CHANGE: Adding SOURCEDIR property. Its value is 'C:\Users\j\Desktop\'.
MSI (c) (B0:68) [15:06:58:344]: PROPERTY CHANGE: Adding VersionHandler property. Its value is '5.00'.
=== Logging started: 6/13/2012 15:06:58 ===
MSI (c) (B0:AC) [15:06:58:344]: Note: 1: 2262 2: PatchPackage 3: -2147287038
MSI (c) (B0:AC) [15:06:58:344]: Machine policy value 'DisableRollback' is 0
MSI (c) (B0:AC) [15:06:58:344]: User policy value 'DisableRollback' is 0
MSI (c) (B0:AC) [15:06:58:344]: PROPERTY CHANGE: Adding UILevel property. Its value is '5'.
MSI (c) (B0:AC) [15:06:58:344]: Note: 1: 2262 2: Font 3: -2147287038
MSI (c) (B0:AC) [15:06:58:344]: PROPERTY CHANGE: Adding ACTION property. Its value is 'INSTALL'.
MSI (c) (B0:AC) [15:06:58:344]: Doing action: INSTALL
Action 15:06:58: INSTALL.
Action start 15:06:58: INSTALL.
MSI (c) (B0:AC) [15:06:58:344]: UI Sequence table 'InstallUISequence' is present and populated.
MSI (c) (B0:AC) [15:06:58:344]: Running UISequence
MSI (c) (B0:AC) [15:06:58:344]: PROPERTY CHANGE: Adding EXECUTEACTION property. Its value is 'INSTALL'.
MSI (c) (B0:AC) [15:06:58:344]: Doing action: Milestone_ERRCA_UIAN726
Action 15:06:58: Milestone_ERRCA_UIAN726.
Action start 15:06:58: Milestone_ERRCA_UIAN726.
MSI (c) (B0:AC) [15:06:58:344]: Note: 1: 2235 2: 3: ExtendedType 4: SELECT `Action`,`Type`,`Source`,`Target`, NULL, `ExtendedType` FROM `CustomAction` WHERE `Action` = 'Milestone_ERRCA_UIAN726'
MSI (c) (B0:AC) [15:06:58:344]: PROPERTY CHANGE: Adding Milestone property. Its value is 'ERRCA_UIANDADVERTISED'.
Action ended 15:06:58: Milestone_ERRCA_UIAN726. Return value 1.
MSI (c) (B0:AC) [15:06:58:344]: Skipping action: ERRCA_UIANDADVERTISED (condition is false)
MSI (c) (B0:AC) [15:06:58:344]: Doing action: Milestone_AppSearch122
Action 15:06:58: Milestone_AppSearch122.
Action start 15:06:58: Milestone_AppSearch122.
MSI (c) (B0:AC) [15:06:58:344]: Note: 1: 2235 2: 3: ExtendedType 4: SELECT `Action`,`Type`,`Source`,`Target`, NULL, `ExtendedType` FROM `CustomAction` WHERE `Action` = 'Milestone_AppSearch122'
MSI (c) (B0:AC) [15:06:58:344]: PROPERTY CHANGE: Modifying Milestone property. Its current value is 'ERRCA_UIANDADVERTISED'. Its new value: 'AppSearch'.
Action ended 15:06:58: Milestone_AppSearch122. Return value 1.
MSI (c) (B0:AC) [15:06:58:359]: Doing action: AppSearch
Action 15:06:58: AppSearch. {\FinalUIFont}[PROGRESS_RESTORE_TXT]
Action start 15:06:58: AppSearch.
MSI (c) (B0:AC) [15:06:58:359]: Note: 1: 2262 2: AppSearch 3: -2147287038
Action ended 15:06:58: AppSearch. Return value 1.
MSI (c) (B0:AC) [15:06:58:359]: Doing action: FindRelatedProducts
Action 15:06:58: FindRelatedProducts. {\FinalUIFont}[PROGRESS_RESTORE_TXT]
Action start 15:06:58: FindRelatedProducts.
Action ended 15:06:58: FindRelatedProducts. Return value 1.
MSI (c) (B0:AC) [15:06:58:359]: Doing action: Milestone_EulaForm201
Action 15:06:58: Milestone_EulaForm201.
Action start 15:06:58: Milestone_EulaForm201.
MSI (c) (B0:AC) [15:06:58:359]: Note: 1: 2235 2: 3: ExtendedType 4: SELECT `Action`,`Type`,`Source`,`Target`, NULL, `ExtendedType` FROM `CustomAction` WHERE `Action` = 'Milestone_EulaForm201'
MSI (c) (B0:AC) [15:06:58:359]: PROPERTY CHANGE: Modifying Milestone property. Its current value is 'AppSearch'. Its new value: 'EulaForm'.
Action ended 15:06:58: Milestone_EulaForm201. Return value 1.
MSI (c) (B0:AC) [15:06:58:359]: Doing action: EulaForm
Action 15:06:58: EulaForm.
Action start 15:06:58: EulaForm.
MSI (c) (B0:AC) [15:06:58:359]: Note: 1: 2235 2: 3: ExtendedType 4: SELECT `Action`,`Type`,`Source`,`Target`, NULL, `ExtendedType` FROM `CustomAction` WHERE `Action` = 'EulaForm'
MSI (c) (B0:68) [15:06:58:359]: Note: 1: 2262 2: Error 3: -2147287038
Info 2898.For VSI_MS_Sans_Serif13.0_0_0 textstyle, the system created a 'MS Sans Serif' font, in 0 character set, of 13 pixels height.
Info 2898.For VsdDefaultUIFont.524F4245_5254_5341_4C45_534153783400 textstyle, the system created a 'MS Sans Serif' font, in 0 character set, of 13 pixels height.
Info 2898.For VSI_MS_Sans_Serif16.0_1_0 textstyle, the system created a 'MS Sans Serif' font, in 0 character set, of 20 pixels height.
MSI (c) (B0:68) [15:06:58:359]: Note: 1: 2262 2: CheckBox 3: -2147287038
Action 15:06:58: EulaForm. Dialog created
MSI (c) (B0:18) [15:06:58:375]: Note: 1: 2731 2: 0
MSI (c) (B0:68) [15:07:00:419]: PROPERTY CHANGE: Adding EulaForm_Property property. Its value is '1'.
Action ended 15:07:01: EulaForm. Return value 1.
MSI (c) (B0:AC) [15:07:01:791]: Doing action: EULAACCEPTED_ACTION
Action 15:07:01: EULAACCEPTED_ACTION.
Action start 15:07:01: EULAACCEPTED_ACTION.
MSI (c) (B0:AC) [15:07:01:807]: Note: 1: 2235 2: 3: ExtendedType 4: SELECT `Action`,`Type`,`Source`,`Target`, NULL, `ExtendedType` FROM `CustomAction` WHERE `Action` = 'EULAACCEPTED_ACTION'
MSI (c) (B0:AC) [15:07:01:807]: PROPERTY CHANGE: Adding EULAACCEPTED property. Its value is '1'.
Action ended 15:07:01: EULAACCEPTED_ACTION. Return value 1.
MSI (c) (B0:AC) [15:07:01:807]: Doing action: Milestone_LaunchCond24
Action 15:07:01: Milestone_LaunchCond24.
Action start 15:07:01: Milestone_LaunchCond24.
MSI (c) (B0:AC) [15:07:01:807]: Note: 1: 2235 2: 3: ExtendedType 4: SELECT `Action`,`Type`,`Source`,`Target`, NULL, `ExtendedType` FROM `CustomAction` WHERE `Action` = 'Milestone_LaunchCond24'
MSI (c) (B0:AC) [15:07:01:807]: PROPERTY CHANGE: Modifying Milestone property. Its current value is 'EulaForm'. Its new value: 'LaunchConditions'.
Action ended 15:07:01: Milestone_LaunchCond24. Return value 1.
MSI (c) (B0:AC) [15:07:01:807]: Doing action: LaunchConditions
Action 15:07:01: LaunchConditions. {\FinalUIFont}[PROGRESS_RESTORE_TXT]
Action start 15:07:01: LaunchConditions.
Action ended 15:07:01: LaunchConditions. Return value 1.
MSI (c) (B0:AC) [15:07:01:807]: Doing action: CCPSearch
Action 15:07:01: CCPSearch. {\FinalUIFont}[PROGRESS_RESTORE_TXT]
Action start 15:07:01: CCPSearch.
MSI (c) (B0:AC) [15:07:01:807]: Note: 1: 2262 2: CCPSearch 3: -2147287038
Action ended 15:07:01: CCPSearch. Return value 1.
MSI (c) (B0:AC) [15:07:01:807]: Doing action: RMCCPSearch
Action 15:07:01: RMCCPSearch. {\FinalUIFont}[PROGRESS_RESTORE_TXT]
Action start 15:07:01: RMCCPSearch.
Action ended 15:07:01: RMCCPSearch. Return value 0.
MSI (c) (B0:AC) [15:07:01:807]: Doing action: ValidateProductID
Action 15:07:01: ValidateProductID. {\FinalUIFont}[PROGRESS_RESTORE_TXT]
Action start 15:07:01: ValidateProductID.
Action ended 15:07:01: ValidateProductID. Return value 1.
MSI (c) (B0:AC) [15:07:01:807]: Doing action: Milestone_DIRCA_TARG947
Action 15:07:01: Milestone_DIRCA_TARG947.
Action start 15:07:01: Milestone_DIRCA_TARG947.
MSI (c) (B0:AC) [15:07:01:807]: Note: 1: 2235 2: 3: ExtendedType 4: SELECT `Action`,`Type`,`Source`,`Target`, NULL, `ExtendedType` FROM `CustomAction` WHERE `Action` = 'Milestone_DIRCA_TARG947'
MSI (c) (B0:AC) [15:07:01:807]: PROPERTY CHANGE: Modifying Milestone property. Its current value is 'LaunchConditions'. Its new value: 'DIRCA_TARGETDIR'.
Action ended 15:07:01: Milestone_DIRCA_TARG947. Return value 1.
MSI (c) (B0:AC) [15:07:01:807]: Doing action: DIRCA_TARGETDIR
Action 15:07:01: DIRCA_TARGETDIR. {\FinalUIFont}[PROGRESS_RESTORE_TXT]
Action start 15:07:01: DIRCA_TARGETDIR.
MSI (c) (B0:AC) [15:07:01:807]: Note: 1: 2235 2: 3: ExtendedType 4: SELECT `Action`,`Type`,`Source`,`Target`, NULL, `ExtendedType` FROM `CustomAction` WHERE `Action` = 'DIRCA_TARGETDIR'
MSI (c) (B0:AC) [15:07:01:807]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'C:\Program Files (x86)\Microsoft\Microsoft Fix it 50381'.
Action ended 15:07:01: DIRCA_TARGETDIR. Return value 1.
MSI (c) (B0:AC) [15:07:01:807]: Doing action: CostInitialize
Action 15:07:01: CostInitialize. {\FinalUIFont}[PROGRESS_RESTORE_TXT]
Action start 15:07:01: CostInitialize.
MSI (c) (B0:AC) [15:07:01:807]: Machine policy value 'MaxPatchCacheSize' is 10
MSI (c) (B0:AC) [15:07:01:807]: Baseline: Sorting baselines for {55D13F49-FCB8-4892-8266-05D373FCAA61}.
MSI (c) (B0:AC) [15:07:01:807]: Baseline: New baseline 2.1.3 from transaction.
MSI (c) (B0:AC) [15:07:01:807]: Baseline: Sorted order Native: Order 0.
MSI (c) (B0:AC) [15:07:01:807]: Baseline Data Table:
MSI (c) (B0:AC) [15:07:01:807]: ProductCode: {55D13F49-FCB8-4892-8266-05D373FCAA61} Version: 2.1.3 Attributes: 0 PatchId: Native BaselineId: -2147483648 Order: 0
MSI (c) (B0:AC) [15:07:01:807]: Baseline File Table:
MSI (c) (B0:AC) [15:07:01:807]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'C:\'.
MSI (c) (B0:AC) [15:07:01:807]: PROPERTY CHANGE: Adding CostingComplete property. Its value is '0'.
Action ended 15:07:01: CostInitialize. Return value 1.
MSI (c) (B0:AC) [15:07:01:807]: Doing action: FileCost
Action 15:07:01: FileCost. {\FinalUIFont}[PROGRESS_RESTORE_TXT]
Action start 15:07:01: FileCost.
MSI (c) (B0:AC) [15:07:01:807]: Note: 1: 2262 2: MsiAssembly 3: -2147287038
MSI (c) (B0:AC) [15:07:01:807]: Note: 1: 2262 2: RemoveFile 3: -2147287038
MSI (c) (B0:AC) [15:07:01:807]: Note: 1: 2262 2: MoveFile 3: -2147287038
MSI (c) (B0:AC) [15:07:01:807]: Note: 1: 2262 2: DuplicateFile 3: -2147287038
MSI (c) (B0:AC) [15:07:01:807]: Note: 1: 2262 2: Shortcut 3: -2147287038
MSI (c) (B0:AC) [15:07:01:807]: Note: 1: 2262 2: Class 3: -2147287038
MSI (c) (B0:AC) [15:07:01:807]: Note: 1: 2262 2: Extension 3: -2147287038
MSI (c) (B0:AC) [15:07:01:807]: Note: 1: 2262 2: TypeLib 3: -2147287038
MSI (c) (B0:AC) [15:07:01:807]: Note: 1: 2262 2: IniFile 3: -2147287038
MSI (c) (B0:AC) [15:07:01:807]: Note: 1: 2262 2: ReserveCost 3: -2147287038
Action ended 15:07:01: FileCost. Return value 1.
MSI (c) (B0:AC) [15:07:01:807]: Doing action: IsolateComponents
Action 15:07:01: IsolateComponents. {\FinalUIFont}[PROGRESS_RESTORE_TXT]
Action start 15:07:01: IsolateComponents.
MSI (c) (B0:AC) [15:07:01:807]: Note: 1: 2262 2: BindImage 3: -2147287038
MSI (c) (B0:AC) [15:07:01:807]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038
MSI (c) (B0:AC) [15:07:01:807]: Note: 1: 2262 2: Patch 3: -2147287038
Action ended 15:07:01: IsolateComponents. Return value 1.
MSI (c) (B0:AC) [15:07:01:807]: Skipping action: ResumeForm (condition is false)
MSI (c) (B0:AC) [15:07:01:807]: Skipping action: MaintenanceForm (condition is false)
MSI (c) (B0:AC) [15:07:01:807]: Doing action: CostFinalize
Action 15:07:01: CostFinalize. {\FinalUIFont}[PROGRESS_RESTORE_TXT]
Action start 15:07:01: CostFinalize.
MSI (c) (B0:AC) [15:07:01:807]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is '0'.
MSI (c) (B0:AC) [15:07:01:807]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is '0'.
MSI (c) (B0:AC) [15:07:01:807]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is '0'.
MSI (c) (B0:AC) [15:07:01:807]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is '0'.
MSI (c) (B0:AC) [15:07:01:807]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is '0'.
MSI (c) (B0:AC) [15:07:01:807]: Note: 1: 2262 2: Condition 3: -2147287038
MSI (c) (B0:AC) [15:07:01:807]: PROPERTY CHANGE: Modifying TARGETDIR property. Its current value is 'C:\Program Files (x86)\Microsoft\Microsoft Fix it 50381'. Its new value: 'C:\Program Files (x86)\Microsoft\Microsoft Fix it 50381\'.
MSI (c) (B0:AC) [15:07:01:807]: Target path resolution complete. Dumping Directory table...
MSI (c) (B0:AC) [15:07:01:807]: Note: target paths subject to change (via custom actions or browsing)
MSI (c) (B0:AC) [15:07:01:807]: Dir (target): Key: TARGETDIR , Object: C:\Program Files (x86)\Microsoft\Microsoft Fix it 50381\
MSI (c) (B0:AC) [15:07:01:807]: Dir (target): Key: WindowsFolder , Object: C:\Windows\
MSI (c) (B0:AC) [15:07:01:807]: Dir (target): Key: ProgramMenuFolder , Object: C:\Users\j\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\
MSI (c) (B0:AC) [15:07:01:807]: Dir (target): Key: DesktopFolder , Object: C:\Users\j\Desktop\
MSI (c) (B0:AC) [15:07:01:807]: PROPERTY CHANGE: Adding INSTALLLEVEL property. Its value is '1'.
Action ended 15:07:01: CostFinalize. Return value 1.
MSI (c) (B0:AC) [15:07:01:807]: Doing action: ProgressForm
Action 15:07:01: ProgressForm.
Action start 15:07:01: ProgressForm.
MSI (c) (B0:AC) [15:07:01:807]: Note: 1: 2235 2: 3: ExtendedType 4: SELECT `Action`,`Type`,`Source`,`Target`, NULL, `ExtendedType` FROM `CustomAction` WHERE `Action` = 'ProgressForm'
MSI (c) (B0:68) [15:07:01:807]: Note: 1: 2262 2: Error 3: -2147287038
DEBUG: Error 2826: Control Line1 on dialog ProgressForm extends beyond the boundaries of the dialog to the right by 3 pixels
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2826. The arguments are: ProgressForm, Line1, to the right
DEBUG: Error 2826: Control Line2 on dialog ProgressForm extends beyond the boundaries of the dialog to the right by 3 pixels
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2826. The arguments are: ProgressForm, Line2, to the right
DEBUG: Error 2826: Control BannerBmp on dialog ProgressForm extends beyond the boundaries of the dialog to the right by 3 pixels
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2826. The arguments are: ProgressForm, BannerBmp, to the right
Action 15:07:01: ProgressForm. Dialog created
Action ended 15:07:01: ProgressForm. Return value 1.
MSI (c) (B0:AC) [15:07:01:854]: Doing action: ExecuteAction
Action 15:07:01: ExecuteAction. {\FinalUIFont}[PROGRESS_RESTORE_TXT]
MSI (c) (B0:68) [15:07:01:854]: Note: 1: 2262 2: Error 3: -2147287038
Info 2898.For FinalUIFont textstyle, the system created a 'Arial' font, in 0 character set, of 15 pixels height.
Action start 15:07:01: ExecuteAction.
MSI (c) (B0:AC) [15:07:01:854]: PROPERTY CHANGE: Adding SECONDSEQUENCE property. Its value is '1'.
MSI (c) (B0:AC) [15:07:01:854]: Grabbed execution mutex.
MSI (c) (B0:AC) [15:07:01:854]: Incrementing counter to disable shutdown. Counter after increment: 0
MSI (c) (B0:AC) [15:07:01:854]: Switching to server: TARGETDIR="C:\Program Files (x86)\Microsoft\Microsoft Fix it 50381\" EULAACCEPTED="1" CURRENTDIRECTORY="C:\Users\j\Desktop" CLIENTUILEVEL="0" CLIENTPROCESSID="1968" USERNAME="j" SOURCEDIR="C:\Users\j\Desktop\" ACTION="INSTALL" EXECUTEACTION="INSTALL" ROOTDRIVE="C:\" INSTALLLEVEL="1" SECONDSEQUENCE="1" ADDLOCAL=DefaultFeature
MSI (s) (50:6C) [15:07:01:854]: Running installation inside multi-package transaction C:\Users\j\Desktop\MicrosoftFixit50381.msi
MSI (s) (50:6C) [15:07:01:854]: Grabbed execution mutex.
MSI (s) (50:68) [15:07:01:854]: Resetting cached policy values
MSI (s) (50:68) [15:07:01:854]: Machine policy value 'Debug' is 0
MSI (s) (50:68) [15:07:01:854]: ******* RunEngine:
******* Action: INSTALL
MSI (s) (50:68) [15:07:01:854]: Machine policy value 'DisableUserInstalls' is 0
MSI (s) (50:68) [15:07:01:854]: Setting cached product context: User non-assigned for product: 2AD34A7BDF2F2C440A442DC473151CDB
MSI (s) (50:68) [15:07:01:854]: Using cached product context: User non-assigned for product: 2AD34A7BDF2F2C440A442DC473151CDB
MSI (s) (50:68) [15:07:01:854]: Setting cached product context: User non-assigned for product: DED5B648C8CDA1E45B4BF9B5930AACEC
MSI (s) (50:68) [15:07:01:854]: Using cached product context: User non-assigned for product: DED5B648C8CDA1E45B4BF9B5930AACEC
MSI (s) (50:68) [15:07:01:854]: Setting cached product context: machine assigned for product: 00002109020090400000000000F01FEC
MSI (s) (50:68) [15:07:01:854]: Using cached product context: machine assigned for product: 00002109020090400000000000F01FEC
MSI (s) (50:68) [15:07:01:854]: Setting cached product context: machine assigned for product: 000021599B0090400100000000F01FEC
MSI (s) (50:68) [15:07:01:854]: Using cached product context: machine assigned for product: 000021599B0090400100000000F01FEC
MSI (s) (50:68) [15:07:01:854]: Setting cached product context: machine assigned for product: 00004109500200000000000000F01FEC
MSI (s) (50:68) [15:07:01:854]: Using cached product context: machine assigned for product: 00004109500200000000000000F01FEC
MSI (s) (50:68) [15:07:01:854]: Setting cached product context: machine assigned for product: 00006FCA9B229EC4896DC2FC53B9CA70
MSI (s) (50:68) [15:07:01:854]: Using cached product context: machine assigned for product: 00006FCA9B229EC4896DC2FC53B9CA70
MSI (s) (50:68) [15:07:01:854]: Setting cached product context: machine assigned for product: 03FDC343E20F0A006C18236657A5C99F
MSI (s) (50:68) [15:07:01:854]: Using cached product context: machine assigned for product: 03FDC343E20F0A006C18236657A5C99F
MSI (s) (50:68) [15:07:01:854]: Setting cached product context: machine assigned for product: 05175FCAB0C45D78863BE210910CF07B
MSI (s) (50:68) [15:07:01:854]: Using cached product context: machine assigned for product: 05175FCAB0C45D78863BE210910CF07B
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 0D756077321A70C3E844C138CE981581
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 0D756077321A70C3E844C138CE981581
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 108D9FFC4CE15F8BC2BAA471099CA581
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 108D9FFC4CE15F8BC2BAA471099CA581
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 166F59DC4C5A5F446AAACEDD192C043D
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 166F59DC4C5A5F446AAACEDD192C043D
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 166F59DC4C5A5F446AAACEDD192C04DC
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 166F59DC4C5A5F446AAACEDD192C04DC
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 1af2a8da7e60d0b429d7e6453b3d0182
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 1af2a8da7e60d0b429d7e6453b3d0182
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 1D034B0FAA6BD374B960AAD30DF10D8B
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 1D034B0FAA6BD374B960AAD30DF10D8B
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 1D5E3C0FEDA1E123187686FED06E995A
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 1D5E3C0FEDA1E123187686FED06E995A
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 230C33823BDAFFDD49CB4E5F655AA793
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 230C33823BDAFFDD49CB4E5F655AA793
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 25F0F292D26B17E429B1986A28042210
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 25F0F292D26B17E429B1986A28042210
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 269AA0DAE1115D147A50E0D319876A16
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 269AA0DAE1115D147A50E0D319876A16
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 2732C0CDCD59FDB09D0F10386DE0ADB7
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 2732C0CDCD59FDB09D0F10386DE0ADB7
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 286FF0AF07CC75C439DC2E673F7E35E7
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 286FF0AF07CC75C439DC2E673F7E35E7
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 2A2C9928636BD0EACEBD348535D5CC17
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 2A2C9928636BD0EACEBD348535D5CC17
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 2A7527EE2A93F2D4D9CA9F2FB5A81E8D
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 2A7527EE2A93F2D4D9CA9F2FB5A81E8D
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 2EBA015DCB4582B135A639DE38C3978D
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 2EBA015DCB4582B135A639DE38C3978D
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 3240FB1934BBD272081E5A78E37163C5
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 3240FB1934BBD272081E5A78E37163C5
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 32E20A7AC508CAA44B805DA9D135EA6A
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 32E20A7AC508CAA44B805DA9D135EA6A
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 339DC8CE50724A3E5C959AF423EC3E1E
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 339DC8CE50724A3E5C959AF423EC3E1E
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 386D3EFEC30985B4BAF86CC8963F7385
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 386D3EFEC30985B4BAF86CC8963F7385
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 3E7D940E935EDC0BA103E6F043EE8EF5
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 3E7D940E935EDC0BA103E6F043EE8EF5
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 3ECDCD77DED23F261845507E5474D270
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 3ECDCD77DED23F261845507E5474D270
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 3EFC05AE6599898CB093FF27FCD78E04
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 3EFC05AE6599898CB093FF27FCD78E04
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 44C2AF74841DCBD4FA069B9143AA8424
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 44C2AF74841DCBD4FA069B9143AA8424
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 45D25C75464F12C0E6D2FDC30A1D1699
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 45D25C75464F12C0E6D2FDC30A1D1699
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 46A934DE810F4DD4B85A23D858BA90BA
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 46A934DE810F4DD4B85A23D858BA90BA
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 4B9515E6915AFE1408FEDA85735151FD
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 4B9515E6915AFE1408FEDA85735151FD
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 4ccf9caae9dddda409c15b94a670bae2
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 4ccf9caae9dddda409c15b94a670bae2
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 4EA42A62D9304AC4784BF238120613FF
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 4EA42A62D9304AC4784BF238120613FF
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 4EA42A62D9304AC4784BF268140622FF
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 4EA42A62D9304AC4784BF268140622FF
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 4EA42A62D9304AC4784BF268140662FF
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 4EA42A62D9304AC4784BF268140662FF
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 4EA42A62D9304AC4784BF268140750FF
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 4EA42A62D9304AC4784BF268140750FF
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 503E35785372F36AAF53AE899CAF076F
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 503E35785372F36AAF53AE899CAF076F
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 54C3703830031764A96842A3AADD19A5
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 54C3703830031764A96842A3AADD19A5
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 55C2BC09D624257069D8B9F0110102A2
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 55C2BC09D624257069D8B9F0110102A2
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 568774731F3A2774DA34AACFB6FC9FF9
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 568774731F3A2774DA34AACFB6FC9FF9
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 57F51FE82AD37612BC300D69DBD169EF
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 57F51FE82AD37612BC300D69DBD169EF
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 58A351005490E997645A9CD2C3F658E2
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 58A351005490E997645A9CD2C3F658E2
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 5A051352A0CD0802A9F5D5D1D7F55E83
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 5A051352A0CD0802A9F5D5D1D7F55E83
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 5E1F9BD7BCA9D0147ACDA7D320C30E54
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 5E1F9BD7BCA9D0147ACDA7D320C30E54
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 5ED62A6B5B2F85D45907F47C060EF0DC
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 5ED62A6B5B2F85D45907F47C060EF0DC
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 67D6ECF5CD5FBA732B8B22BAC8DE1B4D
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 67D6ECF5CD5FBA732B8B22BAC8DE1B4D
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 68A86D24C1BD65248B9CD5D02919A95F
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 68A86D24C1BD65248B9CD5D02919A95F
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 68AB67CA3301004FABE7000000000050
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 68AB67CA3301004FABE7000000000050
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 68AB67CA7DA706750000090000000030
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 68AB67CA7DA706750000090000000030
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 68AB67CA7DA73301B7449A0400000010
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 68AB67CA7DA73301B7449A0400000010
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 6911F73CE72DC564882186271A00975C
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 6911F73CE72DC564882186271A00975C
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 6E3C12FFDF79F4745981D8BC9EC48245
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 6E3C12FFDF79F4745981D8BC9EC48245
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 6E58EC68CABDDFF39B774E7BF9389C90
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 6E58EC68CABDDFF39B774E7BF9389C90
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 6E815EB96CCE9A53884E7857C57002F0
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 6E815EB96CCE9A53884E7857C57002F0
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 6E8A266FCD4F2A1409E1C8110F44DBCE
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 6E8A266FCD4F2A1409E1C8110F44DBCE
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 6E9736FB63990B646BCA5CE63E89D7E2
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 6E9736FB63990B646BCA5CE63E89D7E2
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 6F9E66FF7E38E3A3FA41D89E8A906A4A
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 6F9E66FF7E38E3A3FA41D89E8A906A4A
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 6FF3CC3F07FC91B389EF4A1160E832B1
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 6FF3CC3F07FC91B389EF4A1160E832B1
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 701043F6AA9F6C745BC43C1AF91155F3
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 701043F6AA9F6C745BC43C1AF91155F3
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 788E47A8F0F87104FA35BC4A2211AA5A
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 788E47A8F0F87104FA35BC4A2211AA5A
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 7ADB9507BD1EC2447B1A16449576024A
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 7ADB9507BD1EC2447B1A16449576024A
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 7B1896769D2A0D94F9C43010F831D19A
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 7B1896769D2A0D94F9C43010F831D19A
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 7E577B2224C65CF4E801A9E52375DB49
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 7E577B2224C65CF4E801A9E52375DB49
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 84b9c17023c712640acaf308593282f8
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 84b9c17023c712640acaf308593282f8
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 8C2F50BA806Fb304591EDFA8FDCA3DE1
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 8C2F50BA806Fb304591EDFA8FDCA3DE1
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 8DF49EE825F536443A0481D561231885
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 8DF49EE825F536443A0481D561231885
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 8EE82118DAE80BD4586C712CEC05FF17
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 8EE82118DAE80BD4586C712CEC05FF17
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 9040110900063D11C8EF10054038389C
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 9040110900063D11C8EF10054038389C
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 904CD28A11B6D7215AC3DC4069FF456A
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 904CD28A11B6D7215AC3DC4069FF456A
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 92810D8F1AC12E93F92AA4F5609F5659
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 92810D8F1AC12E93F92AA4F5609F5659
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 9363736248FC2C6060F6C938607FEDC1
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 9363736248FC2C6060F6C938607FEDC1
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 93FDBE4833B47D940ADBBEE6C2E4181C
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 93FDBE4833B47D940ADBBEE6C2E4181C
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 960EFD2EE3801364B9C6344CE899D15E
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 960EFD2EE3801364B9C6344CE899D15E
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 9624DEE6D8858b548AC0629AAC26EEE4
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 9624DEE6D8858b548AC0629AAC26EEE4
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 96F4F346A6A525B4DB65959008B055F6
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 96F4F346A6A525B4DB65959008B055F6
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 9B24BC6F330F25148831FF11ADE8A687
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 9B24BC6F330F25148831FF11ADE8A687
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 9B3B508BE94BAE4DCA362627638CE8AC
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 9B3B508BE94BAE4DCA362627638CE8AC
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 9DB288F89FC03DD3EFF6A397F636BEDC
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 9DB288F89FC03DD3EFF6A397F636BEDC
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: 9F2595648CECC8DF75A46AECA7F49E6A
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: 9F2595648CECC8DF75A46AECA7F49E6A
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: A1FFA879939B77148BA58CB78176CAC5
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: A1FFA879939B77148BA58CB78176CAC5
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: A3878338869058B3FA7CABEAA036CD05
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: A3878338869058B3FA7CABEAA036CD05
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: a4cab25097f64d640a42c11e4b7fc34d
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: a4cab25097f64d640a42c11e4b7fc34d
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: A4FA46DB08C82514DA77CFDD0F2580BA
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: A4FA46DB08C82514DA77CFDD0F2580BA
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: A6C4EA4EA1980053C1E3A7A06A6CD520
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: A6C4EA4EA1980053C1E3A7A06A6CD520
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: A7C639EE04AE5D13B956E8E380C98382
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: A7C639EE04AE5D13B956E8E380C98382
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: A7CD37D3D1D2FC54A876427893527C61
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: A7CD37D3D1D2FC54A876427893527C61
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: A80D00DEF5C3D884390A0AF4122F9365
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: A80D00DEF5C3D884390A0AF4122F9365
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: A9DF4E9D422FDD64BD4370BCAA7C159B
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: A9DF4E9D422FDD64BD4370BCAA7C159B
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: ABB21E0F66DA22044A351A8C0A4C5D07
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: ABB21E0F66DA22044A351A8C0A4C5D07
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: AE8C22496C0B79148BCFCD976785AC00
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: AE8C22496C0B79148BCFCD976785AC00
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: AFAD45F1162926A45BD9C6F9624BF84E
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: AFAD45F1162926A45BD9C6F9624BF84E
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: B0F57C6D1CB39CF48B5CF3E7E80D95AC
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: B0F57C6D1CB39CF48B5CF3E7E80D95AC
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: b25099274a207264182f8181add555d0
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: b25099274a207264182f8181add555d0
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: B280BA81485647F4A8CB5D39C54FE6C4
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: B280BA81485647F4A8CB5D39C54FE6C4
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: B55DF58AB1984134795AAE690CDB085B
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: B55DF58AB1984134795AAE690CDB085B
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: B5891039611D39A49AD349850048FF68
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: B5891039611D39A49AD349850048FF68
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: B7573E6B77E5519368A6CCCFB4D891C4
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: B7573E6B77E5519368A6CCCFB4D891C4
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: B7A5008C8369DD148BB3FA7277452E11
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: B7A5008C8369DD148BB3FA7277452E11
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: BD779456100020000010AEDB22D8EDB8
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: BD779456100020000010AEDB22D8EDB8
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: C173E5AD3336A8D3394AF65D2BB0CCE6
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: C173E5AD3336A8D3394AF65D2BB0CCE6
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: c1c4f01781cc94c4c8fb1542c0981a2a
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: c1c4f01781cc94c4c8fb1542c0981a2a
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: C28643E881181F13CBC489DC69571E2C
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: C28643E881181F13CBC489DC69571E2C
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: C4910073DD5CA934EB606A9606ACC407
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: C4910073DD5CA934EB606A9606ACC407
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: C491DB6F091437D41B1B4CC89929B1EF
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: C491DB6F091437D41B1B4CC89929B1EF
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: C5E15486C9A0C5D4D860E69226249E80
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: C5E15486C9A0C5D4D860E69226249E80
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: C6B56403F35B1A94E9AB3A1F78DA05E2
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: C6B56403F35B1A94E9AB3A1F78DA05E2
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: C78A0900E0E34D34AA177AB16065A3A4
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: C78A0900E0E34D34AA177AB16065A3A4
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: C8015D5A218EA87619EF921DDBEA36A6
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: C8015D5A218EA87619EF921DDBEA36A6
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: C88D1A60201E7254FA0792FF7DFA12A5
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: C88D1A60201E7254FA0792FF7DFA12A5
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: CA0B84B9318C4714092474A68857297C
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: CA0B84B9318C4714092474A68857297C
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: CADE42353DED56A38618484B8B8A7A9F
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: CADE42353DED56A38618484B8B8A7A9F
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: CEB6B96C0127B4CCF07429947E728599
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: CEB6B96C0127B4CCF07429947E728599
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: CFD2C1F142D260E3CB8B271543DA9F98
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: CFD2C1F142D260E3CB8B271543DA9F98
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: CFE98E2070B7A5D4AA30E90C099241EE
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: CFE98E2070B7A5D4AA30E90C099241EE
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: D03E6E60894BF2449A3470ED147D7F58
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: D03E6E60894BF2449A3470ED147D7F58
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: D20352A90C039D93DBF6126ECE614057
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: D20352A90C039D93DBF6126ECE614057
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: D276F30548C6A844F8F8B43CA58C4314
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: D276F30548C6A844F8F8B43CA58C4314
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: D7314F9862C648A4DB8BE2A5B47BE100
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: D7314F9862C648A4DB8BE2A5B47BE100
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: D8602CBBC9EC5F846AAEB4449BBD415A
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: D8602CBBC9EC5F846AAEB4449BBD415A
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: DBA18E807F972C9488F1DFC60B796539
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: DBA18E807F972C9488F1DFC60B796539
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: DDA39468D428E8B4DB27C8D5DC5CA217
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: DDA39468D428E8B4DB27C8D5DC5CA217
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: DDB6C50237B7ED245850A990F3532A83
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: DDB6C50237B7ED245850A990F3532A83
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: DE6B4B17576C7491810361C3365CC208
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: DE6B4B17576C7491810361C3365CC208
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: DFC90B5F2B0FFA63D84FD16F6BF37C4B
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: DFC90B5F2B0FFA63D84FD16F6BF37C4B
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: E072096A10A46DB4C8324C144377EED2
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: E072096A10A46DB4C8324C144377EED2
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: E2E1F599245F0134E8D199625F2A973B
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: E2E1F599245F0134E8D199625F2A973B
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: E5D9D200AB92D6E3B94CD3D7D6CB37C5
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: E5D9D200AB92D6E3B94CD3D7D6CB37C5
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: E6680C84BE75C4443817E8341260B63C
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: E6680C84BE75C4443817E8341260B63C
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: E757FC781F1C22D468C5006C59B02585
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: E757FC781F1C22D468C5006C59B02585
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: E9384A458F781DB469283A949E49F3A0
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: E9384A458F781DB469283A949E49F3A0
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: E979633747A3EE6E0BFE17E5AEEAD421
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: E979633747A3EE6E0BFE17E5AEEAD421
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: ECEC214627185EB439B5C6CECA2DAC78
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: ECEC214627185EB439B5C6CECA2DAC78
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: ED2388710ED978C4F92839519A0B9358
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: ED2388710ED978C4F92839519A0B9358
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: F207464E3345CE64F8565129670C5AF4
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: F207464E3345CE64F8565129670C5AF4
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: F336D6C736DCF835D064BBAF98EBC27A
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: F336D6C736DCF835D064BBAF98EBC27A
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: F60730A4A66673047777F5728467D401
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: F60730A4A66673047777F5728467D401
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: F7AC5766B15EA6F4994D8F0F21C4E6AA
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: F7AC5766B15EA6F4994D8F0F21C4E6AA
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: F7C5C8DC85C758F498776A0CC8809721
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: F7C5C8DC85C758F498776A0CC8809721
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: F92F4A37CA13DBE4AAB1C05C1FC8F838
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: F92F4A37CA13DBE4AAB1C05C1FC8F838
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: FB4B305EBB7FF5D3B88C6F491BFC9F24
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: FB4B305EBB7FF5D3B88C6F491BFC9F24
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: FB540C64F3B24CB4E8C4000EFCB89DBD
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: FB540C64F3B24CB4E8C4000EFCB89DBD
MSI (s) (50:68) [15:07:01:869]: Setting cached product context: machine assigned for product: FCD1B590B8E5CE74B9818491817A13BD
MSI (s) (50:68) [15:07:01:869]: Using cached product context: machine assigned for product: FCD1B590B8E5CE74B9818491817A13BD
MSI (s) (50:68) [15:07:01:885]: Machine policy value 'LimitSystemRestoreCheckpointing' is 0
MSI (s) (50:68) [15:07:01:885]: Note: 1: 1715 2: Microsoft Fix it 50381
MSI (s) (50:68) [15:07:01:885]: Note: 1: 2262 2: Error 3: -2147287038
MSI (s) (50:68) [15:07:01:885]: Calling SRSetRestorePoint API. dwRestorePtType: 0, dwEventType: 102, llSequenceNumber: 0, szDescription: "Installed Microsoft Fix it 50381".
MSI (s) (50:68) [15:07:07:969]: The call to SRSetRestorePoint API succeeded. Returned status: 0, llSequenceNumber: 111.
MSI (s) (50:68) [15:07:07:969]: File will have security applied from OpCode.
MSI (s) (50:68) [15:07:07:969]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Users\j\Desktop\MicrosoftFixit50381.msi' against software restriction policy
MSI (s) (50:68) [15:07:07:969]: SOFTWARE RESTRICTION POLICY: C:\Users\j\Desktop\MicrosoftFixit50381.msi has a digital signature
MSI (s) (50:68) [15:07:08:000]: SOFTWARE RESTRICTION POLICY: C:\Users\j\Desktop\MicrosoftFixit50381.msi is permitted to run at the 'unrestricted' authorization level.
MSI (s) (50:68) [15:07:08:000]: End dialog not enabled
MSI (s) (50:68) [15:07:08:000]: Original package ==> C:\Users\j\Desktop\MicrosoftFixit50381.msi
MSI (s) (50:68) [15:07:08:000]: Package we're running from ==> C:\Windows\Installer\142aa4.msi
MSI (s) (50:68) [15:07:08:000]: APPCOMPAT: Compatibility mode property overrides found.
MSI (s) (50:68) [15:07:08:000]: APPCOMPAT: looking for appcompat database entry with ProductCode '{55D13F49-FCB8-4892-8266-05D373FCAA61}'.
MSI (s) (50:68) [15:07:08:000]: APPCOMPAT: no matching ProductCode found in database.
MSI (s) (50:68) [15:07:08:000]: MSCOREE not loaded loading copy from system32
MSI (s) (50:68) [15:07:08:000]: Machine policy value 'TransformsSecure' is 0
MSI (s) (50:68) [15:07:08:000]: User policy value 'TransformsAtSource' is 0
MSI (s) (50:68) [15:07:08:000]: Note: 1: 2262 2: File 3: -2147287038
MSI (s) (50:68) [15:07:08:000]: Note: 1: 2262 2: MsiFileHash 3: -2147287038
MSI (s) (50:68) [15:07:08:000]: Machine policy value 'DisablePatch' is 0
MSI (s) (50:68) [15:07:08:000]: Machine policy value 'AllowLockdownPatch' is 0
MSI (s) (50:68) [15:07:08:000]: Machine policy value 'DisableLUAPatching' is 0
MSI (s) (50:68) [15:07:08:000]: Machine policy value 'DisableFlyWeightPatching' is 0
MSI (s) (50:68) [15:07:08:000]: Enabling baseline caching for this transaction since all active patches are MSI 3.0 style MSPs or at least one MSI 3.0 minor update patch is active
MSI (s) (50:68) [15:07:08:000]: Transforms are not secure.
MSI (s) (50:68) [15:07:08:000]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\j\AppData\Local\Temp\MSI3e2c0.LOG'.
MSI (s) (50:68) [15:07:08:000]: Command Line: TARGETDIR=C:\Program Files (x86)\Microsoft\Microsoft Fix it 50381\ EULAACCEPTED=1 CURRENTDIRECTORY=C:\Users\j\Desktop CLIENTUILEVEL=0 CLIENTPROCESSID=1968 USERNAME=j SOURCEDIR=C:\Users\j\Desktop\ ACTION=INSTALL EXECUTEACTION=INSTALL ROOTDRIVE=C:\ INSTALLLEVEL=1 SECONDSEQUENCE=1 ADDLOCAL=DefaultFeature ACTION=INSTALL
MSI (s) (50:68) [15:07:08:000]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{1C7C3009-013E-4A16-9A0F-0000FB80A613}'.
MSI (s) (50:68) [15:07:08:000]: Product Code passed to Engine.Initialize: ''
MSI (s) (50:68) [15:07:08:000]: Product Code from property table before transforms: '{55D13F49-FCB8-4892-8266-05D373FCAA61}'
MSI (s) (50:68) [15:07:08:000]: Product Code from property table after transforms: '{55D13F49-FCB8-4892-8266-05D373FCAA61}'
MSI (s) (50:68) [15:07:08:000]: Product not registered: beginning first-time install
MSI (s) (50:68) [15:07:08:000]: Product {55D13F49-FCB8-4892-8266-05D373FCAA61} is not managed.
MSI (s) (50:68) [15:07:08:000]: MSI_LUA: Credential prompt not required, user is an admin
MSI (s) (50:68) [15:07:08:000]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
MSI (s) (50:68) [15:07:08:000]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI (s) (50:68) [15:07:08:000]: User policy value 'SearchOrder' is 'nmu'
MSI (s) (50:68) [15:07:08:000]: Adding new sources is allowed.
MSI (s) (50:68) [15:07:08:000]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
MSI (s) (50:68) [15:07:08:000]: Package name extracted from package path: 'MicrosoftFixit50381.msi'
MSI (s) (50:68) [15:07:08:000]: Package to be registered: 'MicrosoftFixit50381.msi'
MSI (s) (50:68) [15:07:08:000]: Note: 1: 2262 2: Error 3: -2147287038
MSI (s) (50:68) [15:07:08:000]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI (s) (50:68) [15:07:08:000]: Machine policy value 'DisableMsi' is 0
MSI (s) (50:68) [15:07:08:000]: Machine policy value 'AlwaysInstallElevated' is 0
MSI (s) (50:68) [15:07:08:000]: User policy value 'AlwaysInstallElevated' is 0
MSI (s) (50:68) [15:07:08:000]: Running product '{55D13F49-FCB8-4892-8266-05D373FCAA61}' with user privileges: It's not assigned.
MSI (s) (50:68) [15:07:08:000]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'C:\Program Files (x86)\Microsoft\Microsoft Fix it 50381\'.
MSI (s) (50:68) [15:07:08:000]: PROPERTY CHANGE: Adding EULAACCEPTED property. Its value is '1'.
MSI (s) (50:68) [15:07:08:000]: PROPERTY CHANGE: Adding CURRENTDIRECTORY property. Its value is 'C:\Users\j\Desktop'.
MSI (s) (50:68) [15:07:08:000]: PROPERTY CHANGE: Adding CLIENTUILEVEL property. Its value is '0'.
MSI (s) (50:68) [15:07:08:000]: PROPERTY CHANGE: Adding CLIENTPROCESSID property. Its value is '1968'.
MSI (s) (50:68) [15:07:08:000]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'j'.
MSI (s) (50:68) [15:07:08:000]: PROPERTY CHANGE: Adding SOURCEDIR property. Its value is 'C:\Users\j\Desktop\'.
MSI (s) (50:68) [15:07:08:000]: PROPERTY CHANGE: Adding ACTION property. Its value is 'INSTALL'.
MSI (s) (50:68) [15:07:08:000]: PROPERTY CHANGE: Adding EXECUTEACTION property. Its value is 'INSTALL'.
MSI (s) (50:68) [15:07:08:000]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'C:\'.
MSI (s) (50:68) [15:07:08:000]: PROPERTY CHANGE: Adding INSTALLLEVEL property. Its value is '1'.
MSI (s) (50:68) [15:07:08:000]: PROPERTY CHANGE: Adding SECONDSEQUENCE property. Its value is '1'.
MSI (s) (50:68) [15:07:08:000]: PROPERTY CHANGE: Adding ADDLOCAL property. Its value is 'DefaultFeature'.
MSI (s) (50:68) [15:07:08:000]: Machine policy value 'DisableAutomaticApplicationShutdown' is 0
MSI (s) (50:68) [15:07:08:000]: PROPERTY CHANGE: Adding MsiRestartManagerSessionKey property. Its value is '6bcbf50d546d1d47bc7d73cc7a682962'.
MSI (s) (50:68) [15:07:08:000]: RESTART MANAGER: Session opened.
MSI (s) (50:68) [15:07:08:000]: Engine has iefSecondSequence set to true.
MSI (s) (50:68) [15:07:08:000]: TRANSFORMS property is now:
MSI (s) (50:68) [15:07:08:000]: PROPERTY CHANGE: Deleting SOURCEDIR property. Its current value is 'C:\Users\j\Desktop\'.
MSI (s) (50:68) [15:07:08:000]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
MSI (s) (50:68) [15:07:08:000]: SHELL32::SHGetFolderPath returned: C:\Users\j\AppData\Roaming
MSI (s) (50:68) [15:07:08:000]: SHELL32::SHGetFolderPath returned: C:\Users\j\Favorites
MSI (s) (50:68) [15:07:08:000]: SHELL32::SHGetFolderPath returned: C:\Users\j\AppData\Roaming\Microsoft\Windows\Network Shortcuts
MSI (s) (50:68) [15:07:08:000]: SHELL32::SHGetFolderPath returned: C:\Users\j\Contacts\Documents\Documents
MSI (s) (50:68) [15:07:08:000]: SHELL32::SHGetFolderPath returned: C:\Users\j\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
MSI (s) (50:68) [15:07:08:016]: SHELL32::SHGetFolderPath returned: C:\Users\j\AppData\Roaming\Microsoft\Windows\Recent
MSI (s) (50:68) [15:07:08:016]: SHELL32::SHGetFolderPath returned: C:\Users\j\AppData\Roaming\Microsoft\Windows\SendTo
MSI (s) (50:68) [15:07:08:016]: SHELL32::SHGetFolderPath returned: C:\Users\j\AppData\Roaming\Microsoft\Windows\Templates
MSI (s) (50:68) [15:07:08:016]: SHELL32::SHGetFolderPath returned: C:\ProgramData
MSI (s) (50:68) [15:07:08:016]: SHELL32::SHGetFolderPath returned: C:\Users\j\AppData\Local
MSI (s) (50:68) [15:07:08:016]: SHELL32::SHGetFolderPath returned: C:\Users\j\Pictures
MSI (s) (50:68) [15:07:08:016]: SHELL32::SHGetFolderPath returned: C:\Users\j\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI (s) (50:68) [15:07:08:016]: SHELL32::SHGetFolderPath returned: C:\Users\j\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
MSI (s) (50:68) [15:07:08:016]: SHELL32::SHGetFolderPath returned: C:\Users\j\Desktop
MSI (s) (50:68) [15:07:08:016]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI (s) (50:68) [15:07:08:016]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
MSI (s) (50:68) [15:07:08:016]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
MSI (s) (50:68) [15:07:08:016]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts
MSI (s) (50:68) [15:07:08:016]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
MSI (s) (50:68) [15:07:08:016]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
MSI (s) (50:68) [15:07:08:016]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
MSI (s) (50:68) [15:07:08:016]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
MSI (s) (50:68) [15:07:08:016]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI (s) (50:68) [15:07:08:016]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Windows\Installer\142aa4.msi'.
MSI (s) (50:68) [15:07:08:016]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Users\j\Desktop\MicrosoftFixit50381.msi'.
MSI (s) (50:68) [15:07:08:016]: Machine policy value 'MsiDisableEmbeddedUI' is 0
MSI (s) (50:68) [15:07:08:016]: EEUI - Disabling MsiEmbeddedUI for service because it's not a quiet/basic install
MSI (s) (50:68) [15:07:08:016]: Note: 1: 2262 2: PatchPackage 3: -2147287038
MSI (s) (50:68) [15:07:08:016]: Machine policy value 'DisableRollback' is 0
MSI (s) (50:68) [15:07:08:016]: User policy value 'DisableRollback' is 0
MSI (s) (50:68) [15:07:08:016]: PROPERTY CHANGE: Adding UILevel property. Its value is '5'.
MSI (s) (50:68) [15:07:08:016]: Note: 1: 2262 2: Font 3: -2147287038
MSI (s) (50:68) [15:07:08:016]: PROPERTY CHANGE: Adding Preselected property. Its value is '1'.
MSI (s) (50:68) [15:07:08:016]: Doing action: INSTALL
Action 15:07:08: INSTALL.
Action start 15:07:08: INSTALL.
MSI (s) (50:68) [15:07:08:031]: Running ExecuteSequence
MSI (s) (50:68) [15:07:08:031]: Doing action: Milestone_AppSearch122
Action 15:07:08: Milestone_AppSearch122.
Action start 15:07:08: Milestone_AppSearch122.
MSI (s) (50:68) [15:07:08:031]: Note: 1: 2235 2: 3: ExtendedType 4: SELECT `Action`,`Type`,`Source`,`Target`, NULL, `ExtendedType` FROM `CustomAction` WHERE `Action` = 'Milestone_AppSearch122'
MSI (s) (50:68) [15:07:08:031]: PROPERTY CHANGE: Adding Milestone property. Its value is 'AppSearch'.
Action ended 15:07:08: Milestone_AppSearch122. Return value 1.
MSI (s) (50:68) [15:07:08:031]: Doing action: AppSearch
Action 15:07:08: AppSearch. {\FinalUIFont}[PROGRESS_RESTORE_TXT]
Action start 15:07:08: AppSearch.
MSI (s) (50:68) [15:07:08:031]: Skipping AppSearch action: already done on client side
Action ended 15:07:08: AppSearch. Return value 0.
MSI (s) (50:68) [15:07:08:031]: Doing action: FindRelatedProducts
Action 15:07:08: FindRelatedProducts. {\FinalUIFont}[PROGRESS_RESTORE_TXT]
Action start 15:07:08: FindRelatedProducts.
MSI (s) (50:68) [15:07:08:031]: Skipping FindRelatedProducts action: already done on client side
Action ended 15:07:08: FindRelatedProducts. Return value 0.
MSI (s) (50:68) [15:07:08:031]: Doing action: Milestone_LaunchCond24
Action 15:07:08: Milestone_LaunchCond24.
Action start 15:07:08: Milestone_LaunchCond24.
MSI (s) (50:68) [15:07:08:031]: Note: 1: 2235 2: 3: ExtendedType 4: SELECT `Action`,`Type`,`Source`,`Target`, NULL, `ExtendedType` FROM `CustomAction` WHERE `Action` = 'Milestone_LaunchCond24'
MSI (s) (50:68) [15:07:08:031]: PROPERTY CHANGE: Modifying Milestone property. Its current value is 'AppSearch'. Its new value: 'LaunchConditions'.
Action ended 15:07:08: Milestone_LaunchCond24. Return value 1.
MSI (s) (50:68) [15:07:08:031]: Doing action: LaunchConditions
Action 15:07:08: LaunchConditions. {\FinalUIFont}[PROGRESS_RESTORE_TXT]
Action start 15:07:08: LaunchConditions.
Action ended 15:07:08: LaunchConditions. Return value 1.
MSI (s) (50:68) [15:07:08:031]: Doing action: CCPSearch
Action 15:07:08: CCPSearch. {\FinalUIFont}[PROGRESS_RESTORE_TXT]
Action start 15:07:08: CCPSearch.
MSI (s) (50:68) [15:07:08:031]: Skipping CCPSearch action: already done on client side
Action ended 15:07:08: CCPSearch. Return value 0.
MSI (s) (50:68) [15:07:08:031]: Doing action: RMCCPSearch
Action 15:07:08: RMCCPSearch. {\FinalUIFont}[PROGRESS_RESTORE_TXT]
Action start 15:07:08: RMCCPSearch.
MSI (s) (50:68) [15:07:08:031]: Skipping RMCCPSearch action: already done on client side
Action ended 15:07:08: RMCCPSearch. Return value 0.
MSI (s) (50:68) [15:07:08:031]: Doing action: ValidateProductID
Action 15:07:08: ValidateProductID. {\FinalUIFont}[PROGRESS_RESTORE_TXT]
Action start 15:07:08: ValidateProductID.
Action ended 15:07:08: ValidateProductID. Return value 1.
MSI (s) (50:68) [15:07:08:031]: Doing action: Milestone_DIRCA_TARG29
Action 15:07:08: Milestone_DIRCA_TARG29.
Action start 15:07:08: Milestone_DIRCA_TARG29.
MSI (s) (50:68) [15:07:08:031]: Note: 1: 2235 2: 3: ExtendedType 4: SELECT `Action`,`Type`,`Source`,`Target`, NULL, `ExtendedType` FROM `CustomAction` WHERE `Action` = 'Milestone_DIRCA_TARG29'
MSI (s) (50:68) [15:07:08:031]: PROPERTY CHANGE: Modifying Milestone property. Its current value is 'LaunchConditions'. Its new value: 'DIRCA_TARGETDIR'.
Action ended 15:07:08: Milestone_DIRCA_TARG29. Return value 1.
MSI (s) (50:68) [15:07:08:031]: Skipping action: DIRCA_TARGETDIR (condition is false)
MSI (s) (50:68) [15:07:08:031]: Doing action: CostInitialize
Action 15:07:08: CostInitialize. {\FinalUIFont}[PROGRESS_RESTORE_TXT]
Action start 15:07:08: CostInitialize.
MSI (s) (50:68) [15:07:08:031]: Machine policy value 'MaxPatchCacheSize' is 10
MSI (s) (50:68) [15:07:08:031]: Baseline: Sorting baselines for {55D13F49-FCB8-4892-8266-05D373FCAA61}.
MSI (s) (50:68) [15:07:08:031]: Baseline: New baseline 2.1.3 from transaction.
MSI (s) (50:68) [15:07:08:031]: Baseline: Sorted order Native: Order 0.
MSI (s) (50:68) [15:07:08:031]: Baseline Data Table:
MSI (s) (50:68) [15:07:08:031]: ProductCode: {55D13F49-FCB8-4892-8266-05D373FCAA61} Version: 2.1.3 Attributes: 0 PatchId: Native BaselineId: -2147483648 Order: 0
MSI (s) (50:68) [15:07:08:031]: Baseline File Table:
MSI (s) (50:68) [15:07:08:031]: PROPERTY CHANGE: Adding CostingComplete property. Its value is '0'.
MSI (s) (50:68) [15:07:08:031]: Note: 1: 2262 2: Patch 3: -2147287038
MSI (s) (50:68) [15:07:08:031]: Note: 1: 2262 2: PatchPackage 3: -2147287038
MSI (s) (50:68) [15:07:08:031]: Note: 1: 2262 2: MsiPatchHeaders 3: -2147287038
MSI (s) (50:68) [15:07:08:031]: Note: 1: 2205 2: 3: __MsiPatchFileList
MSI (s) (50:68) [15:07:08:031]: Dumping __MsiPatchMedia table...
MSI (s) (50:68) [15:07:08:031]: Delta compression fallback method for this product transaction is 'MSI 2.0 legacy obsolescence'
Action ended 15:07:08: CostInitialize. Return value 1.
MSI (s) (50:68) [15:07:08:031]: Doing action: FileCost
Action 15:07:08: FileCost. {\FinalUIFont}[PROGRESS_RESTORE_TXT]
Action start 15:07:08: FileCost.
MSI (s) (50:68) [15:07:08:031]: Note: 1: 2262 2: MsiAssembly 3: -2147287038
MSI (s) (50:68) [15:07:08:031]: Note: 1: 2262 2: RemoveFile 3: -2147287038
MSI (s) (50:68) [15:07:08:031]: Note: 1: 2262 2: MoveFile 3: -2147287038
MSI (s) (50:68) [15:07:08:031]: Note: 1: 2262 2: DuplicateFile 3: -2147287038
MSI (s) (50:68) [15:07:08:031]: Note: 1: 2262 2: Shortcut 3: -2147287038
MSI (s) (50:68) [15:07:08:031]: Note: 1: 2262 2: Class 3: -2147287038
MSI (s) (50:68) [15:07:08:031]: Note: 1: 2262 2: Extension 3: -2147287038
MSI (s) (50:68) [15:07:08:031]: Note: 1: 2262 2: TypeLib 3: -2147287038
MSI (s) (50:68) [15:07:08:031]: Note: 1: 2262 2: IniFile 3: -2147287038
MSI (s) (50:68) [15:07:08:031]: Note: 1: 2262 2: ReserveCost 3: -2147287038
Action ended 15:07:08: FileCost. Return value 1.
MSI (s) (50:68) [15:07:08:031]: Doing action: IsolateComponents
Action 15:07:08: IsolateComponents. {\FinalUIFont}[PROGRESS_RESTORE_TXT]
Action start 15:07:08: IsolateComponents.
MSI (s) (50:68) [15:07:08:031]: Note: 1: 2262 2: BindImage 3: -2147287038
MSI (s) (50:68) [15:07:08:031]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038
Action ended 15:07:08: IsolateComponents. Return value 1.
MSI (s) (50:68) [15:07:08:031]: Doing action: CostFinalize
Action 15:07:08: CostFinalize. {\FinalUIFont}[PROGRESS_RESTORE_TXT]
Action start 15:07:08: CostFinalize.
MSI (s) (50:68) [15:07:08:031]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is '0'.
MSI (s) (50:68) [15:07:08:031]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is '0'.
MSI (s) (50:68) [15:07:08:031]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is '0'.
MSI (s) (50:68) [15:07:08:031]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is '0'.
MSI (s) (50:68) [15:07:08:031]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is '0'.
MSI (s) (50:68) [15:07:08:031]: Note: 1: 2262 2: Condition 3: -2147287038
MSI (s) (50:68) [15:07:08:031]: Target path resolution complete. Dumping Directory table...
MSI (s) (50:68) [15:07:08:031]: Note: target paths subject to change (via custom actions or browsing)
MSI (s) (50:68) [15:07:08:031]: Dir (target): Key: TARGETDIR , Object: C:\Program Files (x86)\Microsoft\Microsoft Fix it 50381\
MSI (s) (50:68) [15:07:08:031]: Dir (target): Key: WindowsFolder , Object: C:\Windows\
MSI (s) (50:68) [15:07:08:031]: Dir (target): Key: ProgramMenuFolder , Object: C:\Users\j\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\
MSI (s) (50:68) [15:07:08:031]: Dir (target): Key: DesktopFolder , Object: C:\Users\j\Desktop\
Action ended 15:07:08: CostFinalize. Return value 1.
MSI (s) (50:68) [15:07:08:031]: Doing action: SetODBCFolders
Action 15:07:08: SetODBCFolders. {\FinalUIFont}[PROGRESS_RESTORE_TXT]
Action start 15:07:08: SetODBCFolders.
MSI (s) (50:68) [15:07:08:031]: Note: 1: 2262 2: ODBCDriver 3: -2147287038
MSI (s) (50:68) [15:07:08:031]: Note: 1: 2262 2: ODBCTranslator 3: -2147287038
Action ended 15:07:08: SetODBCFolders. Return value 1.
MSI (s) (50:68) [15:07:08:047]: Doing action: InstallValidate
Action 15:07:08: InstallValidate. {\FinalUIFont}[PROGRESS_RESTORE_TXT]
Action start 15:07:08: InstallValidate.
MSI (s) (50:68) [15:07:08:047]: PROPERTY CHANGE: Deleting MsiRestartManagerSessionKey property. Its current value is '6bcbf50d546d1d47bc7d73cc7a682962'.
MSI (s) (50:68) [15:07:08:047]: Feature: DefaultFeature; Installed: Absent; Request: Local; Action: Local
MSI (s) (50:68) [15:07:08:047]: Component: C_DefaultComponent; Installed: Absent; Request: Local; Action: Null; Client State: Unknown
MSI (s) (50:68) [15:07:08:047]: Component: C_ADDKEY1; Installed: Null; Request: Local; Action: Local; Client State: Null
MSI (s) (50:68) [15:07:08:047]: Component: C_K64_ADDKEY1; Installed: Null; Request: Local; Action: Local; Client State: Null
MSI (s) (50:68) [15:07:08:047]: Component: __C_ADDKEY165; Installed: Null; Request: Local; Action: Local; Client State: Null
MSI (s) (50:68) [15:07:08:047]: Component: __C_K64_ADDKEY165; Installed: Null; Request: Local; Action: Local; Client State: Null
MSI (s) (50:68) [15:07:08:047]: Note: 1: 2262 2: BindImage 3: -2147287038
MSI (s) (50:68) [15:07:08:047]: Note: 1: 2262 2: ProgId 3: -2147287038
MSI (s) (50:68) [15:07:08:047]: Note: 1: 2262 2: PublishComponent 3: -2147287038
MSI (s) (50:68) [15:07:08:047]: Note: 1: 2262 2: SelfReg 3: -2147287038
MSI (s) (50:68) [15:07:08:047]: Note: 1: 2262 2: Extension 3: -2147287038
MSI (s) (50:68) [15:07:08:047]: Note: 1: 2262 2: Font 3: -2147287038
MSI (s) (50:68) [15:07:08:047]: Note: 1: 2262 2: Class 3: -2147287038
MSI (s) (50:68) [15:07:08:047]: Note: 1: 2262 2: Icon 3: -2147287038
MSI (s) (50:68) [15:07:08:047]: Note: 1: 2262 2: TypeLib 3: -2147287038
MSI (s) (50:68) [15:07:08:047]: Note: 1: 2262 2: RemoveFile 3: -2147287038
MSI (s) (50:68) [15:07:08:047]: Note: 1: 2262 2: DuplicateFile 3: -2147287038
MSI (s) (50:68) [15:07:08:047]: Note: 1: 2262 2: ReserveCost 3: -2147287038
MSI (s) (50:68) [15:07:08:047]: PROPERTY CHANGE: Modifying CostingComplete property. Its current value is '0'. Its new value: '1'.
MSI (s) (50:68) [15:07:08:047]: Note: 1: 2727 2:
MSI (s) (50:68) [15:07:08:047]: Note: 1: 2205 2: 3: FilesInUse
Action ended 15:07:08: InstallValidate. Return value 1.
MSI (s) (50:68) [15:07:08:047]: Doing action: InstallInitialize
Action 15:07:08: InstallInitialize. {\FinalUIFont}[PROGRESS_PROCESSED_TXT]
Action start 15:07:08: InstallInitialize.
MSI (s) (50:68) [15:07:08:047]: Machine policy value 'AlwaysInstallElevated' is 0
MSI (s) (50:68) [15:07:08:047]: User policy value 'AlwaysInstallElevated' is 0
MSI (s) (50:68) [15:07:08:047]: BeginTransaction: Locking Server
MSI (s) (50:68) [15:07:08:047]: Server not locked: locking for product {55D13F49-FCB8-4892-8266-05D373FCAA61}
Action ended 15:07:09: InstallInitialize. Return value 1.
MSI (s) (50:68) [15:07:09:685]: Doing action: AllocateRegistrySpace
Action 15:07:09: AllocateRegistrySpace. {\FinalUIFont}[PROGRESS_PROCESSED_TXT]
Action start 15:07:09: AllocateRegistrySpace.
Action ended 15:07:09: AllocateRegistrySpace. Return value 1.
MSI (s) (50:68) [15:07:09:701]: Doing action: ProcessComponents
Action 15:07:09: ProcessComponents. {\FinalUIFont}[PROGRESS_PROCESSED_TXT]
Action start 15:07:09: ProcessComponents.
MSI (s) (50:68) [15:07:09:701]: Note: 1: 2205 2: 3: MsiPatchCertificate
MSI (s) (50:68) [15:07:09:701]: LUA patching is disabled: missing MsiPatchCertificate table
MSI (s) (50:68) [15:07:09:701]: Resolving source.
MSI (s) (50:68) [15:07:09:701]: Resolving source to launched-from source.
MSI (s) (50:68) [15:07:09:701]: Setting launched-from source as last-used.
MSI (s) (50:68) [15:07:09:701]: PROPERTY CHANGE: Adding SourceDir property. Its value is 'C:\Users\j\Desktop\'.
MSI (s) (50:68) [15:07:09:701]: PROPERTY CHANGE: Adding SOURCEDIR property. Its value is 'C:\Users\j\Desktop\'.
MSI (s) (50:68) [15:07:09:701]: PROPERTY CHANGE: Adding SourcedirProduct property. Its value is '{55D13F49-FCB8-4892-8266-05D373FCAA61}'.
MSI (s) (50:68) [15:07:09:701]: SOURCEDIR ==> C:\Users\j\Desktop\
MSI (s) (50:68) [15:07:09:701]: SOURCEDIR product ==> {55D13F49-FCB8-4892-8266-05D373FCAA61}
MSI (s) (50:68) [15:07:09:701]: Determining source type
MSI (s) (50:68) [15:07:09:701]: Source type from package 'MicrosoftFixit50381.msi': 2
MSI (s) (50:68) [15:07:09:701]: Source path resolution complete. Dumping Directory table...
MSI (s) (50:68) [15:07:09:701]: Dir (source): Key: TARGETDIR , Object: C:\Users\j\Desktop\ , LongSubPath: , ShortSubPath:
MSI (s) (50:68) [15:07:09:701]: Dir (source): Key: WindowsFolder , Object: C:\Users\j\Desktop\ , LongSubPath: , ShortSubPath:
MSI (s) (50:68) [15:07:09:701]: Dir (source): Key: ProgramMenuFolder , Object: C:\Users\j\Desktop\ , LongSubPath: User's Programs Menu\ , ShortSubPath: USER'S~2\
MSI (s) (50:68) [15:07:09:701]: Dir (source): Key: DesktopFolder , Object: C:\Users\j\Desktop\ , LongSubPath: User's Desktop\ , ShortSubPath: USER'S~1\
Action 15:07:09: GenerateScript. Generating script operations for action:
GenerateScript: {\FinalUIFont}[PROGRESS_PROCESSED_TXT]
Action ended 15:07:09: ProcessComponents. Return value 1.
MSI (s) (50:68) [15:07:09:701]: Doing action: MsiUnpublishAssemblies
Action 15:07:09: MsiUnpublishAssemblies. {\FinalUIFont}[PROGRESS_PROCESSED_TXT]
Action start 15:07:09: MsiUnpublishAssemblies.
Action ended 15:07:09: MsiUnpublishAssemblies. Return value 1.
MSI (s) (50:68) [15:07:09:701]: Doing action: UnpublishComponents
Action 15:07:09: UnpublishComponents. {\FinalUIFont}[PROGRESS_PROCESSED_TXT]
Action start 15:07:09: UnpublishComponents.
MSI (s) (50:68) [15:07:09:701]: Note: 1: 2262 2: PublishComponent 3: -2147287038
Action ended 15:07:09: UnpublishComponents. Return value 1.
MSI (s) (50:68) [15:07:09:701]: Doing action: UnpublishFeatures
Action 15:07:09: UnpublishFeatures. {\FinalUIFont}[PROGRESS_PROCESSED_TXT]
Action start 15:07:09: UnpublishFeatures.
Action ended 15:07:09: UnpublishFeatures. Return value 1.
MSI (s) (50:68) [15:07:09:701]: Doing action: StopServices
Action 15:07:09: StopServices. {\FinalUIFont}[PROGRESS_PROCESSED_TXT]
Action start 15:07:09: StopServices.
MSI (s) (50:68) [15:07:09:701]: Note: 1: 2262 2: ServiceControl 3: -2147287038
Action ended 15:07:09: StopServices. Return value 1.
MSI (s) (50:68) [15:07:09:701]: Doing action: DeleteServices
Action 15:07:09: DeleteServices. {\FinalUIFont}[PROGRESS_PROCESSED_TXT]
Action start 15:07:09: DeleteServices.
Action ended 15:07:09: DeleteServices. Return value 1.
MSI (s) (50:68) [15:07:09:701]: Doing action: UnregisterComPlus
Action 15:07:09: UnregisterComPlus. {\FinalUIFont}[PROGRESS_PROCESSED_TXT]
Action start 15:07:09: UnregisterComPlus.
MSI (s) (50:68) [15:07:09:701]: Note: 1: 2262 2: Complus 3: -2147287038
Action ended 15:07:09: UnregisterComPlus. Return value 1.
MSI (s) (50:68) [15:07:09:701]: Doing action: SelfUnregModules
Action 15:07:09: SelfUnregModules. {\FinalUIFont}[PROGRESS_PROCESSED_TXT]
Action start 15:07:09: SelfUnregModules.
MSI (s) (50:68) [15:07:09:701]: Note: 1: 2262 2: SelfReg 3: -2147287038
Action ended 15:07:09: SelfUnregModules. Return value 1.
MSI (s) (50:68) [15:07:09:701]: Doing action: UnregisterTypeLibraries
Action 15:07:09: UnregisterTypeLibraries. {\FinalUIFont}[PROGRESS_PROCESSED_TXT]
Action start 15:07:09: UnregisterTypeLibraries.
Action ended 15:07:09: UnregisterTypeLibraries. Return value 1.
MSI (s) (50:68) [15:07:09:716]: Doing action: RemoveODBC
Action 15:07:09: RemoveODBC. {\FinalUIFont}[PROGRESS_PROCESSED_TXT]
Action start 15:07:09: RemoveODBC.
MSI (s) (50:68) [15:07:09:716]: Note: 1: 2262 2: ODBCDataSource 3: -2147287038
MSI (s) (50:68) [15:07:09:716]: Note: 1: 2262 2: ODBCTranslator 3: -2147287038
MSI (s) (50:68) [15:07:09:716]: Note: 1: 2262 2: ODBCDriver 3: -2147287038
MSI (s) (50:68) [15:07:09:716]: Note: 1: 2711 2: ODBCDriverManager
1: {\FinalUIFont}[PROGRESS_PROCESSED_TXT]
MSI (s) (50:68) [15:07:09:716]: Note: 1: 2711 2: ODBCDriverManager64
Action ended 15:07:09: RemoveODBC. Return value 1.
MSI (s) (50:68) [15:07:09:716]: Doing action: UnregisterFonts
Action 15:07:09: UnregisterFonts. {\FinalUIFont}[PROGRESS_PROCESSED_TXT]
Action start 15:07:09: UnregisterFonts.
MSI (s) (50:68) [15:07:09:716]: Note: 1: 2262 2: Font 3: -2147287038
Action ended 15:07:09: UnregisterFonts. Return value 1.
MSI (s) (50:68) [15:07:09:716]: Doing action: RemoveRegistryValues
Action 15:07:09: RemoveRegistryValues. {\FinalUIFont}[PROGRESS_PROCESSED_TXT]
Action start 15:07:09: RemoveRegistryValues.
MSI (s) (50:68) [15:07:09:716]: Note: 1: 2262 2: RemoveRegistry 3: -2147287038
Action ended 15:07:09: RemoveRegistryValues. Return value 1.
MSI (s) (50:68) [15:07:09:716]: Doing action: UnregisterClassInfo
Action 15:07:09: UnregisterClassInfo. {\FinalUIFont}[PROGRESS_PROCESSED_TXT]
Action start 15:07:09: UnregisterClassInfo.
MSI (s) (50:68) [15:07:09:716]: Note: 1: 2262 2: Class 3: -2147287038
Action ended 15:07:09: UnregisterClassInfo. Return value 1.
MSI (s) (50:68) [15:07:09:716]: Doing action: UnregisterExtensionInfo
Action 15:07:09: UnregisterExtensionInfo. {\FinalUIFont}[PROGRESS_PROCESSED_TXT]
Action start 15:07:09: UnregisterExtensionInfo.
MSI (s) (50:68) [15:07:09:716]: Note: 1: 2262 2: Extension 3: -2147287038
Action ended 15:07:09: UnregisterExtensionInfo. Return value 1.
MSI (s) (50:68) [15:07:09:716]: Doing action: UnregisterProgIdInfo
Action 15:07:09: UnregisterProgIdInfo. {\FinalUIFont}[PROGRESS_PROCESSED_TXT]
Action start 15:07:09: UnregisterProgIdInfo.
MSI (s) (50:68) [15:07:09:716]: Note: 1: 2262 2: ProgId 3: -2147287038
Action ended 15:07:09: UnregisterProgIdInfo. Return value 1.
MSI (s) (50:68) [15:07:09:716]: Doing action: UnregisterMIMEInfo
Action 15:07:09: UnregisterMIMEInfo. {\FinalUIFont}[PROGRESS_PROCESSED_TXT]
Action start 15:07:09: UnregisterMIMEInfo.
MSI (s) (50:68) [15:07:09:716]: Note: 1: 2262 2: MIME 3: -2147287038
Action ended 15:07:09: UnregisterMIMEInfo. Return value 1.
MSI (s) (50:68) [15:07:09:716]: Doing action: RemoveIniValues
Action 15:07:09: RemoveIniValues. {\FinalUIFont}[PROGRESS_PROCESSED_TXT]
Action start 15:07:09: RemoveIniValues.
MSI (s) (50:68) [15:07:09:716]: Note: 1: 2262 2: RemoveIniFile 3: -2147287038
Action ended 15:07:09: RemoveIniValues. Return value 1.
MSI (s) (50:68) [15:07:09:716]: Doing action: RemoveShortcuts
Action 15:07:09: RemoveShortcuts. {\FinalUIFont}[PROGRESS_PROCESSED_TXT]
Action start 15:07:09: RemoveShortcuts.
Action ended 15:07:09: RemoveShortcuts. Return value 1.
MSI (s) (50:68) [15:07:09:732]: Doing action: RemoveEnvironmentStrings
Action 15:07:09: RemoveEnvironmentStrings. {\FinalUIFont}[PROGRESS_PROCESSED_TXT]
Action start 15:07:09: RemoveEnvironmentStrings.
MSI (s) (50:68) [15:07:09:732]: Note: 1: 2262 2: Environment 3: -2147287038
Action ended 15:07:09: RemoveEnvironmentStrings. Return value 1.
MSI (s) (50:68) [15:07:09:732]: Doing action: RemoveDuplicateFiles
Action 15:07:09: RemoveDuplicateFiles. {\FinalUIFont}[PROGRESS_PROCESSED_TXT]
Action start 15:07:09: RemoveDuplicateFiles.
Action ended 15:07:09: RemoveDuplicateFiles. Return value 1.
MSI (s) (50:68) [15:07:09:732]: Doing action: RemoveFiles
Action 15:07:09: RemoveFiles. {\FinalUIFont}[PROGRESS_PROCESSED_TXT]
Action start 15:07:09: RemoveFiles.
Action ended 15:07:09: RemoveFiles. Return value 1.
MSI (s) (50:68) [15:07:09:732]: Doing action: RemoveFolders
Action 15:07:09: RemoveFolders. {\FinalUIFont}[PROGRESS_PROCESSED_TXT]
Action start 15:07:09: RemoveFolders.
MSI (s) (50:68) [15:07:09:732]: Note: 1: 2262 2: CreateFolder 3: -2147287038
MSI (s) (50:68) [15:07:09:732]: Note: 1: 2262 2: LockPermissions 3: -2147287038
Action ended 15:07:09: RemoveFolders. Return value 1.
MSI (s) (50:68) [15:07:09:732]: Doing action: CreateFolders
Action 15:07:09: CreateFolders. {\FinalUIFont}[PROGRESS_PROCESSED_TXT]
Action start 15:07:09: CreateFolders.
Action ended 15:07:09: CreateFolders. Return value 1.
MSI (s) (50:68) [15:07:09:732]: Doing action: MoveFiles
Action 15:07:09: MoveFiles. {\FinalUIFont}[PROGRESS_PROCESSED_TXT]
Action start 15:07:09: MoveFiles.
Action ended 15:07:09: MoveFiles. Return value 1.
MSI (s) (50:68) [15:07:09:732]: Doing action: InstallFiles
Action 15:07:09: InstallFiles. {\FinalUIFont}[PROGRESS_PROCESSED_TXT]
Action start 15:07:09: InstallFiles.
MSI (s) (50:68) [15:07:09:732]: Dumping binary patch manager data...
MSI (s) (50:68) [15:07:09:732]: Note: 1: 2205 2: 3: MsiPatchOldAssemblyFile
MSI (s) (50:68) [15:07:09:732]: Note: 1: 2228 2: 3: MsiPatchOldAssemblyFile 4: SELECT `MsiPatchOldAssemblyFile`.`Assembly_` FROM `MsiPatchOldAssemblyFile` WHERE `MsiPatchOldAssemblyFile`.`File_` = ?
MSI (s) (50:68) [15:07:09:732]: Note: 1: 2262 2: Error 3: -2147287038
MSI (s) (50:68) [15:07:09:732]: Note: 1: 2205 2: 3: MsiSFCBypass
MSI (s) (50:68) [15:07:09:732]: Note: 1: 2228 2: 3: MsiSFCBypass 4: SELECT `File_` FROM `MsiSFCBypass` WHERE `File_` = ?
Action ended 15:07:09: InstallFiles. Return value 1.
MSI (s) (50:68) [15:07:09:732]: Doing action: PatchFiles
Action 15:07:09: PatchFiles. {\FinalUIFont}[PROGRESS_PROCESSED_TXT]
Action start 15:07:09: PatchFiles.
Action ended 15:07:09: PatchFiles. Return value 1.
MSI (s) (50:68) [15:07:09:732]: Doing action: DuplicateFiles
Action 15:07:09: DuplicateFiles. {\FinalUIFont}[PROGRESS_PROCESSED_TXT]
Action start 15:07:09: DuplicateFiles.
Action ended 15:07:09: DuplicateFiles. Return value 1.
MSI (s) (50:68) [15:07:09:732]: Doing action: BindImage
Action 15:07:09: BindImage. {\FinalUIFont}[PROGRESS_PROCESSED_TXT]
Action start 15:07:09: BindImage.
MSI (s) (50:68) [15:07:09:732]: Note: 1: 2262 2: BindImage 3: -2147287038
Action ended 15:07:09: BindImage. Return value 1.
MSI (s) (50:68) [15:07:09:732]: Doing action: CreateShortcuts
Action 15:07:09: CreateShortcuts. {\FinalUIFont}[PROGRESS_PROCESSED_TXT]
Action start 15:07:09: CreateShortcuts.
MSI (s) (50:68) [15:07:09:732]: Note: 1: 2262 2: Icon 3: -2147287038
MSI (s) (50:68) [15:07:09:732]: Note: 1: 2235 2: 3: DisplayResourceDLL 4: SELECT `Shortcut`,`Name`, `FileName`, `Component`.`Directory_`, `Arguments`, `WkDir`, `Icon_`, `IconIndex`, `Hotkey`, `ShowCmd`, `Shortcut`.`Description`, `Shortcut`.`Directory_`, `Component`.`RuntimeFlags`, `Component`.`Action`, `Target`, `ComponentId`, `Feature`.`Action`, `Component`.`Installed`, `DisplayResourceDLL`, `DisplayResourceId`, `DescriptionResourceDLL`, `DescriptionResourceId` From `Shortcut`, `Feature`, `Component`, `File` WHERE `Target` = `Feature` AND `Shortcut`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2) OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)))
MSI (s) (50:68) [15:07:09:732]: Note: 1: 2205 2: 3: MsiShortcutProperty
MSI (s) (50:68) [15:07:09:732]: Note: 1: 2235 2: 3: DisplayResourceDLL 4: SELECT `Shortcut`,`Name`, `Target`, null, `Arguments`, `WkDir`, `Icon_`, `IconIndex`, `Hotkey`, `ShowCmd`, `Shortcut`.`Description`, `Shortcut`.`Directory_`, `Component`.`RuntimeFlags`, null, null, null, null, null, `DisplayResourceDLL`, `DisplayResourceId`, `DescriptionResourceDLL`, `DescriptionResourceId` From `Shortcut`, `Component` WHERE `Shortcut`.`Component_` = `Component` AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2)
Action ended 15:07:09: CreateShortcuts. Return value 1.
MSI (s) (50:68) [15:07:09:732]: Doing action: RegisterClassInfo
Action 15:07:09: RegisterClassInfo. {\FinalUIFont}[PROGRESS_PROCESSED_TXT]
Action start 15:07:09: RegisterClassInfo.
MSI (s) (50:68) [15:07:09:747]: Note: 1: 2262 2: Class 3: -2147287038
Action ended 15:07:09: RegisterClassInfo. Return value 1.
MSI (s) (50:68) [15:07:09:747]: Doing action: RegisterExtensionInfo
Action 15:07:09: RegisterExtensionInfo. {\FinalUIFont}[PROGRESS_PROCESSED_TXT]
Action start 15:07:09: RegisterExtensionInfo.
MSI (s) (50:68) [15:07:09:747]: Note: 1: 2262 2: Extension 3: -2147287038
Action ended 15:07:09: RegisterExtensionInfo. Return value 1.
MSI (s) (50:68) [15:07:09:747]: Doing action: RegisterProgIdInfo
Action 15:07:09: RegisterProgIdInfo. {\FinalUIFont}[PROGRESS_PROCESSED_TXT]
Action start 15:07:09: RegisterProgIdInfo.
MSI (s) (50:68) [15:07:09:747]: Note: 1: 2262 2: ProgId 3: -2147287038
Action ended 15:07:09: RegisterProgIdInfo. Return value 1.
MSI (s) (50:68) [15:07:09:747]: Doing action: RegisterMIMEInfo
Action 15:07:09: RegisterMIMEInfo. {\FinalUIFont}[PROGRESS_PROCESSED_TXT]
Action start 15:07:09: RegisterMIMEInfo.
MSI (s) (50:68) [15:07:09:747]: Note: 1: 2262 2: MIME 3: -2147287038
Action ended 15:07:09: RegisterMIMEInfo. Return value 1.
MSI (s) (50:68) [15:07:09:747]: Doing action: WriteRegistryValues
Action 15:07:09: WriteRegistryValues. {\FinalUIFont}[PROGRESS_PROCESSED_TXT]
Action start 15:07:09: WriteRegistryValues.
MSI (s) (50:68) [15:07:09:747]: Note: 1: 2262 2: LockPermissions 3: -2147287038
Action ended 15:07:09: WriteRegistryValues. Return value 1.
MSI (s) (50:68) [15:07:09:747]: Doing action: WriteIniValues
Action 15:07:09: WriteIniValues. {\FinalUIFont}[PROGRESS_PROCESSED_TXT]
Action start 15:07:09: WriteIniValues.
Action ended 15:07:09: WriteIniValues. Return value 1.
MSI (s) (50:68) [15:07:09:747]: Doing action: WriteEnvironmentStrings
Action 15:07:09: WriteEnvironmentStrings. {\FinalUIFont}[PROGRESS_PROCESSED_TXT]
Action start 15:07:09: WriteEnvironmentStrings.
MSI (s) (50:68) [15:07:09:747]: Note: 1: 2262 2: Environment 3: -2147287038
Action ended 15:07:09: WriteEnvironmentStrings. Return value 1.
MSI (s) (50:68) [15:07:09:747]: Doing action: RegisterFonts
Action 15:07:09: RegisterFonts. {\FinalUIFont}[PROGRESS_PROCESSED_TXT]
Action start 15:07:09: RegisterFonts.
MSI (s) (50:68) [15:07:09:747]: Note: 1: 2262 2: Font 3: -2147287038
Action ended 15:07:09: RegisterFonts. Return value 1.
MSI (s) (50:68) [15:07:09:747]: Doing action: InstallODBC
Action 15:07:09: InstallODBC. {\FinalUIFont}[PROGRESS_PROCESSED_TXT]
Action start 15:07:09: InstallODBC.
MSI (s) (50:68) [15:07:09:747]: Note: 1: 2711 2: ODBCDriverManager
MSI (s) (50:68) [15:07:09:747]: Note: 1: 2711 2: ODBCDriverManager64
MSI (s) (50:68) [15:07:09:747]: Note: 1: 2262 2: ODBCDriver 3: -2147287038
MSI (s) (50:68) [15:07:09:747]: Note: 1: 2262 2: ODBCAttribute 3: -2147287038
MSI (s) (50:68) [15:07:09:747]: Note: 1: 2262 2: ODBCTranslator 3: -2147287038
MSI (s) (50:68) [15:07:09:747]: Note: 1: 2262 2: ODBCDataSource 3: -2147287038
MSI (s) (50:68) [15:07:09:747]: Note: 1: 2262 2: ODBCSourceAttribute 3: -2147287038
Action ended 15:07:09: InstallODBC. Return value 0.
MSI (s) (50:68) [15:07:09:747]: Doing action: RegisterTypeLibraries
Action 15:07:09: RegisterTypeLibraries. {\FinalUIFont}[PROGRESS_PROCESSED_TXT]
Action start 15:07:09: RegisterTypeLibraries.
Action ended 15:07:09: RegisterTypeLibraries. Return value 1.
MSI (s) (50:68) [15:07:09:747]: Doing action: SelfRegModules
Action 15:07:09: SelfRegModules. {\FinalUIFont}[PROGRESS_PROCESSED_TXT]
Action start 15:07:09: SelfRegModules.
MSI (s) (50:68) [15:07:09:763]: Note: 1: 2262 2: SelfReg 3: -2147287038
Action ended 15:07:09: SelfRegModules. Return value 1.
MSI (s) (50:68) [15:07:09:763]: Doing action: RegisterComPlus
Action 15:07:09: RegisterComPlus. {\FinalUIFont}[PROGRESS_PROCESSED_TXT]
Action start 15:07:09: RegisterComPlus.
MSI (s) (50:68) [15:07:09:763]: Note: 1: 2262 2: Complus 3: -2147287038
Action ended 15:07:09: RegisterComPlus. Return value 1.
MSI (s) (50:68) [15:07:09:763]: Doing action: InstallServices
Action 15:07:09: InstallServices. {\FinalUIFont}[PROGRESS_PROCESSED_TXT]
Action start 15:07:09: InstallServices.
MSI (s) (50:68) [15:07:09:763]: Note: 1: 2262 2: LockPermissions 3: -2147287038
MSI (s) (50:68) [15:07:09:763]: Note: 1: 2262 2: ServiceInstall 3: -2147287038
Action ended 15:07:09: InstallServices. Return value 1.
MSI (s) (50:68) [15:07:09:763]: Doing action: StartServices
Action 15:07:09: StartServices. {\FinalUIFont}[PROGRESS_PROCESSED_TXT]
Action start 15:07:09: StartServices.
MSI (s) (50:68) [15:07:09:763]: Note: 1: 2262 2: ServiceControl 3: -2147287038
Action ended 15:07:09: StartServices. Return value 1.
MSI (s) (50:68) [15:07:09:763]: Doing action: PublishComponents
Action 15:07:09: PublishComponents. {\FinalUIFont}[PROGRESS_PROCESSED_TXT]
Action start 15:07:09: PublishComponents.
MSI (s) (50:68) [15:07:09:763]: Note: 1: 2262 2: PublishComponent 3: -2147287038
Action ended 15:07:09: PublishComponents. Return value 1.
MSI (s) (50:68) [15:07:09:763]: Doing action: MsiPublishAssemblies
Action 15:07:09: MsiPublishAssemblies. {\FinalUIFont}[PROGRESS_PROCESSED_TXT]
Action start 15:07:09: MsiPublishAssemblies.
Action ended 15:07:09: MsiPublishAssemblies. Return value 1.
MSI (s) (50:68) [15:07:09:763]: Doing action: InstallExecute
Action 15:07:09: InstallExecute. {\FinalUIFont}[PROGRESS_PROCESSED_TXT]
Action start 15:07:09: InstallExecute.
MSI (s) (50:68) [15:07:09:763]: Running Script: C:\Windows\Installer\MSIFC2.tmp
MSI (s) (50:68) [15:07:09:763]: PROPERTY CHANGE: Adding UpdateStarted property. Its value is '1'.
MSI (s) (50:68) [15:07:09:763]: Machine policy value 'DisableRollback' is 0
MSI (s) (50:68) [15:07:09:763]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installe r\Rollback\Scripts 3: 2
MSI (s) (50:68) [15:07:09:779]: Executing op: Header(Signature=1397708873,Version=500,Timestamp=1087207653,LangId=1 033,Platform=0,ScriptType=1,ScriptMajorVersion=21,ScriptMinorVersion=4 ,ScriptAttributes=0)
MSI (s) (50:68) [15:07:09:779]: Executing op: ProductInfo(ProductKey={55D13F49-FCB8-4892-8266-05D373FCAA61},Product Name=Microsoft Fix it 50381,PackageName=MicrosoftFixit50381.msi,Language=1033,Version=33619 971,Assignment=0,ObsoleteArg=0,,,PackageCode={1C7C3009-013E-4A16-9A0F- 0000FB80A613},,,InstanceType=0,LUASetting=0,RemoteURTInstalls=0,Produc tDeploymentFlags=3)
MSI (s) (50:68) [15:07:09:779]: SHELL32::SHGetFolderPath returned: C:\Users\j\AppData\Roaming
MSI (s) (50:68) [15:07:09:779]: Executing op: DialogInfo(Type=0,Argument=1033)
MSI (s) (50:68) [15:07:09:779]: Executing op: DialogInfo(Type=1,Argument=Microsoft Fix it 50381)
MSI (s) (50:68) [15:07:09:779]: Executing op: RollbackInfo(,RollbackAction=Rollback,RollbackDescription=Rolling back action:,RollbackTemplate=[1],CleanupAction=RollbackCleanup,CleanupDes cription=[ProgressUIHeaderText],)
MSI (s) (50:68) [15:07:09:779]: Executing op: SetBaseline(Baseline=0,)
MSI (s) (50:68) [15:07:09:779]: Executing op: SetBaseline(Baseline=1,)
MSI (s) (50:68) [15:07:09:779]: Executing op: ActionStart(Name=ProcessComponents,Description={\FinalUIFont}[PROGRES S_PROCESSED_TXT],)
Action 15:07:09: ProcessComponents. {\FinalUIFont}This Microsoft Fix it is being processed.
MSI (s) (50:68) [15:07:09:779]: Executing op: ProgressTotal(Total=1,Type=1,ByteEquivalent=24000)
MSI (s) (50:68) [15:07:09:779]: Executing op: ComponentRegister(ComponentId={4C231858-2B39-11D3-8E0D-00C04F6837D0}, ,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0)
1: {55D13F49-FCB8-4892-8266-05D373FCAA61} 2: {4C231858-2B39-11D3-8E0D-00C04F6837D0}
MSI (s) (50:68) [15:07:09:779]: Executing op: ActionStart(Name=RemoveODBC,Description={\FinalUIFont}[PROGRESS_PROCE SSED_TXT],)
Action 15:07:09: RemoveODBC. {\FinalUIFont}This Microsoft Fix it is being processed.
MSI (s) (50:68) [15:07:09:825]: Executing op: ODBCDriverManager(,BinaryType=0)
MSI (s) (50:68) [15:07:09:825]: Executing op: ODBCDriverManager(,BinaryType=1)
MSI (s) (50:68) [15:07:09:825]: Executing op: ActionStart(Name=WriteRegistryValues,Description={\FinalUIFont}[PROGR ESS_PROCESSED_TXT],)
Action 15:07:09: WriteRegistryValues. {\FinalUIFont}This Microsoft Fix it is being processed.
MSI (s) (50:68) [15:07:09:825]: Executing op: ProgressTotal(Total=2,Type=1,ByteEquivalent=13200)
MSI (s) (50:68) [15:07:09:825]: Executing op: RegOpenKey(Root=-2147483646,Key=Software\Policies\Microsoft\Windows\I nstaller,,BinaryType=0,,)
MSI (s) (50:68) [15:07:09:825]: Executing op: RegAddValue(Name=Logging,,)
1: \Software\Policies\Microsoft\Windows\Installer 2: Logging
MSI (s) (50:68) [15:07:09:825]: Executing op: RegOpenKey(Root=-2147483646,Key=Software\Policies\Microsoft\Windows\I nstaller,,BinaryType=1,,)
MSI (s) (50:68) [15:07:09:825]: Executing op: End(Checksum=0,ProgressTotalHDWord=0,ProgressTotalLDWord=50400)
Action ended 15:07:09: InstallExecute. Return value 1.
MSI (s) (50:68) [15:07:09:825]: Doing action: RemoveExistingProducts
Action 15:07:09: RemoveExistingProducts. {\FinalUIFont}[PROGRESS_PROCESSED_TXT]
Action start 15:07:09: RemoveExistingProducts.
MSI (s) (50:68) [15:07:09:825]: Note: 1: 2262 2: Error 3: -2147287038
Action ended 15:07:09: RemoveExistingProducts. Return value 1.
MSI (s) (50:68) [15:07:09:825]: Doing action: Milestone_InstallFin291
Action 15:07:09: Milestone_InstallFin291.
Action start 15:07:09: Milestone_InstallFin291.
MSI (s) (50:68) [15:07:09:825]: Note: 1: 2235 2: 3: ExtendedType 4: SELECT `Action`,`Type`,`Source`,`Target`, NULL, `ExtendedType` FROM `CustomAction` WHERE `Action` = 'Milestone_InstallFin291'
MSI (s) (50:68) [15:07:09:825]: PROPERTY CHANGE: Modifying Milestone property. Its current value is 'DIRCA_TARGETDIR'. Its new value: 'InstallFinalize'.
Action ended 15:07:09: Milestone_InstallFin291. Return value 1.
MSI (s) (50:68) [15:07:09:825]: Doing action: InstallFinalize
Action 15:07:09: InstallFinalize. {\FinalUIFont}[PROGRESS_PROCESSED_TXT]
Action start 15:07:09: InstallFinalize.
MSI (s) (50:68) [15:07:09:825]: User policy value 'DisableRollback' is 0
MSI (s) (50:68) [15:07:09:825]: Machine policy value 'DisableRollback' is 0
Action 15:07:09: RollbackCleanup. {\FinalUIFont}[PROGRESS_PROCESSED_TXT]
MSI (s) (50:68) [15:07:09:841]: Calling SRSetRestorePoint API. dwRestorePtType: 0, dwEventType: 103, llSequenceNumber: 111, szDescription: "".
MSI (s) (50:68) [15:07:09:841]: The call to SRSetRestorePoint API succeeded. Returned status: 0.
MSI (s) (50:68) [15:07:09:841]: Unlocking Server
MSI (s) (50:68) [15:07:10:091]: PROPERTY CHANGE: Deleting UpdateStarted property. Its current value is '1'.
Action ended 15:07:10: InstallFinalize. Return value 1.
MSI (s) (50:68) [15:07:10:091]: Doing action: SendSuccessLogEntry
Action 15:07:10: SendSuccessLogEntry.
Action start 15:07:10: SendSuccessLogEntry.
MSI (s) (50:68) [15:07:10:091]: Note: 1: 2235 2: 3: ExtendedType 4: SELECT `Action`,`Type`,`Source`,`Target`, NULL, `ExtendedType` FROM `CustomAction` WHERE `Action` = 'SendSuccessLogEntry'
MSI (s) (50:68) [15:07:10:106]: Creating MSIHANDLE (2) of type 790542 for thread 2408
Action ended 15:07:10: INSTALL. Return value 1.
MSI (s) (50:2C) [15:07:10:106]: Invoking remote custom action. DLL: C:\Windows\Installer\MSI114B.tmp, Entrypoint: SendSuccessLogEntry
MSI (s) (50:90) [15:07:10:106]: Generating random cookie.
MSI (s) (50:90) [15:07:10:106]: Created Custom Action Server with PID 660 (0x294).
MSI (s) (50:D4) [15:07:10:137]: Running as a service.
MSI (s) (50:D4) [15:07:10:137]: Hello, I'm your 32bit Impersonated custom action server.
Action ended 15:07:15: SendSuccessLogEntry. Return value 0.
MSI (s) (50:68) [15:07:15:956]: Closing MSIHANDLE (2) of type 790542 for thread 2408
Property(S): UpgradeCode = {C39BF33C-3152-40E3-83CD-2F1479FC8A72}
Property(S): TARGETDIR = C:\Program Files (x86)\Microsoft\Microsoft Fix it 50381\
Property(S): SourceDir = C:\Users\j\Desktop\
Property(S): DesktopFolder = C:\Users\j\Desktop\
Property(S): ProgramMenuFolder = C:\Users\j\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\
Property(S): ProductName = Microsoft Fix it 50381
Property(S): PROGRESS_REMOVE_TXT = This Microsoft Fix it is being removed.
Property(S): ProductCode = {55D13F49-FCB8-4892-8266-05D373FCAA61}
Property(S): FIXIT_DOESNT_APPLY_TXT_OTHER = This Microsoft Fix it does not apply to your system.
Property(S): ProductVersion = 2.1.3.2
Property(S): Manufacturer = Microsoft
Property(S): ARPCONTACT = Microsoft
Property(S): ProductLanguage = 1033
Property(S): SecureCustomProperties = NEWERPRODUCTFOUND
Property(S): PROGRESS_PLEASE_WAIT_TXT = Please wait...
Property(S): RedirectedDllSupport = 2
Property(S): VersionNT = 601
Property(S): PROGRESS_RESTORE_TXT = Creating a restore point...
Property(S): VSDNETURLMSG = This setup requires the .NET Framework version [1]. Please install the .NET Framework and run this setup again. The .NET Framework can be obtained from the web. Would you like to do this now?
Property(S): VSDIISMSG = This setup requires Internet Information Server 4.0 or higher and Windows NT 4.0, Windows 2000 or higher. This setup cannot be installed on Windows 95, Windows 98, or Windows Me. Please install Internet Information Server and run this setup again.
Property(S): VSDUIANDADVERTISED = This advertised application will not be installed because it might be unsafe. Contact your administrator to change the installation user interface option of the package to basic.
Property(S): VSDNETMSG = This setup requires the .NET Framework version [1]. Please install the .NET Framework and run this setup again.
Property(S): VSDINVALIDURLMSG = The specified path '[2]' is unavailable. The Internet Information Server might not be running or the path exists and is redirected to another machine. Please check the status of this virtual directory in the Internet Services Manager.
Property(S): VSDVERSIONMSG = Unable to install because a newer version of this product is already installed.
Property(S): ErrorDialog = ErrorDialog
Property(S): SFF_UpFldrBtn = UpFldrBtn
Property(S): SFF_NewFldrBtn = NewFldrBtn
Property(S): PROGRESS_PROCESSED_TXT = This Microsoft Fix it is being processed.
Property(S): AdminMaintenanceForm_Action = Repair
Property(S): AdminEulaForm_Property = No
Property(S): DefaultUIFont = VsdDefaultUIFont.524F4245_5254_5341_4C45_534153783400
Property(S): MaintenanceForm_Action = Repair
Property(S): FIXIT_DOESNT_APPLY_TXT = This Microsoft Fix it does not apply to your operating system or application version.
Property(S): FIXIT_REQ_ADMIN_TXT = This Microsoft Fix it requires administrative rights to install.
Property(S): Privileged = 1
Property(S): FixitID = 50381
Property(S): BACK_TXT = < &Back
Property(S): NEXT_TXT = &Next >
Property(S): CANCEL_TXT = Cancel
Property(S): PRODUCT_BANNER_TXT = Microsoft Fix it
Property(S): ProgressUIHeaderText = {\FinalUIFont}[PROGRESS_PROCESSED_TXT]
Property(S): RestorePointHeaderText = {\FinalUIFont}[PROGRESS_RESTORE_TXT]
Property(S): PRIVACY_BTN_TXT = &Privacy Statement
Property(S): CLOSE_TXT = Close
Property(S): EULA_I_AGREE_TXT = I &Agree
Property(S): EULA_DO_NOT_AGREE_TXT = I &Do Not Agree
Property(S): EULA_LICENSE_FULL_TXT = Please take a moment to read the terms of the license below. If you agree to the terms, click the "I Agree", then "Next" to start this Microsoft Fix it solution. Otherwise click "Cancel".
Property(S): ABOUT_TXT = About
Property(S): EXPLORER = explorer.exe
Property(S): FINALBODY_INTERRUPTEDTXT = The installer was interrupted before this Microsoft Fix it could be installed. You need to restart the installer to try again. Click "Close" to exit.
Property(S): FINALBODY_REMOVE_INTERRUPTEDTXT = The installer was interrupted before this Microsoft Fix it could be removed. You need to restart the installer to try again. Click "Close" to exit.
Property(S): FINALBODY_PROCESSEDTXT = This Microsoft Fix it has been processed.
Property(S): FINALBODY_BLOGTXT = Click to read more about Microsoft Fix it:
Property(S): FINALBODY_FAILEDTXT = This Microsoft Fix it failed to process.
Property(S): FINALBODY_STOPTXT = This Microsoft Fix it has stopped
Property(S): FINALBODY_QUITTXT = This Microsoft Fix it is not yet complete. Are you sure you want to quit?
Property(S): FINALBODY_REMOVETXT = This Microsoft Fix it has been successfully removed. Click "Close" to exit.
Property(S): FINALBODY_SURVEY_TXT = Click to tell us what you think:
Property(S): FINALBODY_GET_ONLINE_HELP_TXT = Click to get online help now:
Property(S): YES_TXT = &Yes
Property(S): NO_TXT = &No
Property(S): EXIT_INSTALL_TXT = E&xit Installation
Property(S): CONTINUE_TXT = &Continue
Property(S): OK_TXT = OK
Property(S): TRYAGAIN_TXT = &Try Again
Property(S): FINALBODY_EMAILTXT = Click to send the Microsoft Fix it team e-mail:
Property(S): APP_MUST_BE_CLOSED_INSTALL_TXT = Please close the applications and then click "Try Again".
Property(S): APP_MUST_BE_CLOSED_REMOVE_TXT = The following applications are using files which the installer must remove. You can either close the applications and click "Try Again", or click "Continue" so that the installer continues the installation, and replaces these files when your system restarts.
Property(S): EXIT_TXT = E&xit
Property(S): SERVICE_PACK_BLOCK_TXT = A Service Pack or Windows Update is blocking this Microsoft Fix it.
Property(S): SAME_SETTINGS_NO_CHANGE_TXT = The computer settings already match this Microsoft Fix it and no changes have been made.
Property(S): DOWNLOAD_NEEDED_FIRST_TXT = This Microsoft Fix it does not apply because the computer requires a Microsoft download or Microsoft Update.
Property(S): IMPORTANT_NOTE_TXT = Important note about this Microsoft Fix it
Property(S): RESET_IE_SETTINGS_INFO_BODY_TXT = Click the "Reset" button after clicking "Next".
Property(S): REINSTALL_CD_SW_TXT = After you run this Microsoft Fix it, some programs might not be able to use your CD or DVD drive until you reinstall those programs.
Property(S): SOFTWARE_EXAMPLES_HEADER_TXT = Some examples of programs that might be affected by this Microsoft Fix it:
Property(S): SOFTWARE_EXAMPLES_TXT = iTunes software by Apple
Nero software by Nero Inc
Roxio Creator software by Sonic Solutions
Zune software by Microsoft
Property(S): Milestone = InstallFinalize
Property(S): EULAACCEPTED = 1
Property(S): MsiLogFileLocation = C:\Users\j\AppData\Local\Temp\MSI3e2c0.LOG
Property(S): PackageCode = {1C7C3009-013E-4A16-9A0F-0000FB80A613}
Property(S): ProductState = -1
Property(S): PackagecodeChanging = 1
Property(S): CURRENTDIRECTORY = C:\Users\j\Desktop
Property(S): CLIENTUILEVEL = 0
Property(S): CLIENTPROCESSID = 1968
Property(S): USERNAME = j
Property(S): VersionDatabase = 200
Property(S): ACTION = INSTALL
Property(S): EXECUTEACTION = INSTALL
Property(S): ROOTDRIVE = C:\
Property(S): INSTALLLEVEL = 1
Property(S): SECONDSEQUENCE = 1
Property(S): ADDLOCAL = DefaultFeature
Property(S): VersionMsi = 5.00
Property(S): VersionNT64 = 601
Property(S): WindowsBuild = 7601
Property(S): ServicePackLevel = 1
Property(S): ServicePackLevelMinor = 0
Property(S): MsiNTProductType = 1
Property(S): MsiNTSuitePersonal = 1
Property(S): WindowsFolder = C:\Windows\
Property(S): WindowsVolume = C:\
Property(S): System64Folder = C:\Windows\system32\
Property(S): SystemFolder = C:\Windows\SysWOW64\
Property(S): RemoteAdminTS = 1
Property(S): TempFolder = C:\Users\j\AppData\Local\Temp\
Property(S): ProgramFilesFolder = C:\Program Files (x86)\
Property(S): CommonFilesFolder = C:\Program Files (x86)\Common Files\
Property(S): ProgramFiles64Folder = C:\Program Files\
Property(S): CommonFiles64Folder = C:\Program Files\Common Files\
Property(S): AppDataFolder = C:\Users\j\AppData\Roaming\
Property(S): FavoritesFolder = C:\Users\j\Favorites\
Property(S): NetHoodFolder = C:\Users\j\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
Property(S): PersonalFolder = C:\Users\j\Contacts\Documents\Documents\
Property(S): PrintHoodFolder = C:\Users\j\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
Property(S): RecentFolder = C:\Users\j\AppData\Roaming\Microsoft\Windows\Recent\
Property(S): SendToFolder = C:\Users\j\AppData\Roaming\Microsoft\Windows\SendTo\
Property(S): TemplateFolder = C:\Users\j\AppData\Roaming\Microsoft\Windows\Templates\
Property(S): CommonAppDataFolder = C:\ProgramData\
Property(S): LocalAppDataFolder = C:\Users\j\AppData\Local\
Property(S): MyPicturesFolder = C:\Users\j\Pictures\
Property(S): AdminToolsFolder = C:\Users\j\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
Property(S): StartupFolder = C:\Users\j\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\
Property(S): StartMenuFolder = C:\Users\j\AppData\Roaming\Microsoft\Windows\Start Menu\
Property(S): FontsFolder = C:\Windows\Fonts\
Property(S): GPTSupport = 1
Property(S): OLEAdvtSupport = 1
Property(S): ShellAdvtSupport = 1
Property(S): MsiAMD64 = 6
Property(S): Msix64 = 6
Property(S): Intel = 6
Property(S): PhysicalMemory = 8157
Property(S): VirtualMemory = 13743
Property(S): AdminUser = 1
Property(S): MsiTrueAdminUser = 1
Property(S): LogonUser = j
Property(S): UserSID = S-1-5-21-1139411949-3217698015-1990462012-1000
Property(S): UserLanguageID = 1033
Property(S): ComputerName = J-PC
Property(S): SystemLanguageID = 1033
Property(S): ScreenX = 1024
Property(S): ScreenY = 768
Property(S): CaptionHeight = 22
Property(S): BorderTop = 1
Property(S): BorderSide = 1
Property(S): TextHeight = 16
Property(S): TextInternalLeading = 3
Property(S): ColorBits = 32
Property(S): TTCSupport = 1
Property(S): Time = 15:07:15
Property(S): Date = 6/13/2012
Property(S): MsiNetAssemblySupport = 4.0.30319.1
Property(S): MsiWin32AssemblySupport = 6.1.7601.17514
Property(S): MsiRunningElevated = 1
Property(S): DATABASE = C:\Windows\Installer\142aa4.msi
Property(S): OriginalDatabase = C:\Users\j\Desktop\MicrosoftFixit50381.msi
Property(S): UILevel = 5
Property(S): Preselected = 1
Property(S): CostingComplete = 1
Property(S): OutOfDiskSpace = 0
Property(S): OutOfNoRbDiskSpace = 0
Property(S): PrimaryVolumeSpaceAvailable = 0
Property(S): PrimaryVolumeSpaceRequired = 0
Property(S): PrimaryVolumeSpaceRemaining = 0
Property(S): SOURCEDIR = C:\Users\j\Desktop\
Property(S): SourcedirProduct = {55D13F49-FCB8-4892-8266-05D373FCAA61}
MSI (s) (50:68) [15:07:15:972]: MainEngineThread is returning 0
MSI (s) (50:6C) [15:07:15:987]: RESTART MANAGER: Session closed.
MSI (s) (50:6C) [15:07:15:987]: User policy value 'DisableRollback' is 0
MSI (s) (50:6C) [15:07:15:987]: Machine policy value 'DisableRollback' is 0
MSI (s) (50:6C) [15:07:15:987]: Incrementing counter to disable shutdown. Counter after increment: 0
MSI (s) (50:6C) [15:07:15:987]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installe r\Rollback\Scripts 3: 2
MSI (s) (50:6C) [15:07:15:987]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
MSI (s) (50:6C) [15:07:15:987]: Restoring environment variables
MSI (s) (50:6C) [15:07:15:987]: Destroying RemoteAPI object.
MSI (s) (50:90) [15:07:15:987]: Custom Action Manager thread ending.
MSI (c) (B0:AC) [15:07:15:987]: Back from server. Return value: 0
MSI (c) (B0:AC) [15:07:15:987]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
MSI (c) (B0:AC) [15:07:15:987]: PROPERTY CHANGE: Deleting SECONDSEQUENCE property. Its current value is '1'.
Action ended 15:07:15: ExecuteAction. Return value 1.
MSI (c) (B0:AC) [15:07:15:987]: Doing action: FinishedForm
Action 15:07:15: FinishedForm.
Action start 15:07:15: FinishedForm.
MSI (c) (B0:AC) [15:07:15:987]: Note: 1: 2235 2: 3: ExtendedType 4: SELECT `Action`,`Type`,`Source`,`Target`, NULL, `ExtendedType` FROM `CustomAction` WHERE `Action` = 'FinishedForm'
MSI (c) (B0:68) [15:07:15:987]: Note: 1: 2262 2: Error 3: -2147287038
DEBUG: Error 2826: Control Line1 on dialog FinishedForm extends beyond the boundaries of the dialog to the right by 3 pixels
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2826. The arguments are: FinishedForm, Line1, to the right
DEBUG: Error 2826: Control Line2 on dialog FinishedForm extends beyond the boundaries of the dialog to the right by 3 pixels
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2826. The arguments are: FinishedForm, Line2, to the right
DEBUG: Error 2826: Control BannerBmp on dialog FinishedForm extends beyond the boundaries of the dialog to the right by 3 pixels
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2826. The arguments are: FinishedForm, BannerBmp, to the right
DEBUG: Error 2826: Control UpdateText on dialog FinishedForm extends beyond the boundaries of the dialog on the bottom by 466 pixels
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2826. The arguments are: FinishedForm, UpdateText, on the bottom
Action 15:07:15: FinishedForm. Dialog created
MSI (c) (B0:08) [15:07:16:003]: Note: 1: 2262 2: DuplicateFile 3: -2147287038
MSI (c) (B0:08) [15:07:16:003]: Note: 1: 2262 2: ReserveCost 3: -2147287038
MSI (c) (B0:08) [15:07:16:003]: Note: 1: 2262 2: TypeLib 3: -2147287038
MSI (c) (B0:08) [15:07:16:003]: Note: 1: 2262 2: Class 3: -2147287038
MSI (c) (B0:08) [15:07:16:003]: Note: 1: 2262 2: Extension 3: -2147287038
MSI (c) (B0:08) [15:07:16:003]: PROPERTY CHANGE: Modifying CostingComplete property. Its current value is '0'. Its new value: '1'.
MSI (c) (B0:08) [15:07:16:003]: Note: 1: 2262 2: BindImage 3: -2147287038
MSI (c) (B0:08) [15:07:16:003]: Note: 1: 2262 2: ProgId 3: -2147287038
MSI (c) (B0:08) [15:07:16:003]: Note: 1: 2262 2: PublishComponent 3: -2147287038
MSI (c) (B0:08) [15:07:16:003]: Note: 1: 2262 2: SelfReg 3: -2147287038
MSI (c) (B0:08) [15:07:16:003]: Note: 1: 2262 2: Font 3: -2147287038
MSI (c) (B0:08) [15:07:16:003]: Note: 1: 2262 2: Icon 3: -2147287038
MSI (c) (B0:08) [15:07:16:003]: Note: 1: 2727 2:
Action ended 15:13:48: FinishedForm. Return value 1.
Action ended 15:13:48: INSTALL. Return value 1.
Property(C): UpgradeCode = {C39BF33C-3152-40E3-83CD-2F1479FC8A72}
Property(C): TARGETDIR = C:\Program Files (x86)\Microsoft\Microsoft Fix it 50381\
Property(C): SourceDir = C:\Users\j\Desktop\
Property(C): DesktopFolder = C:\Users\j\Desktop\
Property(C): ProgramMenuFolder = C:\Users\j\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\
Property(C): ProductName = Microsoft Fix it 50381
Property(C): PROGRESS_REMOVE_TXT = This Microsoft Fix it is being removed.
Property(C): ProductCode = {55D13F49-FCB8-4892-8266-05D373FCAA61}
Property(C): FIXIT_DOESNT_APPLY_TXT_OTHER = This Microsoft Fix it does not apply to your system.
Property(C): ProductVersion = 2.1.3.2
Property(C): Manufacturer = Microsoft
Property(C): ARPCONTACT = Microsoft
Property(C): ProductLanguage = 1033
Property(C): SecureCustomProperties = NEWERPRODUCTFOUND
Property(C): PROGRESS_PLEASE_WAIT_TXT = Please wait...
Property(C): RedirectedDllSupport = 2
Property(C): VersionNT = 601
Property(C): PROGRESS_RESTORE_TXT = Creating a restore point...
Property(C): VSDNETURLMSG = This setup requires the .NET Framework version [1]. Please install the .NET Framework and run this setup again. The .NET Framework can be obtained from the web. Would you like to do this now?
Property(C): VSDIISMSG = This setup requires Internet Information Server 4.0 or higher and Windows NT 4.0, Windows 2000 or higher. This setup cannot be installed on Windows 95, Windows 98, or Windows Me. Please install Internet Information Server and run this setup again.
Property(C): VSDUIANDADVERTISED = This advertised application will not be installed because it might be unsafe. Contact your administrator to change the installation user interface option of the package to basic.
Property(C): VSDNETMSG = This setup requires the .NET Framework version [1]. Please install the .NET Framework and run this setup again.
Property(C): VSDINVALIDURLMSG = The specified path '[2]' is unavailable. The Internet Information Server might not be running or the path exists and is redirected to another machine. Please check the status of this virtual directory in the Internet Services Manager.
Property(C): VSDVERSIONMSG = Unable to install because a newer version of this product is already installed.
Property(C): ErrorDialog = ErrorDialog
Property(C): SFF_UpFldrBtn = UpFldrBtn
Property(C): SFF_NewFldrBtn = NewFldrBtn
Property(C): PROGRESS_PROCESSED_TXT = This Microsoft Fix it is being processed.
Property(C): AdminMaintenanceForm_Action = Repair
Property(C): AdminEulaForm_Property = No
Property(C): DefaultUIFont = VsdDefaultUIFont.524F4245_5254_5341_4C45_534153783400
Property(C): MaintenanceForm_Action = Repair
Property(C): EulaForm_Property = 1
Property(C): FIXIT_DOESNT_APPLY_TXT = This Microsoft Fix it does not apply to your operating system or application version.
Property(C): FIXIT_REQ_ADMIN_TXT = This Microsoft Fix it requires administrative rights to install.
Property(C): Privileged = 1
Property(C): FixitID = 50381
Property(C): BACK_TXT = < &Back
Property(C): NEXT_TXT = &Next >
Property(C): CANCEL_TXT = Cancel
Property(C): PRODUCT_BANNER_TXT = Microsoft Fix it
Property(C): ProgressUIHeaderText = {\FinalUIFont}[PROGRESS_PROCESSED_TXT]
Property(C): RestorePointHeaderText = {\FinalUIFont}[PROGRESS_RESTORE_TXT]
Property(C): PRIVACY_BTN_TXT = &Privacy Statement
Property(C): CLOSE_TXT = Close
Property(C): EULA_I_AGREE_TXT = I &Agree
Property(C): EULA_DO_NOT_AGREE_TXT = I &Do Not Agree
Property(C): EULA_LICENSE_FULL_TXT = Please take a moment to read the terms of the license below. If you agree to the terms, click the "I Agree", then "Next" to start this Microsoft Fix it solution. Otherwise click "Cancel".
Property(C): ABOUT_TXT = About
Property(C): EXPLORER = explorer.exe
Property(C): FINALBODY_INTERRUPTEDTXT = The installer was interrupted before this Microsoft Fix it could be installed. You need to restart the installer to try again. Click "Close" to exit.
Property(C): FINALBODY_REMOVE_INTERRUPTEDTXT = The installer was interrupted before this Microsoft Fix it could be removed. You need to restart the installer to try again. Click "Close" to exit.
Property(C): FINALBODY_PROCESSEDTXT = This Microsoft Fix it has been processed.
Property(C): FINALBODY_BLOGTXT = Click to read more about Microsoft Fix it:
Property(C): FINALBODY_FAILEDTXT = This Microsoft Fix it failed to process.
Property(C): FINALBODY_STOPTXT = This Microsoft Fix it has stopped
Property(C): FINALBODY_QUITTXT = This Microsoft Fix it is not yet complete. Are you sure you want to quit?
Property(C): FINALBODY_REMOVETXT = This Microsoft Fix it has been successfully removed. Click "Close" to exit.
Property(C): FINALBODY_SURVEY_TXT = Click to tell us what you think:
Property(C): FINALBODY_GET_ONLINE_HELP_TXT = Click to get online help now:
Property(C): YES_TXT = &Yes
Property(C): NO_TXT = &No
Property(C): EXIT_INSTALL_TXT = E&xit Installation
Property(C): CONTINUE_TXT = &Continue
Property(C): OK_TXT = OK
Property(C): TRYAGAIN_TXT = &Try Again
Property(C): FINALBODY_EMAILTXT = Click to send the Microsoft Fix it team e-mail:
Property(C): APP_MUST_BE_CLOSED_INSTALL_TXT = Please close the applications and then click "Try Again".
Property(C): APP_MUST_BE_CLOSED_REMOVE_TXT = The following applications are using files which the installer must remove. You can either close the applications and click "Try Again", or click "Continue" so that the installer continues the installation, and replaces these files when your system restarts.
Property(C): EXIT_TXT = E&xit
Property(C): SERVICE_PACK_BLOCK_TXT = A Service Pack or Windows Update is blocking this Microsoft Fix it.
Property(C): SAME_SETTINGS_NO_CHANGE_TXT = The computer settings already match this Microsoft Fix it and no changes have been made.
Property(C): DOWNLOAD_NEEDED_FIRST_TXT = This Microsoft Fix it does not apply because the computer requires a Microsoft download or Microsoft Update.
Property(C): IMPORTANT_NOTE_TXT = Important note about this Microsoft Fix it
Property(C): RESET_IE_SETTINGS_INFO_BODY_TXT = Click the "Reset" button after clicking "Next".
Property(C): REINSTALL_CD_SW_TXT = After you run this Microsoft Fix it, some programs might not be able to use your CD or DVD drive until you reinstall those programs.
Property(C): SOFTWARE_EXAMPLES_HEADER_TXT = Some examples of programs that might be affected by this Microsoft Fix it:
Property(C): SOFTWARE_EXAMPLES_TXT = iTunes software by Apple
Property(C): Milestone = DIRCA_TARGETDIR
Property(C): EULAACCEPTED = 1
Property(C): MsiLogFileLocation = C:\Users\j\AppData\Local\Temp\MSI3e2c0.LOG
Property(C): PackageCode = {1C7C3009-013E-4A16-9A0F-0000FB80A613}
Property(C): ProductState = -1
Property(C): PackagecodeChanging = 1
Property(C): CURRENTDIRECTORY = C:\Users\j\Desktop
Property(C): CLIENTUILEVEL = 0
Property(C): CLIENTPROCESSID = 1968
Property(C): VersionDatabase = 200
Property(C): VersionMsi = 5.00
Property(C): VersionNT64 = 601
Property(C): WindowsBuild = 7601
Property(C): ServicePackLevel = 1
Property(C): ServicePackLevelMinor = 0
Property(C): MsiNTProductType = 1
Property(C): MsiNTSuitePersonal = 1
Property(C): WindowsFolder = C:\Windows\
Property(C): WindowsVolume = C:\
Property(C): System64Folder = C:\Windows\system32\
Property(C): SystemFolder = C:\Windows\SysWOW64\
Property(C): RemoteAdminTS = 1
Property(C): TempFolder = C:\Users\j\AppData\Local\Temp\
Property(C): ProgramFilesFolder = C:\Program Files (x86)\
Property(C): CommonFilesFolder = C:\Program Files (x86)\Common Files\
Property(C): ProgramFiles64Folder = C:\Program Files\
Property(C): CommonFiles64Folder = C:\Program Files\Common Files\
Property(C): AppDataFolder = C:\Users\j\AppData\Roaming\
Property(C): FavoritesFolder = C:\Users\j\Favorites\
Property(C): NetHoodFolder = C:\Users\j\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
Property(C): PersonalFolder = C:\Users\j\Contacts\Documents\Documents\
Property(C): PrintHoodFolder = C:\Users\j\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
Property(C): RecentFolder = C:\Users\j\AppData\Roaming\Microsoft\Windows\Recent\
Property(C): SendToFolder = C:\Users\j\AppData\Roaming\Microsoft\Windows\SendTo\
Property(C): TemplateFolder = C:\Users\j\AppData\Roaming\Microsoft\Windows\Templates\
Property(C): CommonAppDataFolder = C:\ProgramData\
Property(C): LocalAppDataFolder = C:\Users\j\AppData\Local\
Property(C): MyPicturesFolder = C:\Users\j\Pictures\
Property(C): AdminToolsFolder = C:\Users\j\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
Property(C): StartupFolder = C:\Users\j\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\
Property(C): StartMenuFolder = C:\Users\j\AppData\Roaming\Microsoft\Windows\Start Menu\
Property(C): FontsFolder = C:\Windows\Fonts\
Property(C): GPTSupport = 1
Property(C): OLEAdvtSupport = 1
Property(C): ShellAdvtSupport = 1
Property(C): MsiAMD64 = 6
Property(C): Msix64 = 6
Property(C): Intel = 6
Property(C): PhysicalMemory = 8157
Property(C): VirtualMemory = 13752
Property(C): AdminUser = 1
Property(C): MsiTrueAdminUser = 1
Property(C): LogonUser = j
Property(C): UserSID = S-1-5-21-1139411949-3217698015-1990462012-1000
Property(C): UserLanguageID = 1033
Property(C): ComputerName = J-PC
Property(C): SystemLanguageID = 1033
Property(C): ScreenX = 1920
Property(C): ScreenY = 1080
Property(C): CaptionHeight = 22
Property(C): BorderTop = 1
Property(C): BorderSide = 1
Property(C): TextHeight = 16
Property(C): TextInternalLeading = 3
Property(C): ColorBits = 32
Property(C): TTCSupport = 1
Property(C): Time = 15:13:48
Property(C): Date = 6/13/2012
Property(C): MsiNetAssemblySupport = 4.0.30319.1
Property(C): MsiWin32AssemblySupport = 6.1.7601.17514
Property(C): MsiRunningElevated = 1
Property(C): USERNAME = j
Property(C): DATABASE = C:\Users\j\Desktop\MicrosoftFixit50381.msi
Property(C): OriginalDatabase = C:\Users\j\Desktop\MicrosoftFixit50381.msi
Property(C): SOURCEDIR = C:\Users\j\Desktop\
Property(C): VersionHandler = 5.00
Property(C): UILevel = 5
Property(C): ACTION = INSTALL
Property(C): EXECUTEACTION = INSTALL
Property(C): CostingComplete = 1
Property(C): ROOTDRIVE = C:\
Property(C): OutOfDiskSpace = 0
Property(C): OutOfNoRbDiskSpace = 0
Property(C): PrimaryVolumeSpaceAvailable = 0
Property(C): PrimaryVolumeSpaceRequired = 0
Property(C): PrimaryVolumeSpaceRemaining = 0
Property(C): INSTALLLEVEL = 1
=== Logging stopped: 6/13/2012 15:13:48 ===
MSI (c) (B0:AC) [15:13:48:558]: Note: 1: 1707
MSI (c) (B0:AC) [15:13:48:558]: Note: 1: 2262 2: Error 3: -2147287038
MSI (c) (B0:AC) [15:13:48:558]: Product: Microsoft Fix it 50381 -- Installation completed successfully.
MSI (c) (B0:AC) [15:13:48:558]: Windows Installer installed the product. Product Name: Microsoft Fix it 50381. Product Version: 2.1.3.2. Product Language: 1033. Manufacturer: Microsoft. Installation success or error status: 0.
MSI (c) (B0:AC) [15:13:48:558]: Grabbed execution mutex.
MSI (c) (B0:AC) [15:13:48:558]: Cleaning up uninstalled install packages, if any exist
MSI (c) (B0:AC) [15:13:48:558]: MainEngineThread is returning 0
=== Verbose logging stopped: 6/13/2012 15:13:48 ===
