Reload Editor
Jun 12, 2012 11:28 AM
We're finding more and more need for multi-SCO projects, and Adobe's packager is very limited.  (Can't save the package?)
I'm wondering - reluctantly - about Reload Editor.  The learning curve looks pretty steep.  Has anybody used it, and does anybody know of any instructions for using it to chain Captivate swfs?
Thanks for any help!
Marion
    Jun 12, 2012 2:10 PM   in reply to MarionJD
    Here's a recorded session that may help with the Adobe packager:
    http://www.adobe.com/cfusion/event/index.cfm?event=set_registered&id=1 932222&loc=en_us
    Here's one for exactly what you're asking about!
    http://captivatedev.com/2011/09/30/packaging-adobe-captivate-scos-into -one-course-using-reload-editor/
    I'd love to know how it works out for you...
    Jun 13, 2012 2:48 PM   in reply to MarionJD
    I think that would be a feature the LMS itself would need to support. I've never seen an LMS-based menu, one created from a multi-sco package, that had more than one level of lessons. I don't think the Reload Editor would allow you to structure that...as such support would probably be pretty unique to the LMS...
    In our LMS, we'd probably handle this by creating multiple courses (i.e course 101, course 102, etc) then having the multi-sco package load the various lessons into the proper courses...just to keep them less daunting...
    Jun 13, 2012 5:32 PM   in reply to Erik Lord
    A multi-SCO SCORM package is one course.  It cannot be a collection of courses.  However, you CAN have a course with multiple SCO modules, and the SCORM standard allows you to specify sequencing rules in the manifest file to specify in what order (e.g. SCO A must be completed before you can open SCO B) or under what conditions (e.g. SCO A must be passed before you can attempt SCO B).  This allows you to build in at least some kind of a hierarchy and structure.
    I don't personally use RELOAD but I believe it does have some ability to build these structures into your manifest file.
    At the end of the day though, it all has to be within one course, and the components will be modules of that course.  The LMS defines your curriculum or collection of courses.
    Jun 13, 2012 8:39 PM   in reply to MarionJD
    Even if you WERE able to define a hierarchy of SCOs, I think the way it would be represented would depend entirely on the abilities built into your LMS SCORM player.
    All of the LMSs I've worked with only support one level of SCO hierarchy in their TOC.
    Jun 14, 2012 7:55 PM   in reply to MarionJD
    Yes.  I use something like MyFirstCourse as the Course ID and MyFirstCourse_01_ModName as the SCO ID for each module.  This way you can always tell which course and course module you are dealing with, even if they should get separated for some reason.  And it means they cannot get mixed up in the LMS either.
