I keep getting this error message about 11gb into burning a 22gb Blu-ray. "Blu-ray Error: "device error", Code "3", Note: "CreateStcSequence: Fail to write M25 File." I have tried just about everything from running as administrator, starting a new project and changing the disc too. I am using CS6 and going crazy... any ideas?
Did you try deleting the sessions files?
The sessions files should be present at : \<ProjectLocation>\<ProjectFolder>\AuthorScriptHDMVSessions\
First close the project, quit Encore, delete the files present at the specified location and then reopen the project.
Sometimes burners might also go in some inconsistent state. So you might consider turning off your burner and then turning it on.
-Ramesh.
Hi Ramesh,
I do not have a folder or files named AuthorScriptHDMVSessions anywhere I can see in the project location folders. Under transcode folder there are files called myproject_sessionFiles_asf_session_1_video are those the ones I should delete? I am on a Windows 7 Ultimate (64), CS6 version of Encore.
Today I did a build to "blu-ray image," then succesfully burned a test copy, from which I also received the error above when trying to burn directly to a disc before. I am currently building my real project (22gb) to an image and will try to burn from that and see if that works too. Ill keep you posted.
Lucky, I don't know if you have read my thread http://forums.adobe.com/message/4490390#4490390
but I am having the same issue. Right now I am trying with a brand new BD writer.
