I've created a very simple Configurator panel for Photoshop CS5 that is nothing more than two items in a tabbed navigator with an HTML widget in each.
The Panel Preview shows the HTML content loading perfectly fine, but when I open the panel in Photoshop, everything but the HTML content shows up.
The HTML content that I'm trying to load is hosted on a local server, but just to rule that out as a problem, I created a tab with an HTML object pointing to Adobe.com, but still nothing.
Any help in resolving this would be greatly appreciated.
Scott.
Could you please sent your design panel ".gpc" file and the corresponding ".assets" folder to xguo@adobe.com ?
Let's try and investigate this problem.
Xiaoyan
After checking the gpc file, the root cause if a panel contians "&" in the name, then the content of HTML widget can't be shown in Photoshop CS5.
As for Photoshop CS6, if the panel name contains "&", then the panel is shown with an incorrect size.
Please don't use "&" to avoid this problem.
3x
Xiaoyan
