How do I add THTML as a PHP file type?
May 8, 2012 4:01 AM
The method I used in previous versions of Dreamweaver doesn't work.  I tried editing the Extensions.txt and the doc types xml.  Thank you.
    May 8, 2012 7:39 AM   in reply to TMHeiser2
    When you have set the server model as per
    any new files will have the PHP extension.
    Gramps
    May 8, 2012 8:24 AM   in reply to TMHeiser2
    Hmm, CS6????
    The example I showed is on a defined site basis. Normally one would not mix different server type fiels within a site. But if I do want another file extension, I go to File -> New Document and choose the file extension as per
    Gramps
    May 8, 2012 9:12 AM   in reply to TMHeiser2
    On my machine I go to
    Computer>System Disk(C:)>Users>myName>AppData>Roaming>Adobe>Dreamweaver CS6>en_US>Configuration>Extensions.txt
    There is probably an easier way to get there, but I only go there when DW gets tangled up.
    Gramps
